Question about Emerson MW8168B Microwave Oven
MW 8168B - Inop
Power comes on, timer works normal, Nothing happens inside. The timer works normal, no noise from inside. Help
  • jack37 Feb 16, 2008
    The fuse is good. Thanks anyway.
Some mic's have fuses check that out
Posted on Feb 16, 2008
Our Viking VMOS200 just stopped working. The lights and the countdown timer work, but no fan noise and no turntable spin.
it has nothing to do with the magnetron. first you have to fix step one. then you will know if the magnetron is bad. its one or two of the primary switches on the bottom of the switch tower. usually with these mw if you dont press cancel to stop the mw, and you just push the latch to stop it, those wires heat up and cause the microswitches to burn and loose proper contacts.
put a cup of water in the mw. set it to one minute and as its counting down. push on the latch LIGHTLY, as to not fully open the door and you will hear the magnetron kick on and the turn table start to rotate
Mar 06, 2011 | Viking VMOS200 Microwave Oven
OK, so our microwave stopped working. All the electronic parts are working (lights, timer, turntable, etc...) however the microwaves aren't being produced (nothing ever warms up inside.) This was...
the problem could be with 2 component. The diode or the magnetron. normally when the diode goes bad, the microwave will make a humming sound. The microwave will tend to sound almost normal when its the magnetron. Or sometimes it will make a sparking noise when put to heat.
Feb 26, 2011 | LG LRM2060ST Microwave Oven
Westinghouse wmg281sf microwave Microwave (mw) less than 6 months old and after selecting start the mw makes a noise that seems to come from the light and during operation impedes the power source to the...
Hello mbz... Since the operation is impeded, the problem is more than the light bulb. This unit has an internal short, and should be under warranty for the first year. Return it. Joe
Thanks for choosing Fixya!
Dec 16, 2010 | Westinghouse Microwave Ovens
It has completely gone dead, there is power coming to the unit. I believe I accidently turned the unit on to heat yesterday with nothing inside instead of turning on the timer thereby allowing the unit to...
You already know it can be a costly mistake. Had it happen in my own home!!!!
Several things can be wrong:
1. The Fuse inside the unit
2. The High Voltage Capacitor
3. The Power Diode
4. (bad news) The Magnetron.
There is an RF window that can be bad also as when a microwave is run with no load it can be burned. It is supposed to help protect the Magnetron from reverse flow RF and help disperse the RF inside the unit.
The next question is: "Are you going to talke this by yourself or have it repaired?" We can you advise on what to do but there are some hazards that you need to be aware of if your going top give it a go..... Just reply here. Thanks.
Jan 24, 2010 | Jenn-Air JMV8208A Microwave Oven
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
JVM1850BH02 Microwave completely shut down, not working after...
The extreme heat has opened up one of the thermostats / thermal cutouts (TCOs) in the oven.
If it was the bottom TCO or magnetron TCO, you should be able to access them by just removing the control panel.
But if it's the one on top of the cavity, the oven will have to come out of the wall, then you need to pull of the outer cover..
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You should locate and look this over first.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Fan & Turntable start when door is opened.
sounds like there is a switch that is bad. you can go buy a new MW for about 200$ and in yours if there is a major problem then i would just go buy a new one but might be worth a repair man to come check it out
pleas do not poke around in the microwave as it carries a charge of 5000volts and can kill you even if not plugged in DON'T TOUCH THE WIRES WITH BRAIDS ON THE OUT SIDE if you must get inside of the unit
Dec 10, 2008 | Microwave Ovens
Kenmore Galaxy Microwave Hood Combo Model 72180002400
Do the inside light and turntable come on when you try to cook?
Is it making any unusual noise or is it louder or quieter than normal?
Do you have the model number?
Jul 29, 2008 | Kenmore 62622 Microwave Oven
Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
May 11, 2008 | Microwave Ovens
Can't reset nothing works at all
Did you try to change the outlet
If yes, try to change the Fuse inside the mw
But make sure to unplug the MW first
Emerson MW8168B Microwave Oven Logo
141 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
