Question about Whirlpool LER8648P Electric Dryer
Whirlpool dryer does not heat
Does not heat when it is running. I have replaced circuit breaker and measured the power coming into the dryer, it is adequate, replaced heating element, thermal fuse, 2 thermostats no luck so far.
Check the lint hose could be cloged air need to flow through it to dry if stopped up want dry and can cause a fire
Posted on Feb 16, 2008
Whirlpool Imperial Electric Dryer wont heat up
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 22, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My whirlpool duet front loading dryer does not have heat
2. Heating element
3. Thermal fuse
Jul 09, 2009 | Whirlpool Dryers
Dryer tumbling but no heat....
2. Heating element
3. Thermal fuse
Jul 08, 2009 | Whirlpool LER5636P Electric Dryer
Dryer is not heating
Check the following.
2. Heating element
3. Thermal fuse
Jun 25, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool GEW9868K Electric is not heating up not drying the clothes
2. Heating element
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting....
Jun 24, 2009 | Whirlpool GEW9868K Electric Dryer
Won't heat
2. Heating element
3. Thermal fuse
Jun 20, 2009 | Whirlpool GEW9200L Electric Dryer
The dryer works but no heat.
2. Heating element
3. Thermal fuse
Jun 18, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool electric dryer that will not heat up, dryer comes on and turns, but no heat
2. Heating element
3. Thermal fuse
Jun 18, 2009 | Whirlpool Dryers
Dryer running but not heating. How do I check heating element?
Check the following to address this non heating issue
2. Heating element
3. Thermal fuse
Jun 02, 2009 | Whirlpool Dryers
No hot air coming from the dryer
2. Heating element
3. Thermal fuse
May 07, 2009 | Whirlpool GEW9200L Electric Dryer
Whirlpool LER8648P Electric Dryer Logo
99 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
