Question about GE JGBP28 Gas Kitchen Range
Control panel out
The top burners with the clicker ignighters work fine. Its the main panel on the top front panel. it is blacked out . we have checked the breaker and the wall plug where the oven is pluged into. it is getting the proper volts. the stove is getting electricity because the top burner ignighters click and light. could it be the control panel. Thank you Judy
    President:
  • 1,314 Answers
It very well could be have you pushed clock like your going to set it
Posted on Feb 15, 2008
GE JS900 electric range stovetop works fine but no lights or clock on control panel so the oven cannot be turned on.
You will probably have to replace the main control board- the cooktop operates independently of the ovens, so your symptom is not uncommon... GE Range Stove Oven Oven Control Board WB27T10416
Jan 09, 2016 | GE Kitchen Ranges
Bradford White gas power vent water heater; just replaced power vent motor and fan assembly because a bearing went out. Now the new fan motor runs constantly without igniting. Is there a switch that...
Some how you have disconnected the sensor that tells the main burner that the fan is on. Its trying to light but cant. On some models there is a air pressure switch that reads the pressure inside the vent pipe itself. It will have a small hose on it and if that has cracked or was not replaced it wont light. This is how its supposed to work--- vent fan comes on,sensor confirms fan is on,hot surface ignighter starts to glow red,and main burner is opened,another sensor confirms that main burner is lit,then hot surface ignighter turns off. Hope this helps.
Jan 11, 2013 | Water Heaters
Model is pg484ggbs/01- How do you remove control panel ? The large oven is dead, no lights no noise ? what do i check first ?
the first thing i think that should be checked is for 120 vac at the control board all power goes into it then out to the selector and t-stat..the control/relay board is on the rear of the unit and it needs to be pulled out and remove the rear panel, the control. i am having ahard time finding parts breakdown with drawings, but from memory to remove the front control panel ya need to remove the surface burners and the main top and their is screws for the front console under the surface burners. I am assuming the small oven and surface burners work??
I will keep looking to find drawings and let ya know
Oct 28, 2011 | Thermador PD486GEBS Stainless Steel Dual...
Front burner slow in lighting on jenn-air stove top. All other burners light quickly. Could it be the ignighter? Can I switch out ignighters with a back burner that we seldom use?
Yes, it most likely is the ignitor. Chances are it simply needs to be cleaned (ignitor, burner etc.)
If cleaning it does not solve the problem, I reccomend replacing it with a new one.
A malfunction of that type causes gas buildup and can result in excessive ignition when it finally does light. As they get worse, they litterally create mini explosions and can become fire hazzards.
For that reason I reccomend that you do not use that ignitor on any burner with such a malfunction.
You should be able to find a new ignition assembly at your local appliance parts warehouse, or by calling the manufacturer.
Oct 02, 2009 | Kitchen Ranges
I have a whirlpool dryer "LGB6300LW0", that isn't drying. The burner comes on and will go out and come back on. This I guess is to keep the tempature consentant.But after a while the burner doesn't come on...
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 279834.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Disconnect Power. Lift Cover on lint filter. Remove two screws Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a 5/16” hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Reverse process to re-assemble. Take careful note of belt configuration BEFORE removing it. Draw a diagram of its travel.
Motor and idler pulley for dyer will be on right. Gas components, if present, will be on left
Replace All coils with Kit Number listed above. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Sep 04, 2009 | Dryers
The top burners do not light?
your ignighters are not working,,,you need to have it serviced for them to work again..the ignighters are what start the heat process.
Jan 08, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
KItchenaid supera gas stove
thers is a thermal cut-offs under the main control area little black thermostat one controls display andother turns fan on/off
Feb 08, 2008 | KitchenAid KESC307 Electric Kitchen Range
Display no longer works
Yes, I see this but it isn't real common.  The control board (eoc) will have to be replaced.  Most of them are costly.  If you give me the complete model # from the sticker on the oven (may be behind bottom drawer) I can check into this better for you and get you a price.
Oct 18, 2007 | GE Profile JS998 Kitchen Range
GE JGBP28 Gas Kitchen Range Logo
135 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
