Question about Casio Exilim EX-S600 Digital Camera
Loose cabe on screen
There are 2 cables on thre screen one is black the other is white the white one is still attachedthe black one is free where does it attach too
thanks
  • 477 Answers
If you look right next to the white on you should see a - symbol solder it to there and see if that works.
Posted on Apr 09, 2008
I took apart my Compaq Presario V2630US and I don't know where to plug the cable coming from the screen to the motherboard. The cable contains 2 wires one black the other white each has a female plug that...
Not a problem benpanel.
The cable you're describing is the Wireless Antenna cable.
One Black wire, one White wire.
1) ALL power removed from the laptop. AC adapter (Charger) and Battery
2) Observe Anti-Static Precautions
3) Laptop closed, turn it over, open Battery Compartment facing Away from you.
Open the Mini-PCI Compartment Cover.
(Bottom edge of laptop facing you, in the middle)
The Black and White Wireless Antenna cable leads, plug into the Mini-PCI Communications Module.
(Wireless module)
The connectors are designed so they will only plug in one way, and only to the respective connections.
If you would like the Service Manual (Free) let me know in a Comment.
Regards,
joecoolvette
Dec 12, 2010 | Compaq Presario V2630US Notebook
When i rcharge my phone only a white screen
Tray to make an emergency call like diall 112 or 911 if works it means your phone hardware (engine) or software just fine.in that case the problem are on display.usually the problem are from rubber wire (flexyble cable) that connecting between PCB (engine) with up board like screen,ear phone etc.or the screen (LCD) it self. first, tray to change the flexble cabe.I hope it helps.
May 26, 2010 | Nokia N95 Cellular Phone
How to hook up from TV to recorder
hi there
there are three cable yellow red and white your yellow
cable is the picture cabe and your red and white cabe is the sound cabe plug the yellow cabe in the yellow input and the white and red in the red and white input @ the back ok you recorder now the some go to the tv set it will work 100% now
Dec 19, 2009 | Samsung DVD-VR357
Wii is playing in black and white
Check cable.
You're connect them with what cables?
Oct 12, 2009 | Nintendo Wii Console
Screen goes black and whte and freezes
Does it do it on all connections IE: DVD, Cabe, VCR? if it does than most likely a bad digital board in the TV. If only on one connection you see this then suspect intermittent connections to that device or a bad cable.
Aug 15, 2009 | Televison & Video
Bose Lifestyle 48 System play's dvd in black & white only also connect to vs-2 video enhacer hello, my bose lifestyle 48 only plays DVD's in black and white. I can't find a setting or a reason why it...
Your s-video cable at the back of your media center is loose. This will cause black and white internal video and is known to fall out or just become loose from minor movement. (it's the nature of s-video cables) This should solve your problem. This is the s-video cable that connects to the VS2 and media center.
If this doesn't solve the problem (I'd be surprised), just reset it by unplugging the DC power cable at the side of the VS-2 for about 30+ seconds and plug it back in..
May 31, 2009 | Bose Lifestyle 48 System
Picture blanks out when there's a lot of white
First I have a question for for you...Does it happen on all channels???I'm asking you this because if its not on all channels the problem may not be the tv set but the station that you are watching.The reason is that they have to transmit signal 1Vpp max and if its higher for some reason it makes interference with sound which your tv see as a mistake and protect circuit turn off LCD inside.The other thing is that your lamp time is over and you have to replace it because it can't provide enough light anymore and when "white" scene is on the screen the high voltage unit try to heat gas in the lamp but can't and protect is working again
Feb 26, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Nintendo ds NEED HELP
My DS touch screen is very light. If you turn look at a particular angle you can still see what is shown on the screen, but other than that, the screen looks white. I have already changed the touch pad and that was not the problem. Any assistance would be appreciated.
Thanks
Feb 04, 2008 | Nintendo DS Console
Cabe hook up tore out
Most cable boxes have outputs for audio and video. Yellow is the video, red is the audio out for the right side and white is the audio for the left.
Take a set of RCA jacks and hook it up to the back of the set on input one.
Yellow to Yellow
Red to Red
White to White.
You need further instruction, respond to this post and I will reply.
Dec 17, 2007 | Akai PT5492S 54" Rear Projection...
Casio Exilim EX-S600 Digital Camera Logo
51 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
