Question about Sharp AR-M277 All-In-One Printer
Black line left on copies from the document feeder
I have cleaned the heck outta my glass and the slit of glass, but I can not get this black line to quit printing on my copies. Every time we feed a piece of paper thru the doc feeder, a black line about 11/2 inch up from the bottom of the page is this line all the way across the page. Does anyone have any suggestions on what I could check or clean???
  • 4 more comments
  • AKcopow Feb 15, 2008
    At least I thought it was the glass...I just did the flashlight suggestion and the only thing I saw was some excess toner which I promptly Canned Air'd it but could not find a staple or piece of dirt. And the scratch does look like it is under, not on the top. Our machine does not staple - and I try to keep a good eye if someone has left a staple in their paper when they make copies; no one has done so.
    The line is a thin line - it was a bit thicker, but after I cleaned it it DID decrease in size, but still very noticeable on the copies. I have taken the WHOLE glass off - both pieces - and cleaned both sides. I heard a rumor that one of my rollers might have a fuzzy thing or dirt on them but I did not see anything. Should I check all rollers that I can see/get my hand on??
    As far as I know, the glass has never been rotated. We had this issue a while back, and we were instructed to clean that slit well - which we did - and the line went away, but not its back!
    I was told, way back in the day, to use alcohol wipes to clean the rollers and that is what I used. I also used a can of Glass Cleaner (the foaming stuff) to clean the top and bottom of the glass and slit, not Windex
    I just did the blank suggestion and I still get the line. My boss wanted me to take out the slit, so I just did and holding the slit of glass to the light - you can see this faint, almost like a buffed line run right up thru the middle of the glass piece! Would this cause my lines? I did not notice this before - and it looks like the back a CD that has been tossed around...but it is right in the middle of the glass and very faint. You have to tilt the piece just right, like a hologram, to see the scratch. What do I do now?!!
    OMG! How do I rank you up for help?!! I did your newest suggestion - basically feed it thru the doc feeder landscape and auto adjust the image to print portrait; not exaclty what you said to do but thats what I did to the machine - and NO LINE!! Well, there is, but now it is along the side of the paper but NOT interferring with any of the information we were needing to copy!
    I will CERTAINLY take your advice about taking that to a glass shop - we happen to have one of those right behind our shop. I am sure the manual for our machine would let us know if there are any sensor's in the glass, right? I can look and see NO wires attached but I have no idea bout the sensor's. Thank you SO much for all your help!! I am sure my employee's can deal til we get a new slit piece.
    Do you happen to know if I can contact Sharp for that part - or order it online versus going to a glass shop? Again, THANK YOU so much for all the help. I will surely use this site again for ANY problems that I have with our office machines. THANK YOU!!
  • brian c
    brian c May 11, 2010
    At this point there isn't much you can do besides replace the glass. The "hazing" is causes by the constant "buffing" action of the paper rubbing on it.
    It will cause the lines because the original is only "rolled" over the slit glass, as opposed to the old style copiers that transported the entire original onto the large glass.
    If you're absolutely sure it only happens through the feeder, there IS one option..
    Change the letter trays to "letter r" (long ways) configuration, and put the originals in long ways, that way the scratch isn't in the scanning area. This may take some time to teach the office staff the new orientation, but you won't have to buy a new slit glass.
    PS: If the glass doesn't use any wires (some have sensors attached), you can take it to a glass shop and have one made relatively cheap. Just make sure it's the correct thickness.
  • brian c
    If the scratch appears to be on the underside of the glass, is is possible this has happened before and the tech (?) rotated the glass once already?
    Keep i mind, that if the line is on the front side of the copy, then the culprit is towards the rear.
    Example: Run a blank sheet through the feeder. Then take the copy and rotate it so the line is on top. Line it up on the scale plate. Look in the corresponding area on the slit glass, and also on the reflector plate near the exposure lamp.
    What are you using to clean it?
    If it's an ink blob, windex will NOT take it off no matter how hard you rub! Use rubbing alcohol.
  • brian c
    Glad to see that you have troubleshot it down to the slit glass.
    Is there a possibility the slit glass is scratched from a staple being dragged over it?
    Is the line thin, or thick?
    Use a really bright flashlight, it may be something on the underside of the glass.
    It doesn't take much to cause a line.
  • 589 Answers
Ah, the beauty of digital manipulation :)
In the old days you would have to change the paper in the tray too...
I've been looking online for the glass, and can't locate it. They will charge you a bundle for a piece of glass anyway (I know Konica charges about $50 one).
As to the question of a sensor. If there's no wire on it, there's no sensor. Some manufacturers use a "coating" that goes to a ground wire for anti-static, etc. Most likely, yours doesn't require this.
Also, to prolong the life of the new glass (now don't tell ALL of my secrets) use armor-all, car wax, even pledge (the wood stuff) on a rag and buff the glass. Just a dab will do.
I'll keep looking online for the part for ya.
Posted on Feb 15, 2008
I am getting a black line on scanned documents of my HP Officejet 6310 All-in-One Thanks
It would require you to open scanner and clean scanning head unfortunately.
Aug 02, 2015 | HP Office Equipment & Supplies
Black line vertical while scan and photocopy a document
does it happen when you put it on the glass or only thru the document feeder? if only when you use the doc feeder then it is something on the slit glass the small piece of glass about an inch wide next to the big sheet of glass. some times ink from a pen od dirt gets baked on the slit glass. it can be hard to get off but if you look closly then you can see it and clean it off.
Feb 20, 2015 | Samsung SCX Office Equipment & Supplies
Why do my copies have black lines down the paper?
if its just copies clean the small glass to the left of the large glass its called the slit glass and is usally about 12 inches long and 2 inches wide if it comes out on prints as well as copies its a drum or fuser check to see which is bad another way to test if its the slit glass make a copie from the large glass if no line its definatly the sit glass
May 27, 2014 | Kyocera Epson Workforce Pro Wp-4530 Wp4530...
Black cq when using document feeder
clean the slit glass its the small maybe two inch wide glass to the left of the main glass clean it good use windex or alcohol that will get rid of you problem have a great day
Apr 18, 2014 | Kyocera KM-1505 Copier
Lines on documents
when using the document feeder??? if so then place a document on the big glass and make a copy if the line goes away clean the small slit glass to the left of the big glass that glass is what the doc feeder uses
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 11, 2014 | Konica Minolta bizhub C250 All-In-One...
BLACK MARK ON THE COPIES OR SCANNED IMAGE
Clean the slit glass under the document feeder. Lift the feeder and find the thin piece of glass on either the left or right side and give it a good cleaning - you marks will likely go away.
Here is a how-to for removing lines from Sharp copiers.
How To Remove Lines from copies prints on Sharp copier
Jan 17, 2014 | Sharp Mx-C402sc mx-C402sc
Cc 2550 when making copies using document
You need to clean or change the charger unit, if you open front cover you will see green unit going inside the drum, you can take it out and clean or if it is too bad change it.
Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Aug 21, 2013 | Copystar Cs2550 Copier
Black lines down on printed page
This is caused by dirt/debrise on the ADF (automatic document feeder) scanner glass. You need to open up the feeder where your originals are fed in and look for a strip of glass that runs from front to back. It is about an inch or so wide. You need to clean this glass to get rid of the lines. Some models have this glass just to the left of the large main glass, but in your case I beleive it is in the feeder itself.
Good Luck.
Apr 23, 2010 | Brother MFC-7820N Printer
Samsung sf 330
If you open up the feeder door (Where your originals feed into) you will see a slit of glass going from side to side by the feed rollers. (you might need a flashlight to see it better)
On the slit glass there is probably some white out or something on the glass. All you have to do is clean the glass and this should take care of your problem.
To help you zero in on where the marks might be located, make a copy of a white piece of paper through the fax machine.
And then line up the copy that comes out with your black marks to the feeder.
This should get you in the general location.
If you have any other questions, feel free to post another question.
If I have helped you, please post a feedback and a rating.
Have a good day.
Good luck.
Mac
Feb 23, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Sharp AR-M277 All-In-One Printer Logo
872 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
