Question about NEC MultiSync MT1050 Multimedia Projector
It's on, then it's off
My MT1050 turns on, displays picture, then about 2 minutes it shuts off. Status light blinks red for approx. 6 seconds and power light is steady orange. The manual only offers a 4 second and 8 second solution. Can someone tell me what might be wrong? Thanks
  • 4 more comments
  • dna11207 Feb 15, 2008
    The fan is running, the vents are not obstructed, and the filters are all clean. Once it goes throught the shut down and the fan turns off, it will turn right back on again. Any other thoughts?
    Do you know if this is repairable? Also, I have searched hi and low for a repair manual for this unit and have had no luck. Thank you again.
  • dna11207 Feb 16, 2008
    Does someone know where the thermal cutout is located in this unit? Should it have gone bad in only 748hrs of use?
    I bypassed the thermal cutout and it is still doing the same thing. Does anyone have any other ideas? Thank you again.
    We have a 'new' symptom the projector will stay on and running with no problems if it is sitting on it's back.
  • dna11207 Feb 17, 2008
    Well, I am going to assume that you are right that there was or is something loose that the pressure of having it on its back or upside down (which we hadn't tried till late last night) is reconnecting or what have you.... needless to say it is working just fine now thankfully, it was becoming a little aggravating to say the least.... thank you so much for your input we do appreciate it, now if we could just get a remote for it that don't cost $200 we would be good to go.
    President:
  • 2,072 Answers
Is the fan running properly or are any vents blocked?
Sounds like it is overheating.
Posted on Feb 15, 2008
  • Rick Kasper Feb 15, 2008
    Might just be that the thermal cutout is going bad inside the unit. Shutting off at to low a temperature.
    Sounds like the most likely cause. They do change properities as they get older.
  • Rick Kasper Feb 16, 2008
    That last line you put there has me totally baffled.
    I honestly have been thinking about it all day and running fine
    sitting on its back.
    Other then disconnecting and reconnecting plugs and connectors, and possibly turning it on it's back is reconnecting a broken or cold solder connection, I honestly don't know.
    Actually, when I got that message on my blackberry I had to laugh.
    A bad connection, where laying it on its back puts enough pressure on is the only thing that makes any sense now.
    You sure are persistent I have to admit.
    Wish I could give you a better answer.
Magnavox error codes
check this
The Service Default Mode (SDM) is a technical aid that can be used to display the your TV error code.
Follow these instrutions exactly to place your set in SDM Mode.
For sets that still have video do the following.
  1. Turn your TV on
  2. Using the original Philips TV remote press the following keys. Press each key for 1 sec then press the next.
  3. From the remote press 0 6 2 5 9 6 MENU
  4. You should now see the letters "SDM" in the far right hand corner.
  5. If not do step "3' again.
  6. To display the error code hit the "Status" button on your remote.
  7. The TV can store up to "7" past errors.
For sets that have no video do the following.
  1. Turn your TV on
  4. Wait a few seconds. The red power light should begin to blink.
  5. The blinking sequence will determine the error code.
  6. You will have one long 5 second red blink followed by the error code.
Note: On some sets the TV will automaticaly blink the error code when its powered up without having to go into the SDM menu. If you power light blinks after the set is powered up jot down the sequence.
Example Error Codes from the power light.
( RED 5 Seconds ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 3
Example #2
( RED 5 Seconds ) off ( RED 1 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 12
(Note:) Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
Jul 04, 2014 | Televison & Video
What does it means of 6 seconds red light interval of my NEC MT1050 projector,and how will I fix it to come back to life?
Holding down the "OFF" key on the remote control for 30 seconds
to reset the lamp timer
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jun 13, 2014 | NEC MT850, MT1050, MT1055, MT1056...
Red status light is on but not blinking and picture wont show at all???
access the self diagnosis feature by pressing the menu and device/input buttons on the tv both together and hold them for 6 seconds then counr the teo digit blink code.
Mar 11, 2013 | Mitsubishi WD-62725 62" Rear Projection...
Status light is blinking red, power button orange nec vt700
Hello
Look at the number of blinks of the status light.
[1] If it blinks at one cycle (0.5seconds On and 2.5seconds OFF) : Lamp cover error or lamp housing error. Replace the lamp cover or lamp housing correctly.
[2] If it blinks 2 cycles (0.5 seconds ON and 0.5 seconds OFF): Temperature error. The projector is overheated. Move the projector to a cooler position.
[3] if it blinks at 4 cycles (0.5 seconds ON and 0.5 seconds OFF): Fan error. Fans sill not work correctly.
[4] If it bliks at 6 cycles (0.5 seconds ON and 0.5 seconds OFF): Lamp fails to light. Wait a full minute and then turn on again.
[5] If it blinks continous (Red): Lamp has reached the end of its life. Lamp replacement messege will be displayed. Replace Lamp with same type and number. After replacement reset lamp hour. OK.
Sep 10, 2011 | NEC VT700 Projector
Turned tv on 2night had picture and sound for approx 3 minutes then tv turned itself off had 2 flashing red lights turned tv back on no picture or sound then turned itself off again
B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Mar 16, 2011 | Sony Televison & Video
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
MT 1050 Lights, goes out then Status light error
I have the same issue with mine. Did you ever find a solution? Thanks!
Sep 17, 2009 | NEC MultiSync MT1050 Multimedia Projector
LG 52SX4D turns off randomly.
My Lg 52"tv turn off and on
Apr 29, 2009 | Televison & Video
NEC MultiSync MT1050 Multimedia Projector Logo
361 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
