Question about ViewSonic VX2235WM Monitor
Monitor resolution Everytime I reboot my machine the resolution for the monitor changes back to 1600 X 900 from 1680 X 1050. I am running Pentium D machine with Window XP and a Viewsonic VX2235wm monitor
  • andrearp88 Mar 29, 2008
    My resolution was 1680 by 1050. But now my screen resolution is 1600 by 1200
  • chimodoll Dec 18, 2008
    Same. I have had the VS monitor and 8800GT 512 meg for over a year set at 1680X1050...three days ago this resolution seemingly disappeared. I cannot find this resolution in display settings or through Nvidia Control Panel. The monitor goes to 1440X900 or 1600X1200. 1680X1050 doesn;t exist.
    I have contacted Nvidia and I have gone through a series of step by step instructions but with no luck.
    Any ideas from anyone?
I ran this monitor for ages on a gforce 7800gt graphics card with flight sim and had no problems until one day it did exactly the same thing.
After uninstalling and re-installing Drivers for both screen and graphics card failed I searched the forums and it is not the monitors fault, its the graphics card not understanding the monitor. The card reacts to any changes you have made to it and adapts to suit (Eg; LCD screens, TV's, S.Video cables etc)
With the Monitor you get a DVI cable. Switch off the computer, unplug your VGA cable and plug in the DVI cable then switch the computer back on.
When the computer reboots to the main screen go into the NVIDIA menu and select single screen view (disable all clones with TV's)
Now in the resolution choices in the NVIDIA menu the resolutions will have changed to max 1680x1050.
Hope this helps.
Posted on Feb 10, 2009
  • 348 Answers
When you increase considerable resolution windows will ask you do you want to keep these settings? you select yes then that will be saved
Posted on Nov 23, 2008
I tried to change the setting of screen to 768 x 1024, when I did it the screen went blank and I can´t set it back.
Hi , Your PC Monitor cannot handle that resolution then, when a Monitor Changes resolution , and you do not click Save Settings ,after resolution has changed , it should automatically change back within 15 seconds...This could be a Driver or PC related error....Otherwise try not too use that resolution
May 22, 2010 | Intel Compaq EVO Pentium 4 1.7GHz / 256MB...
SOYO DYLM24E6 DISPLAYS OUT OF RANGE WAS TOLD MONITOR HAS A RESET BUTTON IF SO WHERE OR IS THERE A FIX FOR THIS MONITOR IT IS NEW
Restart your computer in Safe Mode
(or reconnect your previous monitor).
Set the screen-resolution to 800 by 600 at 60 Hertz.
Shutdown, connect the new monitor, and restart, and your Soyo monitor will be able to display something, using these "NOT-out-of-range" values.
Try changing the resolution to 1024-by-768, or 1280-by-1024,
and "test' these values, to see what values are "in-range" for your new monitor.
Jan 07, 2010 | Soyo DYLM24D6 LCD Monitor
No input signal on monitor after changing resolution
While booting press F8 , Go to safe mode and change the screen resolution and reboot the system.
Hope this helps
Siju.D
Nov 12, 2009 | Compaq Evo D500 PC Desktop
It says "input not supported" whenever i change the resolution higher than 1280 1080..i changed my vga card to my onboard one...cause at least here i can see everything clear with the resolution of 1280...
hi there,
looks like windows does not know how to handle the monitor.
You may try to disable the onboard graphic card in the BIOS before
hooking up the monitor to the nvidia card. then try to run windows in safe mode(by pressing F8 when booting up), it'll run windows with the lowest available resolution, which will be supported by the monitor.
Now download appropriate driver for monitor, install and reboot.
That should do the trick
good luck
Sep 29, 2009 | HP w17e Monitor
RectangulaR box on my screen says: input not supported
If your monitor is displaying a message, that's good news: Your monitor is not shut. What the message is saying is that either the refresh rate frequency, or the resolution you have set your video card to on your pc/laptop, is too high for your LCD (I assume) monitor, and it cannot handle these settings.
It would appear that the default refresh rate for LCDs is only 60Hhz.
Reboot your machine in SAFE MODE, pressing the F8 key repeatedly as soon as the initial POST messages disappear from the screen. Next, select Safe Mode from the different options shown.
Once the PC starts and you're running Windows, go to Control Panel->Appearance and Personalization->Adjust Screen Resolution->Advanced Settings->Adapter->List All Modes and verify that the resolution that's been set is within the range allowed by your monitor.
Your user's manual should have this information. In case you don't have this information, change it to something safe, like 800 x 600 pixels, at 60Hz refresh rate.
Close all windows, reboot, and Voila! Your monitor is back to life!
Should you wish to continue to improve your monitor resolution, then right click anywhere on an empty spot on your desktop, and choose Personalize->Adjust Display Settings, and try a higher resolution, remembering to leave the refresh rate at 60Hz.
Aug 17, 2009 | Acer AL1916W 19" LCD Monitor
Dell 86oo lapton, monitor goes black after start up completes.
The problem is likely that the resolution set on your computer is not compatible with the resolution set on your monitor. The easiest way to fix this is to hook up your old monitor and manually change the resolution to the native resolution on your monitor. Your documentation will have this info. If that does not work then you would need to reset your CMOS chip by shorting two pins. Input your computer make and model into google for a motherboard manual. It will tell you how to do this. Then it will be at the default resolution and you can adjust it from there.
Feb 02, 2009 | Acer X193W LCD Monitor
Resolution
You need to enter a lower resolution. The monitor you are on is incapable of using a resolution that high. If you cannot get back on you need to start in safemode. Then change the resolution to a lower one that your monitor can handle.
Feb 25, 2008 | Gateway FPD2275W LCD Monitor
Dell 2407 a04 Turns on (for 2 seconds) then off
your pc may be set to a resolution that is out of range for the monitor. Boot into "Safe mode" reset the Display settings to 640 x 480. reboot into normal mode then change the screen settings to your desired resolution.
Sep 07, 2007 | Dell UltraSharp 2407WFP 24" LCD Monitor
Screen resolution resets to 800x600 after every reboot when d/port is connected.
You may have to set the monitors resolution to match the pc as they may be different.
Jan 13, 2007 | Dell Latitude D620 Notebook
ViewSonic VX2235WM Monitor Logo
453 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
