Installed new mother board (PC Chips A33G) now XP will not boot. I've reinstalled the HDD back onto old mother board and system starts fine. What doI do? I was told that if I run the motherboard driver disk while hooked to oldboard it might solve the boot problem on the new board. Is this True? Anotherone told me to start system on old board and change IDE controller to Microsoftstandard dual ide controller.And if this will fix it, How do I change thecontroller? I am not sure what to do next, Please Help!! Thank You Lloyd
Comments:
Feb 15, 2008
- I have tried all that. The BIOS sees the hard drive fine, but it will only boot as far as the window that has the selections to Start windows normally,start windows last known good config.,or start in safe mode. From here it just tries to reboot over and over but never all the way to windows. Thank You Lloyd I Thank anyone who can help further with this problem. Should not be this hard to change out MoBos
Feb 17, 2008
- First let me say I"m thankful for any help anyone can give. In my first post I wrote that someone told me I could hook everything to old mobo and change the IDE controller to Microsoft standard dual ide controller. And if this will fix it,
How do I change the controller? It is running an Intel IDE controller I am not sure what to do next. Can I Roll back that controller, or do I have to delete the controller? Please
Help!! It was hinted that if I change the controller back to microsoft standard controller, that the O.S. will recognize the new mobo and everything will work fine. P.S. I have tried everything you guys have suggested and then some and I am very grateful for the help. The only thing I got to work was to Reload O.S. But I want to keep HDD just like it was, to many things to load or change. Does anybody know if changing controller will work and is so , How do I change it??????? Thank You Lloyd
did you go into the new bios and check to make sure you have the hard drive setting on auto, then check your boot order that the drive is first to boot., if that doesnt work create a floppy boot disk (google it) and see if you see the hard drive when you do that.
Comments:
Feb 16, 2008
- have you boot in to safe mode see if it start there? if it still doesn't boot into safe mode then i would remove all extra cards on the mother board example sound cards, lan cards, video card (if the mother board had internal video), if your mother board has built in anything disable it in bios. what it's trying to do is discover new hardware and it's having a confilt with your old hardware that currently configured, you might want to install fresh.
Feb 17, 2008
- if the controller is part of the mother board then you have to have the drivers that it installs, never heard of using roll back to ms drivers,
