Question about Visioneer OneTouch 5820 Flatbed Scanner
Visioneer OneTouch 5820 USB for windows 7
Visioneer OneTouch 5820 USB para Windows 7 no funciona
    New Friend:
Ok guys here is the fix for vist and or windows 7 to make your scanners work
1. put your cd in the drive don't let it autorun
2. goto my computer then right click the driver that has your install disk in it
3. click open
4. then fine the drivers folder and open it
4. the file you see should be your driver for your scanner the number on this file should be the modle # of your scanner
5. right click that file then click run as adm. allow any and all pop up's
6. after the install is done restart your computer
7.after the computer reboots go back to my computer and open the driver that has you install disk and open it (do not do auto open) like for this file start32.exe and right click it then click run as adm. allow any and all pop up's (you may see something saying in any one of the steps that the driver or software u are trying to load dose not have a signature always click ok, allow, or indtall this sofe ware is old so it dose not have a signature)
8. after the install is done reboot your computer goto control panle and open it look for systems and open it goto device manager open it then look for your scanner it should not be hard to fine it's the one marked with the yellow flag
9. right that file then goto properties then click on it then goto update driver ( do not click driver update software in the same menu with properties) another menu will open up click on update driver it's just below the driver details box
10. now windows will update your driver when done restart your computer and y should be good to go
Posted on Jun 20, 2010
  • Alan Huessy
    Alan Huessy Oct 25, 2016
    manfxrer has no updates for win7 - and win update can't locate one. worthless advice
  • Alan Huessy
    advisors should test their own advice first
SOURCE:
Window 7 driver of visioneer 9320
This model is discontinued from OEM. So, it will not work on Windows 7. For more information, please visit the following links:
http://support.visioneer.com/products/9320/default.asp
http://support.visioneer.com/KnowledgeBase/Articles/VIS1493%20-%20Updating%20Your%20Scanner%20Driver.asp?ScannerModel=DM3115&bit=32
Hope the above information is helpful.
Thanks & regards,
Scancare
Aug 16, 2012 | Visioneer OneTouch 9320 Flatbed Scanner
Hi, I want to use my old visioneer onetouch 7100 usb scanner with win 7, but can't find a driver. can you please help? thank you!
In this instance it looks like this is not compatible with Windows 7. However, sometimes a windows XP driver can work absolutely fine... I would just suggest to give it a try!
http://support.visioneer.com/products/7100/downloads.asp
good luck!
Mar 31, 2011 | Computers & Internet
Need a driver for Visioneer OneTouch 8700 Flatbed Scanner
The drivers for supported OS versions are available here: http://support.visioneer.com/products/8700/downloads.asp . The supported OS versions are: Windows XP SP 1 / 2000 Professional / Me / 98SE and the additional software that was bundled on the CD is not included.
If you have a different Microsoft OS, you can check the Microsoft compatibility center for either Vidat or Win7. A check of the Win7 compatibility Center http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx showed some Visioneer OneTouch scanners work with Win7. However, the 8700F is not in the list.
I hope this helps.
(Dual boot with XP or a virtual computer with an older valid OS version will work. The Win7 Pro and Ultimate let you use Virtual PC and XP mode to run an XP virtual computer for free.)
Jan 03, 2011 | Visioneer OneTouch 8700 Flatbed Scanner
How can i install visioneer one touch 8900 usb scanner in Windos 7?
The 9420 visioneer Scanner driver will run the 8900 scanner.
first,go to visioneer and download the .MSI file for the 9420. Run it. The driver files will be found in directory: C:\Visioneer\OneTouch 4.0\9420 Drivers.next, find the 8900 drivers.they will be in c:\ Windows\twain_32\vizscan8xxx. open the file and look for rtscan.dll Rename it old rtscan.dll.if you can't find them,either use Device manager to show you where they are. or you can reinstall the Driver(Xp\2000\Me\Win 89 from Visioneer site. Rename the rtscan.dll file which will be in the twain_32 folder(see above).
copy all the files in 9420 Driver file to the c:\Windows\twain_32\vizcsan8xxx folder. turn your scanner on.windows should find the drivers and install the scanner.
Sep 18, 2010 | Visioneer OneTouch 8920 Flatbed Scanner
Doesnt get connected under windows 7
For the Visioneer OneTouch 5600 Flatbed Scanner in windows 7 go to the visioneer web site at http://support.visioneer.com/products/5600/downloads.asp and download the file 5600.303110.EN.exe. Then right click on the file name and select Trouble shoot compatibility. Do not connect the scanner until told to. Run the program using the recommend settings. That installs the drivers. It does not install the paperport support software but does install the monitor in the task bar. That is enough to use the scanner and save or print the scans.
Sep 08, 2010 | Visioneer OneTouch 5600 Flatbed Scanner
Does the Visioneer OneTouch 7100 work with Windows 7? Where can I find a driver?
I scanned by cannon scanner (canoscan D646u ex).Suddently the error message appeared that Release the lock switch, detach the usb cable and reconnect.close the scanner driver. What can I do ?
Jan 11, 2010 | Visioneer OneTouch 7100 Flatbed Scanner
I have a visioneer onetouch 8900 and my new computer has Windows 7 on it. Visioneer does not support it anymore, where can I get a driver patch to make it work?
.the Visioneer 9420 scanner program will run the 8900. You can run Visioneer 8900 in Windows 7, and Vista. uing thedriver for9420. Please type 'Can I run Vissioner 8900in vista?
you should see a web site for icrosoft forums that gives the steps involved to get your scanner to work in both Vista and Windows 7.0
Dec 23, 2009 | Visioneer OneTouch 8920 Flatbed Scanner
Visioneer OneTouch 9120 scanner driver for Vista?
iwant todownload visioneer onetouch 9120 usb scanner driver for windows vista
Jan 05, 2009 | Visioneer OneTouch 9120 Flatbed Scanner
Scan slides in 5820 Visioneer Scanner
Here's the Visioneer Support Site for your scanner. You can download the User's Manual HERE.
Jan 17, 2008 | Visioneer OneTouch 5820 Flatbed Scanner
Windows X-P
Here is the link of HOW TO:
http://www.visioneer-europe.com/support/faqs/15.htm
Dec 29, 2007 | Visioneer OneTouch 7600 Flatbed Scanner
Open Questions:
See all Visioneer OneTouch 5820 Flatbed Scanner Questions
Visioneer OneTouch 5820 Flatbed Scanner Logo
1,929 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
Thomas F. Schneider
Ekse
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
