Question about Magellan MAESTRO 3100 98083401 GPS Device
Maestro 3100 will not talk/ or give instruction when you drive
  • 1 more comment
  • Grampsfor 13 Feb 23, 2008
    I have been usibg the unit for several months, Twice, the sound just stopped then a couple ofweeks later it came back on. Now it has lost the sound again and try as I may, I can't get it back. Where oh where dis it go?
  • JCTap May 20, 2008
    My Maestro 3100 would have no audio anytime I turned the unit on.
    I had to hit the reset button recessed on left side of the unit with a paper clip or the tip of a pin to get it to work.
    now it just does not work at all.
    I'm thinking that something is wrong with the plug for the earpiece.
    Help ! how can I get this feature to work again.
    This is actually the most important thing about it.
  • dbh21245 Jun 08, 2008
    Received the Maestro 3100 as a gift and followed the instruction for software update (recommended) the only problem is the there is no sound now and can not get it back on. Have contacted the manufacturer with " yes it's a problem but we don't have a solution". If you know there is a problem and don't know how to fix it, why put the product on the market. Sure would stop me from ever considering your products again and will certainly spread the word to others to avoid this product.
    dbh21245
Hello i just just finish fixing the external speaker problem the problem seems to be the earpiece hole the unit thinks that u have and ear peace plug in so here the solution:
1 get a hold of some headphones 2 turn the magellan on and into the main screen. 3 plug the headphones in the unit press right arrow and left arrow and listen for sound 4 un-plug half way wiggle insert and remove repeat, 5 un-plug and blow into earpiece hole 6 check for sound
i did it for about 1 min and it work for me i hope this helps some one enjoy!
Posted on May 24, 2009
  • 61 Answers
Check the audio out port..A faulty port can result in the on board speaker cutting out or muting out. try connectting an external speaker jack into the audio out port and slightly wiggle it.
I do not recommend but open up the unit and check for dry solder at the speaker end
If all ok, it might be a faulty speaker coil. replace with similar impedence
Posted on Feb 28, 2008
I dropped my magellan "maestro 3100", now it will
hi elizalde_cl
start your 3100, then get a paper clip and depress the reset on the left side near the bottom of your 3100 to reset it and let it restart. that should fix it, but if it doesnt, let me know and ill tell you what to do next.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Dec 02, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
My magellan maestro 3100 screen says Venus0 UT R06?
you have what is refered to as BRICKED YOUR UNIT! this is not for the faint at heart to repair as it involves alot of moving, coping and pasting files but im going to give you a link that you can follow to restore you unit. 1st i must say that if this occurred after you updated the 3100, magellen will repair or replace any unit that was renedered inoperable after their update. i suggest you call them if that is the case.
Hours: Monday through Friday, 6:00 a.m. to 5:00 p.m. PST/PDT
Telephone: 800 707 9971
the below link will instruct you as to how to restore your unit if magellan is no help.
GpsPasSion Forums
please let me know if this was helpful or you need further help...bill
Jul 14, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 frozen on blue screen tried power on and off and reset button still frozen black bar at bottom of scren stays on blue screen
i just replied to a fellow with the same problem and since your problem is same, ill post what i wrote him/her but try a hard reset 1st..turn the gps on then locate the little pin hole on the side, using a paper clip, push reset....if that fails, try the 2.18 update if you havent already.
updates for any magellan can be found HERE
but read below first before getting the update
i cant stress enough that patients is a must here. this update is huge 1.75GB
follow the instructions below whether you have updated your gps already or not!
There are few ways to solve this problem. i assume you installed the 2.18 update for the 3100 and assuming you tried the reset already, try and run the update again and follow the directions to the letter..make sure the battery is fully charged (i also keep mine plugged in if the update doesnt say not to) and do not try and run the update across a network. this update is huge 1.75GB and can take an hour or so depending on the computer..do not interrupt the update process. if you do not have the 2.18 update read me file, i can try and post it here, but its in PDF and dont think i can post that
if all else fails, magellan will fix or replace for free any of there gps that were rendered inoperable due to one of there updates.
either solution will work but magellans going to tell you to run the update again anyway before sending it back.
i gave you the 2 easyest ways to fix it,but
there are other ways to get it running again, but if your not comfortable copying and moving files...youll make it even worst then it is.
hope this helps.
bill
Comments: Jul 19, 2009 - here are a few key points, but read the full update guide before trying the update again.
hope this helps
NOTE: This update is COMPATIBLE ONLY with Windows® XP.
Before Beginning:
Check to make sure you have everything required for updating your unit:
• Magellan Maestro 3100 GPS
• PC running Windows XP
• A Blank SD memory card (16 MB to 2GB)
• USB cable
• Paper clip or similar object (for resetting your unit)
EACH OF THE FOLLOWING POINTS IS CRITICAL TO THE UPDATE PROCESS
1) The battery of your Maestro 3100 must be fully charged before beginning the update.
NOTE: It takes between 3 and 4 hours to fully charge the battery with your vehicle power adapter. Check System Settings to ensure the battery is fully charged.
2) Your Address Book will be erased during the process. Please back up your data to an SD memory card.
a. Insert a blank SD memory card
b. Select User Options
c. Select Backup and Restore
d. Select Yes to confirm
3) Do not connect your Maestro 3100 to your PC until instructed to do so by the Update Wizard.
4) Close all other applications while performing the update.
5) Disconnect all Pocket PC devices from the USB ports on your PC.
6) Insert a blank SD card (16 MB to 2GB) into your Maestro 3100.
7) Perform a hard reset on your Maestro 3100 by pressing a paper clip or similar object into the hole marked reset.
Update Process:
1) Launch the Magellan_Maestro_3100_2_18.exe file.
2) Select Next on the Welcome screen.
3) Turn on your Magellan Maestro and connect the USB cable.
Magellan maestro screen not coming on
if you have a 3100 or 3140 as you have pictured..they cant be charged via USB..you need a home or car charger
May 10, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Need instruction guide
hi!get it here:
http://www.retrevo.com/support/Magellan-3100-GPS-manual/id/2946ag211/t/2/
u might have to make a free registration..if its not working then please look from the retrevo.com website
regards!
Nov 10, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 failed update
go to Tech support at www.magellamgps.com tell them what has transpired and ask for 2.18 Update Recovery Files. This fixed my problem. Took a few email exchanges but I thought the responses were very quick.
Oct 04, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan GPS
Online at Magellan website you can update your magellan maestro 3100
Mar 25, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 3100 stuck on
If you followed the procedure closely, you now have an SD card with your backup on it. The backup consists of two folders: BACKUP, and USBTRANS. Insert the backup SD card in your PC's reader slot and open a "file explorer" aka "Windows Explorer", not to be confused with "Internet Explorer". You will use Windows Explorer to click and drag the USBRANS folder to the Maestro.
With the Maestro 3100 connected to the PC, a couple of Explorer folders will open and you can see the file structure for the GPS in 1, and in the other one a separate file structure for the blank SD card needed for the update. Look at the file structure for the GPS and you should see a handful of folders including "SYS".
  • Start the upgrade program, following the procedures.
  • Click the NEXT button at the bottom of the procedures screen.
  • Immediately copy the backed up USBTRANS folder (and all contents) to the SYS folder on the GPS.
  • The update should now find the Maestro 3100 and proceed with the update.
SUMMARY: copy USBTRANS (it should contain 1 file: UNIT.DAT)
  • from your BACKUP SD card (not the one in the Maestro)
  • to your Maestro 3100's SYS folder.
Feb 25, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 3100 locks
You can try a hard reset. Hold in the reset button (left side of unit, use a pin or toothpick), while turning on the unit. If you don't get the blue Magellan screen, you'll have to try again. If you get a screen with a blue background and a menu, turn it off and try again.
So far, this has fixed:
1. unit won't go on
2. unit reboots when routing
3. unit turns off after a few seconds
At least, it's fixed it for me. No idea why this happens, but it's pretty damn annoying. Give it a try.
Dec 26, 2007 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan MAESTRO 3100 98083401 GPS Device Logo
97 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
