Question about HP Color LaserJet 2600n Printer
Cant print in my network
I have a color laserjet 2600n in my office and i want to get it connected to my network i have 2 thin clients based in win ce i need a solution because the drivers that came with the printer donĀ“t work with win ce please i need help some one knows wht to do ?
  • ATBT May 11, 2009
    Win XP both machines - can't get HP2600n to print using networked computer???? Computer that printer is plugged into does work when asked. On the networked computer, the document gets sent, and then just sits there. The only way to dump the document is to turn printer off. It sees the size of the document but does not see the number of pages. Help!!!!!!!!!!!!
    Using Dell desktop and printer is plugged via USB into back of it. Have Lynksys router networking HP laptop.
I am having a similiar network problem, I setup the 2600n on my small-office network, plugging it into an 8 port switch along with a computer and IP camera....then connected the switch to the default router...this worked for a while as my router provided the printer an internal IP, but somehow the IP reset itself to an external IP,and print jobs I send now to the 2600n from my network will not print. I can't seem to access a configuration window to set a static IP address my router will recognize.
Posted on Feb 17, 2008
I need help to reset password Client - N380 from thinstation
This is the spec for the device
Model
Thin client NP-N380
Stand-alone operating system
WIN CE 6.0 OS
Maximum Users
Unlimited
CPU
ARM11 800HZ
RAM
128MB
STORAGE
128MB
Audio output
yes
Audio input
Yes (except remote desktop connection)
USB Port
3 or 4
COM TAP
Derivable
Support scanning gun
YES
Support touch screen
YES
Support printer
YES (Network printer)
Power input
5V~2A power 5W
Communication distance
Network Cable biggest communication valid distance
Size(mm)
115*115*26
Support Max resolution
1280*1024or1440*900@24 color depth
Whether to support the latest system patch
support
WIFI
Optional(150Mbps)
Support of the operating system
win xp/2000/2003/7/vista/2008
Keyboard mouse port
USB
Whether can do secondery development
YES
Whether could do USB upgrade
YES
Get the password from this documentation.
http://www.thinclientech.com/wp-content/uploads/2014/01/N380-Manual-Instruction-Embedded-Technology.pdf
Sep 26, 2014 | Computers & Internet
I can't find the host-based driver for hp 2600n for windows 8...
** Fixed **
I got my problem solved by followed below article steps.
http://printer-driver-download.us/hp-color-laserjet-2600-n-driver-download/
Thanks
Jan 28, 2013 | HP Color LaserJet 2600n Printer
How to create network terminal system
As in like a Citrix solution for home? You can setup RDP through windows which is a remote connection to another system on your network. You can do this by clicking Start > Run then typing MSTSC and hitting okay. You can then type the name of the other computer and it should prompt you for credentials. You may need to do a bit of setup on the remote computer first, such as adding your network username and password into the remote users group (right click my computer, choose manage, local users and groups, groups
Mar 07, 2011 | Dell E200 233Mhz Thin Client Terminal...
Hi im looking for info on how to flash or load windows ce on a neoware ca5 thin client, i have downloaded the Os but have no clue how to load it on the thin. can you please assist me
  1. Make a bootable USB drive using HP Drive Key Boot Utility (via bootdisk.com Method 2)
  2. Format the flash disk in the device.
  3. Make the flash disk in the device bootable using MBRTool (This is necessary if you installed GRUB on the disk. The MBR needs to be overwritten)
  4. From the Win CE installation folder, from drive:\<path to wince installation>\PLATFORM\CEPC\SRC\BOOTLOADER\DOS\BOOTDISKcopy all files and paste it to the flash disk in the device (These files always comes with Win CE installation)
  5. Put your build of Win CE - EBOOT.BIN in the flash disk on the device (This will be your custom Win CE image)
  6. Remove the USB drive, and boot the device. Your new build of Win CE should boot up.
Aug 26, 2010 | Computers & Internet
Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
Jan 25, 2010 | HP Color LaserJet 2600n Printer
Unable to find on network
is the printer connected through a network cable,if yes print a config page through the printer and check the ip/tcp settings from the printer and check it against the workstations
Jun 25, 2009 | HP Color LaserJet 2600n Printer
Hp color laser Jet 2600n Printer not working on Network card
Check to see you your antivirus is not blocking it. Or you may want to check HP for the latest drivers.
Also check Windows update to make sure you have latest drivers ESPICALLY if you are using VISTA.
May 23, 2008 | HP Color LaserJet 2600n Printer
Neoware thin client password recovery Windows CE
Use Administrator The "A" is capitaized only....worked for me...administrator with Administrator for password!!!!
Drew
Apr 02, 2008 | Neoware CAPIO 620 (cp4h-bb-aa0) Network...
Not able to print
Check for the connectivity if you have connected to network, Check for any client is using the printer spool , check this if not put me ......................|
thank you
Feb 22, 2008 | HP Color LaserJet 2600n Printer
Upgrade 238622-001, Compaq Evo T30 Thin Client 300Mhz 32MB Flash/64MB/Win CE NET/IE 5.5 w/o
You need to replace the 2mbit bios chip used by the WinCE Evo with the 4mbit one used by the NTe and XPe Evo, then you need an add on flash module, since the onboard flash is too small. After that, just find the OS file and flash away. You can find the OS files and a utility to flash from the HP support site. You'll need a crossover ethernet cable, not a patch cable, to do the flash.
Jun 25, 2007 | Compaq EVO T30 Network Terminal
HP Color LaserJet 2600n Printer Logo
263 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
