Question about Sharp AR-M237 Copier
Sharp Copier Service Code
How do I reset Sharp Copier AR 337 Service Code H5 01?
  • 1 more comment
  • Anonymous Mar 06, 2009
    CODE:F1-14
  • Anonymous Mar 16, 2014
    SHARP AR-5518 RESET CODE
  • Anonymous Mar 28, 2014
    Reset code
  • 62 Answers
You had 5 jams in the fuser the hotarea on the left side of your machine.
Posted on Mar 23, 2008
    New Friend:
Developer signal
Posted on Nov 24, 2012
  • Sharp Expert
  • 1,326 Answers
You don't remove the developing unit, you have to remove the fixing unit to check the thirmal fuse and heater lamp and clean and thest the thirmister. Then clear the error code as listed above. If the code does clear before taken out the fixing unit, take it out and clean the thirmister.
Posted on Mar 16, 2008
P,interrupt,clear,interrupt,enter#14, hit start,hit execute,hit clear all
Posted on Mar 05, 2008
Buy a canon
Posted on Oct 10, 2008
Remove developer unit, check thermistor and heater lamps
Posted on Feb 16, 2008
Please help me, how to reset or clear off Sharp Copier/printer AR 5618s Service Maintenance and Developer Indicator.
try pressing *,#,0,#, 24,2,yes or 1 to reset developer light (circle of dots) Then 20, yes or 1 to reset the little man light.
Dec 19, 2014 | Sharp Office Equipment & Supplies
Diagram Sharp SIM14?
Type # - interrupt - C - interrupt and clear the code with simulation 14 and then hit CA to exit. If the code comes back there is a problem with your fuser (dirty thermistors cloged with toner, or one of the lamps are out)
Apr 06, 2014 | Sharp AR-M237 Copier
I have a sharp AR-337 copier, On the dispaly it reads: CALL FOR SERVICE. CODE:H4-00
H4 00 Heat roller abnormally low temperature
The fusing temperature does not reach 175C degrees within 30 sec of turning on the power, or the fusing temperature keeps at 140C degrees.
C/I/0/I code 14. If it doesn't reset probably a blown thermostat on those piece of **** fusers. Also have seen the lamps some, mostly thermostat. If it has many miles on it I'd just replace the fuser.
If the previous methid wont work..., Clear --> Density select --> Clear --> Density select is for service mode.
Check code 26-30 and set to 0 - CE mark support control OFF
Try surge arrest power source.
Hope helps
Apr 22, 2011 | Sharp AR-M237 Copier
Hello, I have a Sharp AR-337 and I am getting a message: "Call for service. Code: H5-01" is there anything i can do to fix this?
Hello sir; I like you check the exit senser first see does it move freely, if yes, then do a reset procedure; press "program", "interupt", "clear", "interupt" then enter 14 press start, turn power off and back on.
Jun 12, 2009 | Sharp AR-M237 Copier
Sharp AR-275 Copier
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
May 19, 2009 | Sharp AR-275 Copier
Need to reset key operator code on Sharp AR-287
Make sure the copier is in "copy" mode.
To get into service mode press the following keys one after the other "P" key - "interupt" key - "clear" key - "interupt" key (do not play around with setting in service mode as this can render your copier useless)
enter 22 and press "start" enter "7" and press start. This should display the admin code.
Restart the copier and you should be good to go.
Mar 25, 2009 | Sharp AL-1641CS Laser Digital Copier
Sharp copier printer error: PostScrip printing not licensed for t
what is you OS? check you printer drivers. are they properly installed?, what is your connection between your PC to your printer?, AR 275 can be connected thru network, parallel port, and a USB... they have different printer drivers
Feb 01, 2009 | Sharp AR-275 Copier
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M237 Copier Logo
2,588 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
