Question about Whirlpool GEW9250 Electric Dryer
Whirlpool Duet GEW9250 Dryer; Only Running in Delicate Cycle
Paid for advice here by "experts"; told by several to replace the "control panel"; did so and the problem persists. All the other controls on the unit seem to work, except the dial in center that allows you to choose the cycle (as the dryer only functions in the "delicate" cycle, the temperature setting stays on extra low only). HELP!
  • 1 more comment
  • ARRGGH Feb 15, 2008
    In the mean time, I took the control panel off the front of the dryer and found that the cycle selection knob has a thin plastic pin on the backside of it that has apparently snapped in half (very poor design; thinner than a toothpick!). Now just have to see if I can replace just that switch or the entire panel.
  • LThalleen May 15, 2008
    We have the same problem, too, with our GEW 9250, dryer. We tried taking the control panel off of the dryer, but it would not come off for some reason. It was in the control locked position and now the time does not show up or anything and we finally got it off the locked position but it won't do anything although we see red lights on two cycles. I am very frustrated considering we only had this for less than 2 1/2 years and now we have to pay for the repairs on something that we could probably fix if we could get into it without breaking it even more. It worked just fine a few days ago so I am really upset about it. I definitely won't recommend this product to anyone considering we have had problems with the dryer overheating in the past when it was set on the sensor control.
  • vbprgmr Jun 13, 2008
    The EXACT thing has happend to our dryer how can I reslove this without paying tons of cash. I have 4 children and zero extras when it comes to paying for repairs or purchasing a new one. Up until now I have LOVED this dryer!
    President:
  • 1,314 Answers
Im going to try to help you for free did you not get the tech sheet when you changed out the control board
Posted on Feb 15, 2008
Control locked light is on. Have replaced control board but control still locked
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Hopefully, this simple advice will save you an expensive service call.
May 28, 2015 | Whirlpool GEW9250 Electric Dryer
that knob is actually a switch. fixing it will be much easier, if you replace the whole switch unit..
good luck..
Jan 29, 2008 | Whirlpool GEW9250 Electric Dryer
My Whirlpool Duet dryer has the "Control Locked"
Hi
To unlock it press the END OF CYCLE SIGNAL button for 15 seconds and the unit will reset.
Dec 31, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer, dryer gets to hot, even on delicate cycle, clothes to hot to touch
may be the heat sensor(around 10Kohm) or the heater relay on the control stuck in the on position.(new control)
Oct 29, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer is stuck on control lock mode. Have tried pressing the end of cycle button for several seconds and control lock button stays on....dryer won't run.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#!#!
Jun 27, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet gew9250 - Control Lock
The most common reason for this type of complaint would be a failure in the user interface board (UI), if the portion of the board has a short circuit across the lock trails it will demonstrate this symptom.
The fix would be to have the UI replaced. Part number is
8558753 Platinum
8558755 Biscuit
8558756 Pewter
The cost for the part alone is around $160.00 plus labor to install.
I know this is not good news. sorry....
Apr 18, 2010 | Whirlpool GEW9250 Electric Dryer
Control locked on my duet dryer
Press and hold the end of the cycle button for 10 seconds and the control panel will unlock
Sep 13, 2009 | Whirlpool GEW9250 Electric Dryer
How do you get the control lock off? my dryer will not start
TO DISABLE: Press and hold the END OF CYCLE SIGNAL button for
3 seconds.
When the dryer is running and Control Locked is on, the
dryer can be stopped by pressing the Pause/Cancel button, but
can’t be restarted until the control is unlocked.
The manual can be found here.
Jul 07, 2009 | Whirlpool GEW9250 Electric Dryer
more than likely a short in the user interface
Jan 28, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet ggw9250pl1
On Duet models, Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Locked feature.
Jan 02, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
180 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
