Question about Sony DHG-HDD250 200-Hours Video Recorder
Guide listings are incomplete
My guide does not show all of the channels from my local cable company. I have allowed the box to rescan, but it still leaves out some of the HD channels such as Disc HD and Science HD which are on channels 720 and 721.
  • ryeman0127 Feb 22, 2009
    I have the same problem. I'm using Cablecard (M-Card) on my Pioneer Kuro and while I can manually (ch up/dn) pick up all the channels, the TVGOS is just incomplete in its listings.
1. Manually scan all channels on your TV with your TV remote and write down the channels and network shown:
(sample: 119.2 C-SPAN2 digital channel).
2. Go to Edit Channels and find the icon for C-SPAN2 (about icon 261 in my zip code). Manually change the channel from Off to On, Insert the frequency, and optionally insert the number you want the channel to show in your channel listing ( or move it manually later).
I have about 10 to add each time I reset my recorder.
Posted on Jun 16, 2009
  • dskl Jun 16, 2009
    CORRECTION: Use the DVR remote ,not TV remote, to manually scan digital channels in step 1 above.
Hi there , my YouView tv guide in not working, when pressing the button it access the guide but does not load the channels and it does not scroll . Is there anything i need to do to make it work again
Did you do the retune on Sept 3rd? If not, you need to do a Full Factory Reset tuning rather than just a rescan.
Rescan simply looks at the place holders where the old channels were stored and refreshes them. A Factory Reset (A.K.A. Shipping Condition) wipes the channel memories and starts again fresh.
The channels carring the EPG may have moved from where the YouView box is expecting them. Try the Factory Rescan
Sep 08, 2014 | Televison & Video
RCA F36715 36" TV received this tv used from a friend. we do not have original remote so we use a generic universal remote. tv works fine, but we cannot get the Guide Plus+ to work. we went through the...
You're cable company may have quit using TV Guide info from "TV Guide", because they want you to get their box for this info, or to save expense. It happened here in Michigan about a year ago. If you have local ABC, NBC, and PBS stations, you can get this info downloaded nightly through an external "over-the-air" antenna.-- assuming you're in the U.S.
May 05, 2010 | RCA F36715 36" TV
I switched to basic cable & my digital tv is getting many digital channels, ie, 108.3, 108.4. Where can I find a guide telling what's on those channels & what station are they?
Your cable company provides digital channels on your cable service. They place those channels as they see fit. Get the list from the cable company.
Mar 22, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Panasonic DVR, loss of TV Guide on-screen program listings
In our case, Time Warner has dropped the channel TV Guide, it used to be channel 99, but it's not even offered any longer, so it would appear that unless this TV guide info/source is fed to the DMR - DVD by some other method, rather than having to have that specific tv channel, I think we are S. O. L.
Mar 25, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
Rca tv my guide plus has quit working
The guide plus needs to reset itself over night. But as long as you are only connected to cable it will not allow for it to reset. You need a two way splitter the cable company signal will go in one side and the outside antenna or what ever you were connected to before cable will go on the other connector. The single side connector will go to the tv. Where the splitter says 'in' you will actually be using it as out to the tv. Where the splitter says 'out' you will be using as in for the cable and the other antenna. Guide Plus is built into your tv and needs the tv to be off to reset over night.
Jan 28, 2009 | RCA P61960 61" Rear Projection Television
TV Guide System not working
In order to receive the TV's Guide system, the cable should be connected directly to the TV instead of the cable box if you are still using it.
How do you have the cable box connected to the TV?
Jan 24, 2009 | Pioneer PDP-5060HD 50 in. Plasma...
Not receiving guide plus + tv listing -no problem until 2 weeks
I called TimeWarner Cable tech support, and the solution is to unplug the power to the box, after 1 min plug back in, let the box reboot, and PRESTO, this time around, the guide should be working.
Note--this is a solution for the problem of online guide that is showing No Data in the boxes, but is bringing up the grid of times/channels/date.
If you can't get the Guide at all, I don't know if this solution works.
Good luck.
Dec 16, 2008 | Televison & Video
How to use EPG
EPG or Electronic Programme Guide is the on-screen version of a tv guide for digital tv. The remote control usually has a dedicated button for the display of the EPG.
The information displayed is often incomplete and some digital boxes or tv sets perform better than others though in theory it needs no setting up. Once the box has searched and made a channel list the programme guide will be available.
Nov 17, 2017 | Pinnacle Televison & Video
Hooking actual live coaxial from Cable Co. to Insignia Converter Box ...
Based on the specs that I have read I am going to say you cannot hook up cable to the converter. Best thing to do would be to call cable company that provides service there and see if it was turned off on the billing side they probably just didn't come out and disconnect from the pole. That might give you service but missing some features such as tv guide channel. Now some tv's have tv guide built into them and maybe in the move that feature on the tv was turned off it they were using it that way before. Here is what the specs say about that converter:
Use this digital-to-analog converter to convert digital TV broadcast signals to analog signals on analog TVs with antenna-based reception.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 08, 2008 | Insignia Digital-to-Analog Converter for...
Recorder is not showing tv listings
I spoke with Toshiba tech support today (800-631-3811). They have an advanced services team that focuses on TV Guide On Screen. Learned the following:
- The TV Guide On Screen signal is updated 4x / day and is broadcast by your service provider
- The broadcast channel varies depending on what the service provider chooses (though typically a major network or PBS station)
- TV Guide On Screen has been doing some reprogramming and updates recently and this has resulted in many sporadic outages
If you ARE not receiving your listings, it's one of two things - either your DVR or the signal from the cable company.
- If you are having issues, call Toshiba and let them know, they will walk through some basic troubleshooting to narrow down if the problem is the DVR or the TV Guide On Screen signal.
- If the issue is the TV Guide On Screen signal, they will be able to report the issue to TV Guide On Screen and let them know their is an issue.
After that - it's in someone else's hands!
Feb 05, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Sony DHG-HDD250 200-Hours Video Recorder Logo
379 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
