Question about Thomson DPL909VD System
Frozen hard drive
Hi, i wonder if you can help, the hard drive has frozen on the above box, it won't record, play or anything and when you go on the library and try and delete the frozen programme it won't delete and then non of the functions work so you have to turn off at the mains to re-start the functions but the hard drive is still frozen. any ideas. thanks, regards andy.
Our Thomson digital terrestrial recorder (DV3) does exactly the same thing. I spend half my time pulling the plug out to un-freeze the thing. It will work happily and then I try to delete a random programme and it just freezes and you can't do anything but pull the power out. Whichever programme it froze on seems to be corrupt in some way so you can't watch it or delete it, it just sits there. Is there a way of resetting the whole system and starting from scratch because surely eventually my whole machine will become full of unwatchable programmes...!
  • 2 more comments
  • ianwoolsey Mar 09, 2008
    I have the same problem - was thinking of chucking it and getting another model - I now have about 6 recordings that I have to avoid !!!
  • lecbruce Jan 04, 2009
  • pigginclover Feb 08, 2009
    Yes I too have frozen programmes. The machine has now taken a turn for the worse and will not even turn on. An orange light flashes on the front and judging my the vibrations coming from the machine, I suspect that the hard drive is active. Pulling the plug and restarting does not help.
  • chrisrobbo Feb 09, 2009
    Thomson DT16300. the orange light constantly flashes, unable to get into menu or anything. does anyone know how to reset this thing or will i have to use it as a UFO.
If you have a Thomson DT16300, here's a handy fix that address freeze ups, lack of reception and problems on your Hard Disk:
goto MENU screen
goto SETUP screen
goto HELP screen
At HELP screen, Enter 1397 - this accesses the engineer panel - you can reformat the HDD in this menu - you will lose all recorded programmes and planned recordings but it clears locked or corrupted files
OR - at the HELP screen, press the GREEN button
On the lower half of the screen youwill see 3 options:
Blue - Reformat HDD - clears all the memory/HDD - useful if you have a corrupted file - you will lose all recorded programmes though
Red - reset the whole box to factory settings - good if you have a locked box or reception problems or cannto scan for new channels. It goes back to when you bought the box, so you will have to input favourites and planned recordings again
Yellow - Software revert - allows you to go back to the previous software driver - you may lose new functions, but you can always restore it back again using the same feature
Posted on Jan 04, 2009
Hiya, I have had the same problem a couple of times and I have been lucky enough to fix it. Firstly switch off the player, switch it back on (my actual TV works, it just freezes when it goes into the library). What you have to do is delete the last recorded program (at the top of the list) and this unfreezes the player.
So, once you click into the library mine freezes within around 2 seconds, what I did was select library and as soon as that library screen appears press the BLUE button and then the green button to confirm the deletion. It takes a little while longer to delete the program but eventually it does and then seems to reset itself. Its a bit of a pain really, and tricky to catch - but rather that than lose the contents of the HD.
Hope this helps?
Best Wishes. Ben
Posted on Jan 05, 2009
My hdd dvd recorder will not record e51 , help
i think thats the code for the hard drive fail. if anything is recorded try to play it if will not play or it jumps about then the hard drive has failed and would need replacing.
Jun 29, 2017 | Toshiba Televison & Video
Hi My Panasonic DMR-E85H Won't let me record to the Hard Drive it is displaying NO REC message on the Display ? Any ideas are most welcome .
it's the same problem with panasonic dmr-e55 recorder ; must we slack them for another one !!! we need help seriously
Jan 13, 2013 | Panasonic DMR-E85H DVD Recorder
Thomson dti6300-16
You can still record all the freeview channels. What has happened is you've run out of room on your hard drive. First you must deselect all the top up channels;
menu > 'Setup' > 'Customise TUTV', and un-ticking all boxes releases space and produces a report of '100%' free for recording. The time available for recording depends on the size of the hard drive and amount of data saved in each recording and 15% of disc space is not counted. This is for software or programme information etc. and, even when not subscribed, ads from TUTV are downloaded to library. However they are replaced or removed automatically, and messages are deleted after a week.
Also delete all the recordings in the library you don't need anymore.
Oct 02, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
I can't get my cd's I recorded on my sony dvd player
Check file extensions of files on your recorded cd's. Add file extension to Roxio, Windows Media player and check your drive settings.
Apr 22, 2009 | Sony DRU840A DVD-RAM Burner
The DVD s recorded from the hard drive won t read on other DVD players Am I missing a setting or what could the problem be. The DVD only play on the player I do the recording from namely the Model LG...
All dvds recorded on a diffrent player have to be finalised before they will play on a diffrent machine I think that you should find the finalise command in your menu ... hope this helps Reagrds Vortash
Apr 19, 2009 | LG RH266 Recorder
Frozen hard drive
Hi this Greynut i have resolved my problem this is what i did press menu then setup press ok then scroll down to the help symbol then press ok then press the green button on your remote control and that will bring up the page settings and what i did was press the red button which is factory defaults that will take your set top box back to the factory settings you will loose your recorded programs but it will be like new setbox again you will have to follow set up instructions and re tune your set i have got all my disc space back now and no problems with screen freezing or set top going off i hope this helps you.
Feb 14, 2008 | Televison & Video
Black screen
80% or more of the issues with your DVR can be resolved by unplugging the box for 90 seconds and plugging it back in. There are some features that will be avilable immediately, and others that will take time to download. IE: all of the quide. I can't stress this enough - reboot your DVR occasionally - just like your computer its hard drive might need this.
I have also seen the hard drive inside this box appear bad when it was actually a problem with one recording. In my case it was a recording on the wrong channel, one that did not broadcast anything in my market. I was unable to access any of my recorded programs and when I tried to play the one in question, the screen went black. I deleted the program and all was well.
Jan 02, 2008 | Arris DCT6200 DTV Receiver
Frozen CDR420
if you already recorded the voices, no ploblem, unplug the power supply will not destroy the recording. and start playbak again.
Nov 05, 2007 | Marantz CDR420 CD Recorder
Recording is choppy and picture freezes
Most likely it's the hard drive, or a loose connection. Either way, I'd bet it's the hard drive and you can replace it very easily.
Oct 22, 2007 | Tivo Series2 TCD649080 Video Recorder
Thomson DPL909VD System Logo
856 people viewed this question
Top Thomson Audio Players & Recorders Experts
shaun taylor
Shehu Pro
Shehu Pro
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
