Question about Audiovox AMP522A Car Audio Amplifier
Car amp high input pinout
As above
  • 43 Answers
With a 4-pin connector - from left, facing the side of amp with RCAs and high level input:
Left speaker + input, Left speaker - input, right speaker - input, right speaker + input
With 5-pin connector - same as above, except center pin goes to ground and 2 right side pins are for right speaker.
Posted on Feb 21, 2008
I want to connect my Bose ps28 iii to another reciever. How and what do I need to make this possible. If I run a av left right to the unit will the reciever turn the unit (bose woofer) on.
The media center plug is wired to carry your left/right signal for front and rear along with reference and turn on voltage. Here's a link to the media center cable pinout images. If you have the connector you can pigtail in your high level inputs (speaker out from the amp you want to use to the corresponding pins. However, I can't guarantee this will work. Bose makes these cables proprietary for a reason... to make money. If hillrods like you and I can easily hack their stuff then they wouldn't be able to overcharge for their goodies. Here's the pinout link anyway. Good luck! http://www.google.com/patents/EP1605637A2?cl=en
Mar 01, 2016 | Bose Audio Players & Recorders
How do you wire it in? Orion 300 prq equalizer
the prq can be used after a head unit before crossover and amps. it is a preamp/equilizer and you must have an orion amp in the signal chain that uses the 5 pin din plug to provide power to the prq via phantom power. if you have a crossover it must be a brand with the same 5 pin din pinout input and output. the din pinout is 1\+15v, 4\r. ch input, 2\ground, 5\l. ch input, 3\-15v. left to right or clockwise on din. the power can be supplied to the prq with an optional 100 pps power supply unit. rca from head unit feed the input and the 5 pin din is the output .
Aug 09, 2013 | Orion 2500D Car Audio Amplifier
High/low gain not working when guitar plugged in
Switch may be dirty. Clean it with some contact cleaner. Also check to make sure you have the right length plug tip and conductor count for the jack. There are 5 lengths in use.
It is a solid state amp so it is possible there is a faulty gain stage in the preamp/driver section. If the amp is an old one more than 18 years old (give or take) it is possible there is an electrolytic capacitor in the gain stage of the "High/Low", switch. It would be in the vicinity of the wiring from the High Low switch where they solder to the main board. It like is one of a few low noise Op Amps, 4558, 387, TL08X/TL07X/TL06X LF353 series. In the 8 pin IC the pinouts are the same, the characteristics are similar. The most basic feedback configuration is just one resistor connecting an input to the output.
Apr 10, 2012 | Peavey Music
I got this Pacific Digital model 1930-24 in a yard sale. It needs a power supply/adapter. Where in canada can I purchase one and is this power supply common. I have a disc drive back up unit for my PC that...
Possibly not. It depends on what the power points are on the connector. The Pacific Digital 1930-24 uses the following pinout voltages: 1 = +12VDC ; 2 = +5VDC ; 3 = RTN/CMN ; 4 = +5VDC ; 5 = RTN/CMN. The pinout DOES NOT follow a clockwise or counter clockwise position. The pinout starts at the bottom with pin 1 by itself, above it is Pin 2 & 4 above that. On the opposite side is 3 with 5 on top. Or you can view the following image: http://img7.imageshack.us/img7/7204/minidin5p.gif
Again, that is the pinout for the socket on the 1930-24. Some iOmega external CDRWs have the +5VDC and RTN pins swapped. So they would not be a good alternative to use.
Jul 25, 2010 | Pacific Digital X-treme CD-RW Burner
Where can i get a ac adapter for a Pacific Digital 1930-48
If you can get an adapter with the correct connector, you could try to make your own power adapter, or even convert an iOmega adapter.
Mar 18, 2010 | Pacific Digital Computers & Internet
PINs for high level input
Hello gmb_66,
You did not specify exactly which Jensen amp you have. None of the Jensen PowerPlus series I found had high-level inputs. You can go here and select your amp to download the manual. They should also have the connector for speaker inputs.
Most amps that have both high-level and RCA inputs allow you to use one or the other, but not both at the same time. If your head unit has RCA ourputs, those would be the ones to use, because they generally provide a cleaner signal to the amp with less noise.
Hope this helps.
May 24, 2009 | Jensen Car Audio & Video
Bose Lifestyle 50 - connection to a non-bose amplifier
The 2 system are completely different your is low level input and its is having only 2 input L and R when those signal they get inside your sub it process through an DSP ( Digital Signal Processor ) and become 5 output to yours satellite cube speakers
The AM6 or 10 are high level input connected direct to any output of any AMP from those signal they convert down to low frequency for sub woofer
Nov 26, 2008 | Bose Lifestyle 38 System
Can the Pyle PLCD-42
Yes there is a couple possible ways.
1. Get 2 RCA Y adapters and split your Preamp Output you will not have any type of fader control this way because you are using a single output.
2. Run one amp from the radio with a set of RCA Cables.
Hook up amp #2 using a Line converter connected to the output of your stereo which will convert you to RCA the just run a cable to the amp..
3. If one of the amps has a High Level Input Run a set of speaker wires from the stereo outputs to the High level Input.
I personally prefer the above 2 methods I find Low Level input sounds better.
Hope this gives you some Ideas and helps
Aug 31, 2008 | Pyle PLCD-42 CD Player
Replacing a Blaupunkt Reno with Florida
Hiii...
This is a PIC mybe can be help you...
Thank's
Jan 27, 2008 | Blaupunkt PA4100 Car Audio Amplifier
OEM gm stereo
If your amplifier has what they call High level inputs (basically inputs on the amp that you run the speaker wires from your radio into), you can splice wires from where the connectors are on your rear speaker(s), still leaving the speaker hooked up, and use those as an input into the amp. If your amplifier does not have high level inputs, a convertor is available to turn an audio signal from your radio output speaker wires ( spliced in just as above, leaving the speaker hooked up), into an rca output jack. Or the best thing to do would be to buy another say 2-4 channel amp w/high level inputs and rca inputs and outputs, and run your rear speaker wires into the amp. Then you'll be able to run the rca cables out of that amp and into the sub amp, and you'll have the new amp to power your rear speakers or rears and fronts. That would be ideal. But, A convertor is your best bet. Got em at best buy, circuit city, etc. Hope this was helpful.
Nov 25, 2007 | Car Audio & Video
Audiovox AMP522A Car Audio Amplifier Logo
1,400 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
