Question about Lakewood LAKQTV22 Utility Heater
Will not stay on
I bought this heater only a couple of months ago. Now it doesn't want to stay on. It shuts off even when it is still cold in the house. I have it on the highest setting. Could the thermostat be going out already?
  • kitty1853 Feb 12, 2009
    i have the same problem it won't stay on
    even when it's on high
    i do love this unit but don't stay on still cold
    Sergeant:
  • 288 Answers
That is what is sounds like. Either that or the over heat protection is kicking it out to when its not supposed to.
Posted on Feb 16, 2008
Axim X51 Amber led stays on even when shut off, has new battery.
OK, i can elp you but before that haver you tried rebooting because then, i would be able to teach you an how to digitize the xf region battery as well as the system compartments
Apr 18, 2010 | Dell Axim X51 Pocket PC
How do you shut down
the pilot light always stays on, its designed to allow your heater to turn on by itself without you needing to light a match every time. if the pilot light is burning you have nothing to worry about. its when the pilot light goes out that a small amount of gas leaks into the room. and by small i mean smaller than a hand held lighter... if you still want to shut the entire thing down you could turn off the gas line feeding the heater or possibly the whole house, otherwise the pilot light will stay on. as far as the actual heater turning off, thats probably controlled by some sort of thermostat somewhere. if you set the temp to very cold it should stay off. if that doesn't work then you may need a new thermostat.
Dec 31, 2009 | Vanguard International VN18B Infra-Red...
I have a 1993 Buick Lesabre. Heater doesn't work.
A relay or the wires connector to the motor needs to be cleaned or replaced.
Dec 03, 2009 | 1993 Buick LeSabre
Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
May 27, 2009 | Honeywell ER150B Air Conditioner
My Lakewood 633 will not shut off unless I shut it off. I fugure that it's a thermostat problem but how can I access it. I bought it two months ago.
Two months ago, it should be covered under warranty. Visit this page for service center info and parts.
Feb 20, 2009 | Heating & Cooling
CARRIER HEATER FAN WONT TURN OFF. PLEASE HELP
Need more information.... Is this a whole house unit, a window unit or what? Model #?
The breaker would be in your basement or wherever your breaker box is. If it's a 220 unit, one side could be kicked if whoever hooked it up used 2 seperate breakers (very unusual but it's been done).
Geno
Mar 06, 2008 | Heating & Cooling
Lakewood LAKQTV22 Utility Heater Logo
178 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
