Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
Wd external hd
I recently purchased a wd 500 ext hd. It is installed and running properly as near as I can tell, as I am not a computer expert. My question is can I set up a fire wall between my hd and the external hd, to prevet a virus/trojan or other computer destruction or curptive event from entering my h/d and then spreading to the external h/d as it has no on and off switch andthe is connected to start up. I really would find unpluging it and pluging it in again a very detractive feature. Can you answer this please. Nate
Not possible. i suggest 24/7 antivirus monitoring.
Posted on Feb 29, 2008
Hi. My computer says I ejected my WD My Passport external drive but it was not properly ejected. How can I fix this. I need all my thesis files but computer can read the external drive! Help please!
Try to test your WD Ext HDD to a different computer and check if you will get the same problem.
If the same problem persist try to use a different cable for your WD Ext HDD.
If still fails kindly ask the store where you bought the WD Ext HDD on how to retrieve your files and have WD EXT HDD replaced?
If your WD Ext HDD works to a different computer then update the BIOS and Chipset of the computer where your WD Ext HDD connected previously.
Hope this helps.
May 29, 2011 | Computers & Internet
Western Digital My Book Essential Edition 1tb is freezing windows
Sounds like a bad PCB on the drive is bad. It's a known issue with western digital. TechRx, Inc. is an expert data recovery company. We offer free estimates.
Jul 07, 2010 | Western Digital My Book Essential Edition...
WD external HD not working
remove the cover of your drive ...check the fuse protection if blow out...if some instance its protect your unit but sometimes is not....change the fuse placing 500mA ampere 100v .
if your HD running your'e lucky...
May 25, 2010 | Western Digital My Book Home Edition 500...
WD 640Gb My Book Essential: HD on main computer
files must be "imported" into your new mail program.
the new computer may have a newer or different version.
Apr 08, 2010 | Western Digital My Book Essential Edition...
I have a WD 500GB External Hard Drive. It has
That could even be a USB problem, I have the same one, my issue turn out to be just power. You are not the first one to have that problem. Replace the USB cord and see if that affects anything.
Mar 25, 2010 | Western Digital My Book Essential 500GB...
I need to make room on my internal ''C'' drive...was advised to move as many folders as poss to free up space. Have moved Pix, Movies, Doc, Links etc to my WD 500 gb ext HD, but cannot move desktop or...
Have you "emptied" your Recycle Bin?
From the "Start" menu, look in "Accessories".
One of the accessories is a "disk cleanup tool". Run it.
It will also delete all your "Temporary Internet Files" that Internet Explorer has created.
Now that you have "moved" your pictures and movies,
what will you do if your external hard-drive "dies",
taking your _only_ copy of those files to its grave?
It's time to buy a *NEW* "internal" disk-drive, e.g., 400GB for under $100 for a "laptop" disk-drive, reinstall Windows onto it, and copy (not "move") all your files from the external disk-drive to the new disk-drive.
Jan 04, 2010 | HP Computers & Internet
External Harddrive locks up Windows Vista Home Basic on start up
I would suggest two things.
First, plug in the 1TB drive when it won't cause problems, and go to Disk Management under Administrative Tools (for example right-click the My Computer icon and select Manage, then drill down to Disk Management). Check your 1TB disk's drive letter there, and perhaps change it to some letter further down the alphabet, like "T" for example.
Then run a full check on the drive - right-click the 1TB drive and select Properties, go to Tools tab and run "check for errors", selecting the option to repair system errors.
After that's finished, plug in the 500GB drive and run a full check on it as well, just to make sure.
Now try booting up with both disks plugged in - the problem should be gone.
If it's not, then it may mean, that your BIOS is trying to open this 1TB drive to make an option to boot from it possible, and it has troubles because of it's size; some older BIOSes can't cope with disks of that size. Should this be the case, you can go into BIOS Setup and disable booting from other devices that the primary internal hard disk.
Jan 02, 2010 | Western Digital My Book Essential Edition...
WD 500 My Book Prem Ed will not power up
If it's less than a year old, call WD and get a replacement power brick and see if that works.
You could of course also buy a replacement and see if that works.
If the unit is not powering up, the HD inside is almost certainly good. Data recovery is trivial. All you have to do is open the case(hard part) and remove the hard drive. Find a desktop you can install it into and copy the data to a new external HD. If you don't have a a desktop available, you can buy a USB to SATA adapter with a power adapter for about $15-20 that will work well. If you're creative you could probably re-install one of these kits into the existing enclosure for a permanent fix.
Jul 26, 2009 | Computers & Internet
Which operating system are you using? Windows XP or Vista?
Here is the website that you can download the driver for your external harddrive.
Mar 26, 2009 | Western Digital External USB 2.0 80 GB...
WD Elements 500 GB
Hi bobo08,
I'd first check to see if the drive is working correctly with some utilities that WD provides, then once you determine if the drive works, you can either return it the retailer or it's working correctly by using these utilities. Here's the link to that drive. HERE
Good Luck
Jan 01, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
75 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
