Question about Taylor 7532 Ultra Thin Glass Digital Scale
Taylor 7532S, battery replaced, error message 0-Ld
Also have the taylor 7532s and have replaced the batteries only to have it show 0.0 then 0-Ld. How can i fix this?
    President:
  • 2,047 Answers
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Posted on Sep 02, 2010
  • norma kelley
    norma kelley Feb 17, 2014
    I do not have a battery. What size do I need?
    New Friend:
I know this question is 5 years old, but hopefully my answer will help people who see the 0-Ld error. This means the scale is overloaded. I had a kitchen scale giving the same error. I took the case apart and bent the metal bar that connects the weighing platform to the circuit board upwards just a bit. It now works fine. Improper storage / handling had caused it to become bent down. The scale then thought it was overloaded and would give an error.
Posted on Mar 10, 2015
    New Friend:
2032 is the battery #....
Posted on Jan 06, 2015
SOURCE:
Taylor scale model 7004 v1812 displays ee replaced battery and it still displays we
Found in a 2012 FIXYA post for a Taylor 7558 but this may work for you too!
"...make sure the batteries are CR2032 and NOT CR2032E batteries. My Taylor 7901 scale finally works!" More on this later...
Taylor 7558 scale not working even with new batteries
More...
The e on CR2032e denotes the manufacturer as Mitsubishi. Both are CR2032 batteries which means they produce 3V and 210 mAh (210 is the spec, 220 is a common claimed total energy content).
https://www.quora.com/Whats-the-difference-between-CR2032-and-cr2032e
I dunno... I just calls em' as I sees em'
Anthony
Dec 16, 2017 | Taylor Health & Beauty
The Taylor bathroom scale is giving an error message. How can I fix this?
If the scale is moved or bumped, or the battery is replaced, the scale needs to be initialized before use.
To initialize, just press on the platform with your foot. The display will turn on and off. The scale is ready for use once again.
Sep 26, 2010 | Taylor 5593 Body Fat/Body Water Scale
How can I fix the Taylor LIthium Scale?
take it to were you got it or instuctions show u
Feb 09, 2010 | Taylor "TAYLOR" 73304072 LITHIUM BATH...
Scales showing Lo after battery has been replaced
Anytime you have trouble with a Taylor scale - they have a lifetime replacement warranty. You need to call their 800 number and pay for 1 way shipping and they will send you a new one.
Jun 04, 2009 | Taylor & Digital Scale Lithium Scale
My Scale stoped weighing me, now it reads 1-ld .
The sensor has been worn out or has been pushed past it's weight limit. When you get on it, it pushed the sensor past the point of working... When she gets on it, no problemo...
Mar 16, 2009 | Taylor 7532 Ultra Thin Glass Digital Scale
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
ERROR message
This link allows you to troubleshoot directly with the company...I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Jan 02, 2009 | Taylor 7506 Precision Tech Lithium Battery...
Taylor Scale 7532s - not working
This link allows you to trouble shoot directly with the company....I hope this helps.
Dec 19, 2008 | Taylor 7532 Ultra Thin Glass Digital Scale
Taylor 7532 Ultra Thin Glass Digital Scale Logo
13,630 people viewed this question
Top Taylor Health & Beauty Experts
Lynnette Kinsman
rebecca curry
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
