Question about Panasonic PT-40LC12 40" Rear Projection HDTV
TV attempts to start and then shuts down altho I hear a fan running, but, no raster.
AS above
  • Gool Feb 16, 2008
    No, flashs green (on sw.)about a minute, then changes to flashing red and eventually stops flasinsg red and shut off. I can hear fans running during this period.
    Genius:
  • 1,665 Answers
Some times the thermistor/temp measuring device is defect.
You must see a service manual that is available at link below , to check also voltages at power supply output.
But if you are not familiar with electronic repairs, better call an authorized tech. service to repair it.
https://www.manualsparadise.com/ShowProductsForModel.do?model=M43671751
Posted on Feb 15, 2008
    President:
  • 1,944 Answers
Does it shut down immediately?
    President:
  • 4,402 Answers
Are there any flashing LED's?
1993 OLDS CUTLASS CIERA Engine cooling fan SHUTS OFF WHEN ENGINE IS TURNED OF, THEN STARTS RUNNING AGAIN 30-40 SECONDS AFTER ENGINE TURNED OFF. hAVE TO DISCONNECT THE BATTERY TO STOP IT.
Sounds like the fan relay is failing, altho normally it keeps powering the fan as you turn the key off.
I suppose the spring could be weak and allowing the points to close.
I would change the relay and see what happens.
Apr 11, 2013 | Cars & Trucks
Fan issue
Only way to know is look to see if fan is on (set will shut down almost instantly if any fan slows or shuts off--the fans are all being monitored.)
Apr 29, 2012 | JVC HD-52G787 52" Projection Television
Tv will intermittently not turn on. when i press the on/off switch i hear a click then i hear fans start up - the fans will die down to a steady speed. no raster. press on/off a few times then tv video...
Your Caps on the PSB- Power supply board are on their way out. Pretty soon it won't turn on at all. You will only get the Fault code blinking LED at startup. Recap the UF capacitors on the PSB. Works 90% of the time.
Jun 30, 2010 | LG MU-50PZ90C Television
Fan was running but neither fridge or freezer were getting cold. You could hear the compressor attempt to start every so often. We replaced the capacitor and the relay and the unit cooled down. The...
Hello
Have you checked the thermal overload on the compressor.It should be mounted on the side of the compressor to feel the heat and shut it down if need be.
Usually a disc type.
Jun 16, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Air flow is blocked
In the 65" TVS there are 4 or more fans One of these is not functioning Probably the one over the power supply itself This will cause it to heat very quickly and shut down in a matter of about 20 seconds.
only way to find out which fan is not working isw to remove the back.
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Mitsubishi WD-65731 65" HDTV
MY PANASONIC PT-50DL54J DLP will just turn off. I
I have posted solutions for similar problems.
There may be a heat issue with the power supply components.
Remove the back panel and blow compressed air into all the component area, (except the fan on the right). The power supply is on the left.
Then vacuum all the dust out.
There may be a problem with the battery in the remote. Weaken batteries can cause the remote to send random signals (including turning off the set).
Aug 22, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Wont turn on, six blinks of led.
Hiii... what type of your TV Set and the chassis number ? it is a Sony ?
IF six blikns incdicated :
No Horizontal (H STOP), no raster...
I hope hear from you soon
[Vrya]
e-mail : be_cek@yahoo.com
Mar 07, 2008 | Televison & Video
SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
I have the same problem... It turns B&W
I can still hear the sound... however I can still turn the tv off when that happens
Aug 28, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
41 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
