Question about kawasaki PVS-10921 Portable DVD Player
Stopped working I load the in the disc and the player states it is loading and then it displays "no valid disc" I also cannot hear the disc spin.
  • 2 more comments
  • Anonymous Mar 21, 2008
  • Sad in Texas Apr 02, 2008
    My Kawasaki PVS-10921 Portable DVD Player W/Screee, stoppped working. It keeps saying, "Loading", I do not here it spin. I'ved tried turning it off and on, W/Battery only,Plugged in. It will not work.
    Sad In Texas
  • jeffgds Jun 14, 2008
    I am going through the same thing right now. It will play CD's and the Disk cleaner says it has cleaned the lens, but DVD's will not play and says "not valid disk" I find it odd that it will play CD's but not DVD's.
  • Doug  Whitehorne
    Doug Whitehorne May 11, 2010
    Try using a disc cleaner. If not the moto may have to be replaced. Your better off buying a new one. Is this a burned cd. or a retail one?
  • 3 Answers
This happened to me several times, Eventually i gave up. One day though i tried it again and it worked. You should probabaly wait a month or two and see what happens
Posted on Mar 15, 2008
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
Disc not valid messge
yo may want to try cleaning the lens and you might also try cleaning or repairing disc an/or lens
Jun 03, 2009 | kawasaki PVS32801 Portable DVD Player
My Sony DVP-cx995v stopped playing DVD's
I had the same "Cannot play" problem - happened suddenly, I don't think I was doing anything unruly at the time.
After checking repair (exchange) prices in excess of $250 from Sony, I decided to open the cover to see if I could see anything wrong - normally a futile exercise with electronics except that in the past I have cleared errant disks that have lodged themselves near the drive/player at the rear of the library.
Upon opening and watching the library try to load and play I noticed the drive itself was not spinning the disk once loaded. It would sit for awhile, thinking about it I'm sure, then would unload and load the next dvd, again failing to spin.
I thought okay, maybe try to spin the dvd while in the player to see if it's jammed or otherwise hard to turn. It was not hard to turn and spun freely. In fact, when I put my finger through the hole at the exposed side of the player at the hub to spin the dvd, clockwise, it suddenly started to spin - and play!
I put the whole thing back together to test and all seems to be working fine at this point. Not sure what would cause the motor to stop spinning and remain in that state through poweroff/on cycles etc. but I'm sure this is not the last time I will have trouble of this kind.
I would note that when replacing the library back in its home on the shelf, be careful not to tip the library, especially toward the player area because the disks will spill out of the carousel near the player and become jammed when you power it on and attempt to load. A final tip of the library away from the player area may clear this if you hear the disks rolling out of their slots and you don't want to open the top again (it's a darned heavy box when fully loaded).
Jan 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Portable dvd player showing"no valid disc"
try to clean the lens using cd cleaner or cotton buds with drop of water on it. that really works.
Dec 03, 2008 | Venturer PVS177W Portable DVD Player
Stopped playing...all DVD/CD
TRY CLEANING THE LENS WITH A SPECIAL CD LENS CLEANER.. YOU CAN BUY IT WALGREENS OR WALMART
Mar 07, 2008 | Mintek MDP-1020 Portable DVD Player
SONY SLV-350P DVD PLAYER/VCR COMBO
I'm afraid you are dealing with a weakened Laser on the unit. The cost vs. benefit ratio of fixing this unit is not worthwhile.
You will find that there are newer versions of this device on the market less expensive than what you paid for the unit you have now.
Dec 28, 2007 | Sony SLV-D350P DVD Player/VCR
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
"No Valid Disc"
These units are known for bad spin motors. the unit appears to be working , but does not obtain the speed needed to extract the information for the a/d converter to correlate.Unfortuneately it is not economically feasible to repair there units. I would however clean the laser just to rule out the obvious. Scrivitron
Jun 13, 2007 | Durabrand DUR-1500 Portable DVD Player
kawasaki PVS-10921 Portable DVD Player Logo
215 people viewed this question
Top kawasaki Televison & Video Experts
Henry  Thomas
Henry Thomas
wayne chamberlain
Jaime Hernandez
Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
