Question about Video Game Consoles & Games
Spilled milk in ps3 system, green light comes on then shuts off
    President:
  • 4,402 Answers
No much you can do, open it up and clean it up and let it dry, use 80% rubbiing alchohol and tooth brush and clean as much as you can and dry everything up! look for a fuse that might have blown, if all else sell on ebay!
Posted on Feb 15, 2008
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
When I turn on my ps3 model cechg01, it blinks the green light a couple times then shuts itself off. No other color lights just the green one, then beeps three times and shuts off.. Can anybody help narrow...
When you plug in your system with the power cable and turn the toggle switch (in the back) do you see the red stand by light?
The red and yellow light comes from 1 bulb and the green and blu light comes from another..
If you have the YLOD and your yellow/red light is out, you will only see the green light.
I am really interested in your problem.
Do this to check your status: If you can do this function below but not any other, chances are, you do have the YLOD. It can be fixed.
Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and should eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
Jan 25, 2011 | Sony Playstation 3 (PS3) Console
When ever i turn on my ps3, it stays green for a few seconds then beeps and a light green comes on and then it turns it self off.
Your post is a little confusing. So youre saying that when you turn your PS3 on and the green light comes on...the system then beeps and then turns itself off? nothing shows up on the TV?
If that is the case, its definitely something wrong with the system/OS. Did you download anything or install anything from the net THROUGH the PS3? Or have you hooked up any external drives that may be carrying a virus? Linux systems are not 100% protected from viruses these days so getting one on the PS3 is not unheard of.
You may want to check and see if your system is overheating. Make sure its well ventilated and also use the air-in-a-can **** to clean out some of the dust
Jun 07, 2010 | Sony Playstation 3 (PS3) Console
I turn it on and a green lignt comes on then turns yellow and shuts back off and blinks red
"When the power status light flashes red after turning it on the PS3 system and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked."
"If this happens:
• Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
• If the PS3 system is in an enclosed area like a bookshelf or entertainment center, move it to a more open area.
• Leave the PS3 system off for 30 minutes to let it cool down.
• If you continue to have issues, you will have to send the system in for service."
May 30, 2010 | Sony Playstation 3 (PS3) Console
When i turn the ps3 on the green light comes on then red light comes on blinking instantly blinking then shuts off
Sorry, but your system has overheated and has to be replaced with a new one. Happened to me too. Return the system to the shop you bought it from and they'll give you a new one.
Feb 21, 2010 | Sony Playstation 3 (PS3) Console
My PS3 overheated and won't turn on either.
normally when the ps3 overheats the system will shut down no matter what you're doing, a bit annoying really, though what yoyu have to do is just wait a bit for it to cool to room temp and try again, if it doesn't in the end then i'm sorry but you have fried the cpu, and you must take it back to the shop for repaires
Jul 07, 2009 | Sony PlayStation 3 40GB System
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
134 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
