Question about GE JE1540 Microwave Oven
GE Built-in Microwave (JE1540w002) NO Heat and turntable not moving.
HI,
I have above mentioned Microwave power comes on timer moving but no heat and turntable is not starting. I have called GE Service line and they are not giving any estimate price for fixing.Therefor, I need help on this one so that I can buy parts and do myself.
Thanks!
  • jeev Mar 23, 2008
    I have the same exact problem and not sure if there is a replcement for this unit - I was told that the frame and the installation kit will cost as much as a new oven. Please let me know how to fix it or if there is a similar modle that I can replace using the same frame kit.
    Thanks,
    Jeev.
I had the same problem.come to find out when i recently replaced the door switch the new terminal i installed,because the old one melted, i must not have pushed it on all the way.it worked itself off the contact of the switch.it took longer to take it all apart than to fix it.cheaper too,lol
Posted on Oct 08, 2008
    Sniper:
  • 65 Answers
Locate the diagram and check you monitor switch it is one of your door switches
Posted on Feb 16, 2008
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
GE microwave not heating, sensor error.
first suspect is the inverter board (power) and magnatron a distant second----in either case the part involved unless an expensive unit is pricey.
Aug 26, 2012 | GE SpaceMaker Microwave Ovens
Microwave will not heat. Display pad lights up, all features work, on that work, turntable moves, but no heat...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jul 27, 2011 | GE JVM2070 Microwave Oven
My advantium lights, turntable turns, timer works, appears to be working as usual, but does not heat..
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
heatman101
Nov 14, 2010 | GE Advantium 120 Convection/Microwave Oven
Everything works (clock, timer, inside light etc.) but not the fan, turntable and will not heat. It stopped while heating lasagne.
Basic
Microwave Oven Troubleshooting Tips
heatman101
Sep 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE JES1358 Microwave: lights are on but doesn't heat
heatman101
Jun 06, 2010 | GE JES1358 Microwave Oven
My microwave is 18 months old, only and it does not heat anymore nor does the turntable turn, what could be wrong?
HELLO,
THIS MEANS THAT YOUR WAVE HAVE DEVELOP MAIZE PROBLEM OR ELEMENT PROBLEM WHAT THIS MEANS IS THAT THE MAIZE HAS BEEN DISCONNECTED FROM IT POSITION BASS ON THE HEAT WHEN USING
SOLUTION TO YOUR MICROWAVE PROBLEM
PLEASE NOTE THIS
THE MAIZE MENTION ABOVE MEANS WIRE AND WHILE THE ELEMENT MEANS THE HEAT PROVIDER
UN SCROLL YOUR WAVE TO LOCATE THE MAIZE TRACE FROM THE ELECTRICITY DOWN TO THE ELEMENT YOU WILL SEE THE TRACE OF DISCONNECTION FROM THE ELEMENT THEN REPOSITION THE LOSS WIRE AND THEN COUPLE IT BACK HAS IT WAS.
AFTER ALL THIS THEN YOUR MICROWAVE WILL THEN CARRY OUT IT FUNCTION AGAIN
PLEASE MAKE SURE THAT YOU MICROWAVE IS NOT PLUG TO ANY FORM OF POWER SUPPLY
GOOD LUCK AND THANKS FOR USING FIXYA .
Apr 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Above Range GE Microwave not heating
Try disconnecting the power line from the microwave ad then reinstalling it after a few minutes.. then try heating up a small cup of water.. allow 1.5 minutes on high power. it should get very hot or boil.. if it doesn't get warm or hot then you may have a bad magnetron ( the tube that produces the microwave energy that causes things to heat up or a bad filament transformer that is required for the magnetron to work.In either case, if it fails to heat anything, I would go back to home depot and insist they send someone out to address the problem. many of their appliances come with a one year warranty but you might want to call the store and ask someone there about normal applaince coverage ( less extended warranty) and what they normally offer. An inquiry costs nothing..
Hope this helps..
Sep 17, 2008 | GE Microwave Ovens
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
284 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
