Question about Tascam Audio Players & Recorders
Help on Tascam 424 4 track repair
I have tascam 424 4 track and the counter and the door latch are broke. I bought another tascam 424 that doesnt work cause someone spilled coffee on it. Would it be easier to swap circuit boards or swap counter and door latch? I cant find any walk through on taking the tascam apart does anyone have any help there? Lots of nobs and things on top and dont want to open wrong. thanks
  • 189 Answers
SOURCE: Tascam Portastudio 424 Manual needed
Try this page: http://www.tascam.com/products/424mkiii;9,17,141,19.html
Regards,
BD
Posted on Apr 25, 2008
SOURCE: tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Posted on May 03, 2008
marsrover
  • 682 Answers
SOURCE: I HAVE A TASCAM DIGITAL
http://www.manualnguide.com/download/manual-guide/tascam-dm-24-digital-mixer-automation-manual.html
setup information in manual above-i think cable will be found in a music equipment store near you.
Posted on Jul 18, 2008
SOURCE: Tascam 238 tape deck
Common problem with these decks-the capstan motor needs to be replaced- A DIY job if you are careful and have some mechanical common sense- Tascam still sells these motors, around $100
Posted on Oct 12, 2008
  • 189 Answers
SOURCE: load imported songs on tascam dp02 cf
Make sure you have the song loaded first. In this case it sounds like you are importing into a new song, so make sure that you have a new song created and loaded prior to importing.
Then go to the menu by pressing the 'MENU' sutton and from there select 'WAVE' and then 'IMPORT TRACK'. You'll see the list of wav files on the fat partition of the CF media displayed. Select the wav file with your beat track on it (use the DATA DIAL or up/down arrow buttons to highlight the right wav file) and press the 'YES/ENTER' button. You'll be prompted for the track to import into. Select Track01 and press the 'Yes/Enter' button again and the WAV file will be read and inported into track 1.
Please note that the wav file should be a 44.1 kHz, 16-bit and a mono wav before trying to import it. If the beat track was created as a stereo wav you'll have to go into a wav editor like Audacity and resave the file as a mono wav file first. Also for a wav with a bit rate higher than 16-bit, the DP-02 is going to truncate the bits rather than dither and this might effect quality adversly so you might want to make sure that the file is properly saved as 16-bit prior to attempting an import to avoid this.
Hope this helps.
bd.
Posted on Jan 12, 2009
Tascam 424 noise
I need more info but I do repair them still in chicago area so that you have a fully functional unit.
Look up skywave tape deck repair if you want to. I have been doing Teac work for over 40 years.
Mar 30, 2014 | Tascam Audio Players & Recorders
I need a power supply for a tascam 424 mk iii. It
Check these out: http://www.audio-depot.com/index.php?main_page=product_info&products_id=1571&currency=USD
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350275805259&rvr_id=&crlp=1_263602_263622&UA=M*S%3F&GUID=c3a1fd4411e0a0b586e289a2fff2035d&itemid=350275805259&ff4=263602_263622#ht_600wt_941
Oct 10, 2009 | Tascam PS-PS5 Power Supply Power Supply
Tascam 424 MK II, how to bounce tracks?
Here is a link I found that took me to an owners manual for your device.
http://www.scribd.com/doc/264105/TASCAM-424-mkII-Manual
Hope this helps :D
Jun 06, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam 424 portastudio mkII power supply
My mistake this is a 424 mkIII not a mkII. Sorry for the typo. Great news is I opened the power supply case and un-soldered the fuse. cleaned it off with tarn-x and behold 3 amps 250 volts. Definatly worth the $1.00 im gonna have to pay for that. As for the **** that was gonna charge me a $100 bucks. There is a reason you are doing that to people. And one day your services will be obsolete.
Apr 28, 2009 | Tascam PS-PS5 Power Supply Power Supply
Having problems recording and playing back tascam dc-02 cf
I'm assuming you are plugging the left and right outputs from the karaoke machine into input A and B of the Tascam to record the stereo output of the Karioke. The Tascam works with mono only (you recreate the stereo mix at mixdown or when bouncing mono tracks together with the panning set). Therefore you should be assigning inputs A and B separately. You could press assign A and then the record button above track 1 and then press assign B and the record button above track 2. Then arm tracks 1 and 2 (by pressing record above each). When you then press play and record together you'll record input A onto track 1 and input B onto track 2.
Hope this helps.
bd.
Mar 25, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam MF-P01 recorder
Hi
I have found Tascam to be an excellent provider of service and spares over the years. Parts can be purchased through a Tascam Authorised Service center. Or you can generally deal direct with them if you are repair guy. You can find one near to you at this site. . Enter your state if you are in the USA, or select the region you are in at the top of the web page where it says global, and away you go. If you have any problems sorting it out, feel free to get back to me and I will help you as best I can. A FixYa is a great reward for helping you to source your part. Cheers
regards
robotek
Oct 07, 2008 | Tascam Starter Pack for 4-Track Cassette...
Could you please tell me the simplest way to record a backing track off a cd onto the hard drive of the Tascam DP-01FX/CD and then add vocal and other percussion onto this track. I bought the unit...
Just review the manual guide,everything is there; in how to record.
If happens if you don't have it,just click below..
Sponsored Links Tascam Manuals on Retrevo
Free download of manuals from the
largest collection on the web
www.retrevo.com/Tascam-manuals
Aug 10, 2008 | Tascam Audio Players & Recorders
I can't figure out how to record on 8 tracks at the same time.
Link to Tascam 2488 documents page:
http://tascam.com/Products/2488_downloads.html
Individual Items as Listed:
Link to the Tascam 2488 product brochure:
http://tascam.com/Products/2488/2488_bro.pdf
Link to the Tascam 2488 application guide:
http://tascam.com/Products/2488/2488_AppGuide.pdf
Here's the link to the Tascam 2488 quick start guide:
http://tascam.com/Products/2488/2488_quickstart.pdf
Link to the updated Tascam 2488 manual:
http://www.tascamcontractor.com/ftp_resour...w_additions.pdf
Link to the Tascam 2488 manual additions:
http://www.tascamcontractor.com/ftp_resour...e_additions.pdf
Link to the Tascam 2488 MIDI Parameter Mapping
http://www.tascamcontractor.com/ftp_resour...ontrol_v0.2.pdf
Link to TASCAM 2488 Hi-Res images:
http://www.tascamcontractor.com/ftp_resour...488_images.html
Nov 07, 2007 | Tascam 2488 Portastudio Multitrack...
Okay I have found two solutions here. They may both be the same but the information here is kind of vague so I will post them both. I have found a PS-PS5 power supply as the title suggests. It can be found here: http://www.supermediastore.com/tascam-ps-ps5-power-supply-for-trainer-series.html I have also found a power supply for the Tascam 424 mkii which can be found here: http://cgi.ebay.com/Tascam-PSP424-Replacement-Power-Supply_W0QQitemZ7405614833QQcmdZViewItem Hope this helps!
Jun 10, 2007 | Tascam PS-PS5 Power Supply Power Supply
127 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
