Question about Singer Featherweight 132Q Mechanical Sewing Machine
Needle wont go up or down
The big knob on the right that moves the needle up and down does not move. What could be causing this and how can I fix it.
Thank you so much
  • jodc Mar 20, 2008
    Mechanics don't engage at all. It's completely locked up, with no threads caught in any place. Hand wheel and clutch knob do not connect, but the clutch knob repeatedly loosens.
  • Singer Master
  • 1,388 Answers
If the Handwheel (big knob) is moving but the needle is not moving, you need to engage the clutch ........depending on the model
- push handwheel in to engage, pull out to disengage
or
- if there is a smaller wheel inside the handwheel, tighten to engage, loosen to release.
BUT if all is jammed........
Check for threads that are jamming the motion of the hook around where the bobbin case is
If your bobbin goes in from the top, remove the needleplate and bobbincase remove thread jams by gently rocking handwheel back and forth until released.
Clean around the hook race with a rag moistened with methylated spirit, surgical spirit or similar, then reassemble.
If front loading, open the door for bobbin case area, release 2 retaining clips holding the collar on (take note of the position/orientation for when you re-assemble....even take a digi photo to refer to !?!).....
......then just do jam removal & clean out in much the same way as for the top loader.
In all cases, don't force too much or be too brutal, gentle and patient works best, try to judge where the jam is caught and work with it slowly......you may need to cut jammed threads, just ensure all are removed before you re-assemble.
Posted on Feb 16, 2008
2 Suggested Answers
  • 1116 Answers
SOURCE: knob not moving
Check the bobbin winding feature to see if it is disengaged.
If there is thread jammed in the bobbin area, the wheel will not move.
Turn off the machine and remove the needle and presser foot.
Remove the bobbin. Open the needle plate and remove the bobbin case and clean the area from lint and thread that may have accumulated there.
Posted on Feb 25, 2010
I don't need help with a washing machine, it's a sewing machine!
Looks like an older mechanical machine--looks very similar to a Bernina I have. Hopefully nothing is broken or out of alignment that would cause this. Refrain from forcing the motor to run while the machine's parts will not move freely or it could damage the motor.
These are great machines, however, they do need maintenance to keep them operating smoothly. They are very prone to seizing when the old oil dries and turns to varnish, thus preventing the parts from moving efficiently. Here's the method I've use to fix several older machines that suffered from this problem. The problem can affect any moving part of your machine, ie the needle bar, the selector knobs/dials/levers, the feed dogs, the handwheel, etc.
Wheel on right side that controls the needle up and down is very tight...
Jul 13, 2017 | PfaFF Sewing Machines
Stitch selector knob on bernina 600, not Deco, is stuck and cannot select needle position, However the width of stitch part of the knob is working.This knob has 2 parts, needle position and width control
Your machine (Bernina 600 Record) has most likely frozen (seized) due to lack of regular maintenance. Don't panic. It can be fixed with a lot of elbow grease, good quality oil and a hairdryer. The following method has resurrected several Berninas I've picked up as "nonworking."
How can fix stuck needle bar on my Bernina 730
It was working now it seems to be frozen the needle part wont move
Nov 01, 2016 | Bernina Sewing Machines
Singer 974 MY NEEDLE WOULDN'T MOVE WHEN I TURN THE HAND WHEEL AND MY HAND WHEEL WOOBLES. HOW CAN I FIX IT?
slacken the small stop screw and remove the centre free motion knob. the balance wheel should now be free to turn independent of the shaft. you will have exposed the friction washer. clean all surfaces and relocate the washer with the two locating lugs facing outwards into the two slots in the shaft and refit the knob and screw. if the screw bottoms on the friction washer remove knob and turn the friction through 180 degrees and try it again
Feb 21, 2014 | Sewing Machines
LED that illuminates the stitch selection bar quit working as did the up/down needle button.
Check your bobbin spindle. If engaged (pushed toward the right) LED will not light. When the clutch knob is pulled out, when you wind a bobbin, the up & down needle will not move. So you must push the clutch knob in again to let the up & down needle go up and down. The clutch knob on my machine is in the large hand wheel upper right side of my machine.
Jul 17, 2011 | Janome 4623 Mechanical Sewing Machine
Where is the indicator to move from one pattern to another on the New Home mx 3123 ? The red light is on behind pattern 1.... How do you move it? Thanks!
it is the big knob on the right hand side below the bigger wheel that moves the needle bar up and down. You have to turn it clockwise to move the indicator to the right all the way to # 13 for straight stitch. It will make a loud click with every move. Make sure the needle is raised up because it jumps back and forth as you move the dial. When you make a buttonhole using pattern 1, when one finishes you turn the dial to #2 then back to #1 to reset the program. I have one right in front of me if you have more questions. This is an AWESOME machine and should never wear out :o)
Jan 15, 2011 | New Home MX-3123 Computerized Sewing...
Knob not moving
Feb 24, 2010 | Brother Sewing Machines
Needle won't move
I had that problem too! I usually turn the tension knob and it works,
Aug 07, 2008 | White Sewing 1632 Mechanical Sewing...
Bobbin Winding
How do I wet wind a 2 inchs long bobbin using varnish.
Thanks
Gholam
Jun 16, 2008 | PfaFF Creative 7570
Needle Keeps Moving While Sewing and Bobbin Wont Thread
Hi Nikki,
The problem seems to be of the needles alignment. If you are using a half bobbin type (D type) needle, makes sure you have used the proper number & size and also fastened it well so that the flat side is firmly fixed/clasping the inner side of the needle hold. That black thing which I feel is the fly-nut that helps you tighten/clamp the needle to its hold. Then after having done that, slowly turn the wheel manually to see whether the needle is going in thru the hole in a straight line and if you can, look underneath to se if the knotter ring (the one that looks like having fangs) comes close as the neele advances inward. All these movements HAVE TO BE syncronised. Only then you will be able to stitch the fines of fabrics speedily. Also make sure oyu are not tugging on the front end of the fabric too hard as this may cause the needle to go in a diagonal manner thus causing it to snap. Take care as to NOT to be too close to the needle while at high speeds. The snapping pieces can fly right into your eyes/nose causing serious injury.
Hope that does it Nikki...
May 06, 2008 | Bernina Virtuosa 150
Singer Featherweight 132Q Mechanical Sewing Machine Logo
689 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
