Question about Leica 28-70mm f/3.5-4.5 R Vario Elmar Lens
Loose lenshood The built-in lenshood is loose.How can I fix it?
  • Anonymous Sep 19, 2008
    I have the same problem with mine. I think it is just poor design . I have not got a solution except to glue it down and find a stepping ring that will fit on the end. It is an awful thing to suggest with a Leica lens but what else can you do. I do not know what head gasket markers are that the other person suggested. Ideally I would like to remove the hood altogether but I cannot see how to do that without disassembling the lens.
    Champion:
    Scholar:
  • 216 Answers
Buy from auto store- head gasket markers.
atdlee@netzero.com
Posted on Feb 23, 2008
Loose handle
Open the door and loosen the self threading screws around the sides of the inner door panel. Once this has been achieved lift the inner panel up so that you can access the door handle screws. Tighten these fasteners and reassemble the door panel.
Jan 24, 2014 | LG LDF6810ST Stainless Steel Built-in...
Dark corners on picture for Canon500d
That sometimes happens when the wrong size lenshood is used. Is that your problem?
Sep 30, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
I have the tokina atx 280 pro lens but no hood, where can i get a replacement hood? or other brands that can fit in my lens. thanks
Most good camera shops and even some online camera stores should be able to help you
Part# BH775
also look here and contact this site as as long as it fits the lens size you have a variety of shapes.
http://www.jsteven.net/tokina-lens-hood/
you can make your own see this page
http://www.lenshoods.net/hoods/Digital-Lenshood-Tokina-AT-X-280-Pro-AF-28-80mm-f-2.8.php
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Tokina AF 28-80mm f/2.8 AT-X Aspheric Pro...
My grandpa needs a new part for his vivitar 55mm. I don't know about cameras so my description may not be great but it is a rubber ring around a plastic piece that screws into the lens. We need to find a...
I think you want a lenshood that is 55mm in diameter (the distance across the front of the lens-what we also need to know is about the lense- what is the wrting on the ring around the very front glass lens? Also, if you l ive near a camera store, take the lens in and they can help you.
May 17, 2010 | Vivitar 35x X3 Telephoto Lens For All 55mm...
Dishwasher leaks from bottom
You must first determine exactly where the water is coming from. The water supply line may be loose or cross-threaded. The overflow float may be stuck in the down position. This will allow the machine to over-fill and leak. The door seal may be worn or off-position. The drain line may be loose or have a hole in it. The wash tub may have a crack in it that needs to be sealed. A gasket around the motor or the heating element may be loose or split.
Get a flashlight. Remove the bottom panel. Start the cycle. Get comfortable on the floor and watch closely. This may be a simple fix. Something like tightening a loose hose. Good luck
Dec 04, 2009 | GE Nautilus 24" Built-in Dishwasher
The left mouse key broke loose on my HP Pavilion dv6-1234dx
Easy fix, no. The fix is to replace the palmrest assembly. The required a large amount of dissassembly of the system.
Work around
Use a USB wireless mouse
Oct 10, 2009 | Computers & Internet
I have a kenmore dishwasher model number 15921 and its flashing a error f6 or f8 what is the problem
F6 is a communication error. It is either a loose connection to the control board, or the control board is shot. They should have diagnosed this when they came out to fix it. Open it up, and look for loose connections.
Feb 02, 2009 | Kenmore 15922 Built-in Dishwasher
Detaching Lens Hood
I'm not sure of the exact model number of your lens, but the hood should have a bayonet flange and rotating it in one direction or the other should allow it to then simply pull off.
Nov 12, 2008 | Tamron Macro 90mm f/2.5 Manual Focus...
Neff built in dishwasher model no: S4453N0GB/07 When you switch the dishwasher on all the relevent lights swich on, indicating the dishwasher is ready to use. but when you switch the start button it clicks...
We fixed the problem at home. The Start button had a loose connection.unscrewed the panel and pushed all the wires in and were able to restart the dishwasher.
Feb 29, 2008 | Neff 24 in. S4456 Built-in Dishwasher
Leica 28-70mm f/3.5-4.5 R Vario Elmar Lens Logo
187 people viewed this question
Top Leica Cameras Experts
Steven Wander
Steven Wander
Steve
Are you a Leica Camera Expert? Answer questions, earn points and help others
