Question about RCA DISH Network(r) 311 Satellite System
Reciever remote doesn't do anything to activate tv. new batteries.
  • Anonymous Mar 14, 2008
    My box was pdated with the new file for March 12/08, bt I am having problems with the remote control.
    The message on the TV says "no signal", I have checked the connections
    turned black box off and on, and still the remote will not allow me to get to the menu to change channels.
    Please help!
  • 78 Answers
"no signal" means the unit thinks it is not getting signal from the dish. try reset by holding down the power button on the unit for up to 10 seconds. it will acquire sat and then load guide. this makes the unit "think" again. also check to be sure the cable fitting "stinger" is straight. no signal could also mean the tv or vcr is off channel or is not connected or inputted properly with the original tv remote.
Posted on Apr 29, 2008
Doesn't receive signal from remote control
if it works intermittenly then the remote dosent need reprogrammed. SOoooo....
line of site comes to mind. your box needs to see what your remote shoots out. sometimes something ends up in front of the reciever spot on the cable box (FYI: a flashlight at the right angle can help find the sweet spot on most devices)
maybe the dvr is going bad watch EVERYTHING you want to see one last time and have it swapped (like death, you can't take anything with you)
good luck (I hope its just a line of sight problem)
Apr 01, 2013 | Motorola Mobility DCH3416 (160 GB) DTV...
RCA flatscreen remote doesn't work
\its most likely the ir sensor which has the issue. I will need the model number of your set to help you further on the issue. You can reply to this same post for further assistance if needed.
Jan 01, 2013 | Televison & Video
On tv 2 the remote controls the volume and power but will not change channels or do anything else. went to system info in tv 1, pressed sat and power. This did not help. Batteries are new.
Hey, Jane!
I can definitely help you with this. Go to the System Info screen like before, but on the TV2 remote press the 'Record button and see if the number in 'Secondary Remote Address' changes. If it doesn't, let me know here, and I will assist you in programming it!
Tommy Faust
DISH Social Media Representative
Nov 07, 2012 | DISH Network IR Remote Control
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
My control remote doesn't work
Hi, first if remote doesn't work, try new batteries......
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
May 08, 2011 | LG 32LC7D Television
I JUST PUT BATTERIES IN THE REMOTE AND IT WILL NOT RECIEVE THE ORDER FROM THE RMOTE WHAT SHOULD I DO THE T.V. BRAND IS ESA
To troubleshoot the remote control problem, follow this step. 1. Check the battery (new if possible) 2. Get a ordinary radio then scan the radio to no signal frequency...just a buzz song will be okay. 3. Try to point your remote control in front of your radio, then press any keys (numbers or anything) 4. If you heard some sound to the radio while pressing the keys 4.a Your remote control is working fine. 5. If you did not heard anything while pressing the keys 5.a Your remote control is not working. You need to replace it or just buy a universal remote control (cheapest way to do).
Thanks. Hope this helps.
Mar 09, 2011 | Televison & Video
Remote will not work for t.v or dish reciever but batteries are good, lights still work but will not turn tv on or off or turn reciever on or off or even get a guide menu. please help
albertmjuras
Is this a new remote or the existing one? I have provided instructions on how to program the remote to your TV and to readdress the remote to your receiver. Select the model of the receiver you have, click on the link and the just follow the directions. The bottom portion of the page has links for TV codes to program the remote to your TV. If this doesn't work, you may need a new remote. I hope this helps.
Program remote to TV and receiver:
http://www.dishnetwork.com/SupportSection/remote-setup
Ray Calo
DISH Network
Mar 01, 2011 | DISH Network IR Remote Control
Direc TV remote won't work Receiver
call directv and they will walk ya thru reporgramming remote for reciever. or goto menu, setup, remote, then follow on screen instructions. i cant give u the exact instructions cause every reciever is a bit different and its different if one remote operates two directv recievers. ( like a bar would do to operate two tvs with one remote)
Jun 12, 2009 | Directv Universal Remote
My remote control for my t.v
Make sure the batteries are in correct alot of people make that mistake . There should be a diagram inside the cover or under where the batteries go. Also try streching the springs out a bit and clean them with a alcohol pad. Also make sure that there isn't anything blocking the little window/reciever on the tv. If that dont work you may have to replace the remote.
Nov 05, 2008 | Philips Magnavox Learning Universal Remote
Sharp tv dish network
that maybe the case..you could put a shielded barrier(copper coated poly) between them.sounds like it's a little too sensitive
Jun 20, 2008 | Televison & Video
Televison & Video Logo
107 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
