Question about ViewSonic VX2255 Monitor
Samsung monitor and mac os
Just bought a samsung syncmaster 2232BW.  I can't adjust the color on it.  There don't seem to be any drivers for mac os.
Please do not adjust RGB unless you know what you are doing.
For critical color work, you will need to use a photospectrometer and calibration software to analyze what your monitor is spitting out.
There are a million obvious reasons you should not trust your eye making arbitrary RGB adjustments off the hip.
Posted on Jun 26, 2008
    Problem Solver:
  • 7 Answers
Go to menubar and adjust colour temperature in green,blue,red
Posted on Feb 16, 2008
I have a SyncMaster 2232BW monitor hooked to my pc, the blue power button comes on when power on, my computer POST appears for about a second then vanishes leaving only bright lights on display, none of...
Seems that you may have the wrong type of video selection theres a button for auto sensing the type of connection. if your video cable is blue then you have an analog connection, white video cable is a digital connection you just need to ensure that the monitor is set to the proper selection.
Sep 05, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
I just bought a used Samsung SyncMaster 2243BWX LCD and plugged it into my Mac Book Pro (an older model) with OSX 10.4 The screen shows a display but it is shifted from the one on my computer with the...
There will be buttons on the front of the monitor where you can change the position of the screen, you could also do this in the display driver on your macbook although I couldnt tell you exactly how on that particular mac, pretty sure the menu onthe monitor will get it sorted though.
Oct 29, 2010 | Samsung SyncMaster 203B LCD Monitor
I have Syncmaster 2232bw. When I first switch it on it flashes for about 1 minute before it stopsa flashing. After that it runs fine until I switch off and it cools. Is this the backlight dying?
This happened with my 2232bw also. The problem was that the 5 820uF capacitors that had burnt out so I replaced them with 5 1000uF capacitors and it's now working like a dream.
Hope This Helps
Slick2160
Oct 15, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
How do you remove the back on a samsung syncmaster 2232bw computer monitor? There are no screws I can see and prying with a screwdriver just scratched it. I need to get in there to replace a lamp or...
toolman6872, Didn't you visit YOUTUBE and see some video clips about "lcd monitor disassembly" and or "lcd monitor repair" ? Let me know if you don't find some info there or at www.ccl-la.com/badcaps.htm Also try using very, very DULL butter knife, not screwdrivers. If you found this helpful, rate it on fixya! 12fixlouie
Dec 31, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
My samsung syncmaster 2232bw wont turn on at all, and the pilot light(blue light surrounding power button) is flashing repeatedly at a fast pace, much much faster than the norm?????????
Solution for Samsung SyncMaster 2232BWplus:
The problem is bad capacitors: 5 pcs. 820microFarad – 25v and 1 pc. 330microFarad -25v. Replace these capacitors. Then re-solder the two transformers of inverter side. Also re-solder the power transformer and the inductor coil.
To open the casing:
At the bottom of the stand just twist the knob to unlock. Then, use a small flat screw driver beginning from the bottom (left or right) then using a hard credit card (or alike) then slide/glide it in between the cover plastics.
Roan
Triangle Tech Whiz
Dec 01, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
ViewSonic VX2255 Monitor Logo
1,546 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
