FixYa.com
Tags:
D-Link AirPlus DI-614+ Wireless Router
How to use this unit as a Access Point for an... (by 2 users)
posted by afongofva on Feb 15, 2008
I bought this unit when I had Broadband to Internet via Cable Modem, but now can I use this as an Access Point to my current (existing) Wireless Network? I am trying to boost the signal in the rooms upstairs.
Thanks!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by bighix1981, posted on Jun 12, 2008
I would really like to use this as a signal repeater, does anyone know how to do that?
Solution #1
posted on Jul 11, 2008
Not Rated (0)
AlmostBob
Rank:Guru Guru
Rating: 87%, 88 votes
set the second router through the web menus to a different ip address, cant have 2 devices on the same (default) 192.168.0.1 address, try 192.168.0.2 (example only) to stop data collisions
connect by cable secondary router lan port 1 to the primary router lan port 4 (any lan port to any lan port),
drag secondary router upstairs on its cable and install it wherever you want
set two routers on different channels.
set all wep settings on both routers the same.
set all pcs to 'auto channel' select
wireless adaptors in pcs will then select strongest signal at any point and transmit thru that router
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Routers problems?
cannot get Blackberry pearl on...
It sees the wireless but either... Answer This...
Hey..DL-614
Hey, did you ever turn the... Answer This...
Repair Service
Find Router Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
