Question about Canon imageRUNNER C3220 Color Copier
Printing If I have lost the original file in my computer, is it possible to reprint the previous print job with the IR C3220? How to do it?
  • 38 Answers
To the best of my knowledge, unless you stored this file on the copiers hard disk via the mailbox feature and set the mailbox to never delete files, you can't do this.
You may have already checked but try in the recycle bin or trash if you're using Mac
Posted on May 08, 2008
REPRINT FAX
I suspect you look in the history and pick the last job printed if you are in a confidential environment then all the information would be deleted after printing and you would need to re-send the original document again.
Good Luck.
Aug 07, 2014 | Xerox WorkCentre 3615/DN - multifunction...
Tip
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE...
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Then try to print again and it will surely solve your printing problem.
Another procedure :
Go to START
Right click on DOS command prompt and run as administrator
You should be in this command directory before you
Type CMD and be sure you are in this directory C:Windows\System32
And if not, type this to change the directory, CHDIR C:Windows\System32
Type NET STOP SPOOLER and message will appear like this
Exit and go to C: DRIVE
Choose WINDOWS and click show content if not view all the folder files
Choose SYSTEM32
Choose SPOOL
Choose printer and delete printing jobs if any
Again right click on Command prompts and run as administrator
Type NET START SPOOLER
Exit and restart your printer and your computer
I will works fine right now.
NOTE : You can bypass the C:Drive procedure and just type NET STOP SPOOLER AND NET START SPOOLER in the DOS COMMAND PROMPT if you believe that there are no printing jobs pending.
Another procedure is to download this troubleshooting software and follows the troubleshooter wizard and it will fix your print spooler service automatically and some common problems as well.
Click here to start downloading.
I hope it helps you solving your print spooler problem. Regards to all readers.
on Mar 24, 2011 | Office Equipment & Supplies
How do i reprint last thing printed
If you are using Linux, you can retrieve your old print jobs and reprint them easily. Go to localhost:631 in a web browser. From there, you can view your print jobs by clicking the Jobs tab at the top and then click on the Show All Jobs button.
This has proved very useful to me in the past, especially when printing a web page to my wireless printer, only to find out that the printer decided to not work properly and the webpage expired before I could reprint.
Aug 02, 2012 | Canon Office Equipment & Supplies
I printed all the pages I wanted and stopped the printing. today I want to print something else and it wants to prin about 30 pages I don't want, help
Hi
Go to START
Choose RUN
Type SERVICES.MSC
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Apr 14, 2011 | Office Equipment & Supplies
Saving a copy job
Hi
Try to scan your originals to your mailbox on the IR machine and save it there.If you need copies of the originals again go to the mailbox highlight the job and reprint it again.
Nov 17, 2008 | Canon imageRUNNER 5000 Copier
It doesn't print some pdf files from our computer
you can try to use the postscript driver, it should proccess it better. If you need to use pcl driver change the driver setup... under the properites of the driver click port tab... click config port....click lpr and in the Queue name type...print
this should help if not you may need the service tech. to upgrade software rp
Mar 19, 2008 | Canon imageRUNNER C3220 Color Copier
Canon iR 3220 printer problem with PDF files
Sound like a driver issue, reinstall and check that it is correct one.
Nov 09, 2007 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER C3220 Color Copier Logo
106 people viewed this question
old marine
old marine
