Question about RCA F27242GY 27" TV
Turning rca tv to video
I have a RCA RCU300 Remote Control and i can't get my tcv to turn to the video channel i have a front and back place to hook up my dvd player or ps2 i need help,please and i am not sure what style
    Scholar:
  • 133 Answers
First did you try all the codes. Some codes do not activate that function to work with the TV. Second what type of TV is it . If it is a combination tv - vcr - dvd these are the hardest to get to work with a universal remote . good luck
Posted on Feb 28, 2008
Need maganovx code for rca remote
005, 006, 013, 046, 053, 055, 057, 058, 077, 089, 094. These are the codes for Magnavox TV, with RCA RCU300 remote control.
Sep 21, 2012 | RCA RCU300WBL Remote Control
I need code for insignia dvd-vcr combo to go with my rca rcu300 remote control
In the manual there is not insignia dvd or vcr code but you can search for it using the remote.
If your TV, VCR, DVD, or Cable Box does not respond after you have tried all the codes for your brand, or if your brand is not listed, try searching for your code by following the steps below
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH until the INDICATOR LIGHT lights, then release CODE SEARCH.
3. Press and release the device button for the device you are programming (TV, VCR/DVD or DBS/CABLE). The INDICATOR LIGHT will blink once then remain lit.
4. Press and release OFF/ON until your device turns off. Important: You may have to press OFF/ON up to 200 times. 5. When your device turns off, press the ENTER button, the INDICATOR LIGHT will go off.
http://support.radioshack.com/support_video/doc67/67859.pdf
May 05, 2011 | RCA RCU300 Remote Control
Need codes for programing my RCA Systemlink 3 remote control to a Sanyo tv
Hello Barbara370,
Here is a link for youl.
http://www.universal-remote.net/rca.html
Hope this helps you out.
Cheers Little Dish Fitter
Nov 12, 2009 | RCA RCU300 Remote Control
Auxillary channel for dvd
You need to determine what output options your DVD player has. Take a look at the rear of the player. It will certainly have RCA jacks for video and audio outputs (yellow for video, red and white for right and left channel audio). It may also have RCA jacks for component video (marked Y, Pb and Pr). Finally, it may have a threaded connector marked "out to TV" or "antenna out" or something similar. This is called RF output.
Most players today don't offer RF output because nearly every TV has direct AV inputs available. If your DVD player has RF output, connect the output connector to the TVs antenna input. You need a coaxial cable with F-connectors on the ends. One may have been supplied with the player. RF output is on channel 3 or 4, set by a switch on the back of the player or by its on-screen setup. Just set the TV to that channel to watch a DVD.
If your player doesn't have RF output, you connect it to the TV using the AV jacks. You need cables with RCA plugs to to connect the video and audio from the player to the TV. Then you switch the TV to its video input to watch the DVD.
This is where you might run into problems. Many TVs need the original remote control to switch inputs. (Some older RCA sets used channels 90, 91 and 92 to switch to their video inputs so any remote would work, but these sets were made before 125-channel tuning became standard. If your set is one of those models, those are the auxiliary channels you heard about.) If you can't switch the set to video input with front panel buttons and you don't have the right remote, you're not completely out of luck.
If you can't use your set's AV inputs or it just doesn't have any, you need an RF converter. These cost around $15. They take the audio and video from the DVD player and convert it to channel 3 or 4. Then you hook that output to your TV as described above.
May 17, 2009 | RCA Universal Remote Control
I have rcu300 remote control need code sv2000 tv
hit the code search button, hold dpwn until light remains lite, then press and release the componet key that you want the remote to operate, then aim remote at the compont, and press the on off key once, keep remote aimed at the tv until it turns off, may take awile, as soon as it urns off, hit the enter button, within 3 seconds, and it will store the code to remote, goodluck
Dec 28, 2008 | RCA RCU300WBL Remote Control
RCA F25645 25in TV.
I have this same TV. The DVD player is either hooked up to the video or s-video input. Go to the Menu (either through the remote or from the front of the TV) and select the Setup option. Go to the part where it asks if you want to use a DVD player. Select yes. Then select Video Input. Exit the Setup. When you hit the DVD button, it will switch to the Video input. The second step is to go into the Menu and select Channel, then go to Video Input Source. From there, select which input you are using for your DVD player, the S-Video or the standard Video (yellow composite cable).
Mar 06, 2008 | RCA F25645 25" TV
Remote control
Can't help with the HD receiver if the code search function didn't find a match. However on the second post, you can find codes for the RCA Universal Remotes at http://www.thompsontv.com/rcarc.html
Nov 30, 2007 | RCA RCU300 Remote Control
I have an emerson tv and a GE universal remote
as this was posted to the rca rcu300 remote location and not in a ge section, i am undure of what model your remote is. that being said, you can find a list of all codes the ge remotes support and how to program them by clicking here.
i hope this helps, if not, please post the model of the remote control, and the emerson dvd/tv combo.
hope this helps,
trin
Nov 16, 2007 | RCA RCU300 Remote Control
RCA F27242GY 27" TV Logo
69 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
