Question about Sony Cyber-shot DSC-W55 Digital Camera
My rapid wind lever will not work, i have a Asahi Pentax camera, 35mm, full fram SLR
  • 667 Answers
If you are handy with tools I can tell you what to try first. This involves removing the bottom cover on the camera (4 screws)
Posted on Feb 15, 2008
Asahi Pentax Spotmatic SP jammed shutter
Have the film come to the end of the roll and the camera will not fire, if so rewind the film. Sorry, a shutter is not a self service item. This should be sent in for a CLA.
Nov 04, 2013 | Pentax Asahi Spotmatic Sp 35mm Film Slr...
Asahi Pentax Spotmatic SP The film rewind button is fully depressed and won't pop out, and the shutter button isn't working.
if the camera is jammed for any reason, then the rewind button will not pop out. on this model it was common that the mirror cock lever at the bottom jumped. in which case the camera will jam up.
remove three screws holding the bottom cover, remove cover. in the middle of the camera is a lever that needs to be latched by pushing it forward. the camera should release and revert to normal usage.
if this is not the case then there may be something jammed in the winding or shutter gears. in which case you would have to remove the top cover and/or front covers.
Aug 10, 2013 | Canon EOS-AE-1 35mm SLR Camera
Asahi pentax sv film advance lever stuck
Without film in the camera it may well read before zero, my K1000, K1000Se, and K2 do that. Press the film rewind button, maybe that will release it for you.
For camera repairs look to:
Eric Hendrickson: http://www.pentaxs.com/index.html
Oct 02, 2012 | Pentax K1000 35mm SLR Camera
I have an old Asahi Pentax, release lever and shutter are stuck.
The Pentax is a easy fix, maybe.. If you feel comfortable removing the bottom cover, then remove the 3 cross point screws. The battery, if installed will be loose. Looking at the bottom section of the camera, locate the tripod socket. On on side is the battery compartment, the other an L shaped lever. Under the L shaped lever is a brass plate with a slot in it. In that slot is another lever that has a spring going through the end eyelet. Move that lever toward the front of the camera until it latches on the L shaped lever above. Then try the release.
The first thing to try on the X700 is fresh batteries. Clean the battery cap and contacts with a pencil eraser.
Jan 04, 2010 | Pentax K1000 35mm SLR Camera
Pentax me super camera, not working wind on lever
The clip spring broke jambing the advance gear. by forcing, the tab on the advance shaft broke.
take or send your camera to a camera repair shop for an estimate cost to repair.
there are no new parts for this model so the repairs could be expensive.
there should be no cost for an estimate.
Dec 10, 2009 | Pentax ME Super 35mm SLR Camera
Pentax ME Super Shutter and Rapid Wind Button...
anmolag,
it could be the rubber bumper next to the fresnel lens has become sticky. very gently ( after removing lens ) try to bring mirror down without forcing it. it should release easily.
if not, rotate the select knob off auto. open film door and check that the shutter is fully deployed, shutters should not be overlapping.
remove screws from bottom cover and remove cover, keep camera up side down so that re-wind button stays put. there is a locking lever under the take up spool ( gray ) . with a pin move lever toward film door and bring advance lever fully to the right , then let it go so it returns quickly.
the shutter should have fired. if not the camera will need to be repaired. get an estimate first as there are no new parts available.
Dec 24, 2008 | Pentax ME Super 35mm SLR Camera
Pentax ME Super Shutter and Rapid Wind Button won't release
Common fault due to perished rubber parts. Can be usually be repaired, but do not try to force the camera, that may cause damage which can not.
Go to http:/www.mypentax.com for information on how to service this yourself. The author can also advise by mail, and can service these cameras too.
Nov 23, 2008 | Pentax ME Super 35mm SLR Camera
Film will not advance
Pressing the rewind button wind the film advance lever,if it is free It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Then your winding gears need cleaning
Jan 18, 2008 | Pentax ME Super 35mm SLR Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
88 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
