Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
Panasonic PT-52DL10 DLP TV
I believe that my TV needs another replacement lamp, however, in addition, there is a loud humming sound coming from the center of the unit behind the main circuit panel. Besides cooling fans, are there other "spinning" components inside? I attempted to disassemble the front panels to investigate the problem, but I am not sure of the procedure to get behind the circuit panel. Please advise.
Thanks,
Bob W.
Picture & color distortion if TV is powered down and then restarted in less than 1/2 hour. If started after 1/2 hour it is OK.
  • Panasonic Master
  • 8,617 Answers
Color wheel bearing can make the noise you describe, and that will also cause color distortions.
Posted on Feb 16, 2008
Replaced lamp
There is some short circuit at the main circuit board. Seek help of any experienced service technician.
Aug 01, 2012 | Samsung HL-P6163W 61" TV
The tv hums, you can turn the volum down to zero znd the tv hums to loud
You have a Bad Color Wheel,that is what is causing loud humming sound.
Encompass Parts Distribution 1-800-638-3328
Samsung Parts 1-800-627-4368
Color Wheel is Located Behind Lamp ,Pull Lamp out and with a Flash Light Look inside you should see Color Wheel. Color wheel spins 9,000 rpms per second
Apr 12, 2011 | Samsung HLS4676S Television
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
Hello.... Samsung HL-P5063W Lamp LED blinks approximately 35 times followed by 1 long standby/temp light blink After this all 3 lights remain lit and flash....lamp/standby and timer makes a loud humming...
Sound like ur tv have two problems.The "lamp"LED light flashes,mean ur tv need a new projection bulb.The loud refrigerator sound,mean the tv colors wheel is dead,it spinning off of it axes motor.Hire a tv repairman to do this the colors wheel is hard change,because require take out many machanicals parts even to get to the colors wheel to change.The bulb is easy replaced,but he there pay him to put new one in.
May 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Toshiba 62HM195, Loud hum noise when TV is first turned on.
I have the exact TV and had the exact same problems. It is the light engine with color wheel that needs to be replaced, and they are VERY hard to come by for this model. Our repairman has had our TV for 5 months and still cannot locate a vendor that carries the part. He said according to Toshiba, the part has been discontinued. If you happen to find one, please post. I'll do the same.
Aug 18, 2009 | Toshiba 62HM195 62" HDTV
My DLP TV made a loud popping sound then went off
first. unplug the set for 5 minutes and see if it will reboot. if it does not the you have 2 problems, the chassis is also bad. next open the lamp door cover, it is behind the speaker grill, and behind the lamp door.
take out the lamp and see if it has broken on the inside if it has it needs to be replaced. mits will send you one i believe it is about 100.00 the number is 915P020010. if the lamp looks ok then the color wheel has probably fallen apart.if this is the case the light engine need to be repaired. check out www.tv-techs.com
Dec 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Loud noise
I believe it is the color wheel. The motor might be going bad or it has dirt or dust in it.
I hope this helps
Shuttle83
Nov 06, 2007 | Toshiba 62HM95 62" HDTV
Loud Buzzing Sound - Rear of TV
It is probably the color wheel that needs replacing.
Oct 05, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
374 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
