Question about GNR F153A (Black/Silver) 15" LCD Monitor
Out of range
I can use my new 10m svga lead.
i get this message .
however it will work one i am in safe mode or the pc has been logged on.
    Problem Solver:
  • 11 Answers
Maybe you have to boot your pc to enable vga mode and adjust the resolution to a smaller screen resolution...........
Posted on Feb 16, 2008
My Hp compaq PC showing problem about HDD - Disk Read Error . But This HDD was run very good to another PC ?
Test all leads that attach to your hard drive power and data cables IDE SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty Make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty. Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error. Even something as small as a faulty electrical or fan lead can cause you problems Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail. b> 1: Download a disk read error repair tool,install this error repair tool.
2: Open disk read error repair tool and scan you computer for free
3: Then click the Repair All Button again and your done! It is very easy to repair disk read error.
Here are the url of disk read error repair tool:http://www.RepairErrorInstantly.com/ttfi... or rather than doing this try the alternative which is windows own repair Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice Select safe mode with networking to download http://www.RepairErrorInstantly.com/ttfi... Then restart again into safe mode with command prompt. Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer Hope this helps. b>
Jan 05, 2013 | HP Compaq dc7700 PC Desktop
When I turn on my emachines t3265 desktop computer, it freezes at the logo, and does not proceed to Windows so I can log on. What is the likely problem, and how can I fix it?
Turn it on.
Hit the ESCAPE (or TAB) key to replace that colourful logo with the technical details of the computer's POST (Power On Self Test) messages. Look for any messages, such as "unable to boot from disk drive" or "disk-drive not detected". Also, remove any CD/DVD media from the CD/DVD drive. Also, remove any 3.5-inch diskette, and disconnect any USB memory-sticks BEFORE you turn it on.
Jul 18, 2011 | E-Machines T3265 PC Desktop
Forgot my user password
log on as safe mode
press f5 at first screen then chose safe mode use arrow key and enter, you will sign in as safe mode, log on to administrator user, usually administrator not use password
after log on go to control panel=> user account=>double click at your account usually you use, click change password then insert new password it will change your password account or remove password, turn off your computer then log on to normal mode and use your new password to log on to your user account
i hope this helpful
thank you forusing fixya
Feb 05, 2011 | Sony VPCX135KX/N VAIO Notebook PC
How to fix blue screen when trying to start computer
it will depend the error message. however; you can try this.
start you computer on safe mode. (i am telling you this will depend on error message)
to start you pc in safe mode hit F8 key simultaneously. when the windows pop up. with you down arrow in you keyboard select. SAFE MODE only. (if you go trought your log in screen you will be lucky) . if so
log in as normal. click yes for safe mode question
(THE NEXT ADVICE IS ONLY IF SYSTEM RESTORE IS ON)
i recomend you if you can log in onto your pc in safe mode to do a System reestore. because the blue screen could be a bad driver or bad update that you recently did.
so to make an system restore follow this. To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as an administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
  3. On the Welcome to System Restore page, click to select the Restore my computer to an earlier time option, and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.2425657.png
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as an Administrator. Then click OK on the System Restore Restoration Complete
HOPE THIS HELP
Dec 17, 2010 | Samsung NC10-14GW Notebook
Windows XP HE on 505GR logon/logoff
it seems to be issue with windows. try logging the computer in safe mode , safe mode with networking then you have to copy mandatory profile to the current user logged in
Jan 04, 2010 | Gateway 505GR PC Desktop
Over rang message on monitor
restart ur pc in safe mode
and make resolution to lower settings it will solve your problem
first restart ur pc
press F8 key continuously
it will shows windows boot option from their select start windows in safe mode
after booting up pc
right click on desk top
go to setting
make resolution to 800X 600 and and colour quality to 4 bit or lower
then apply
save it
and restart pc and it will show your desktop normaly
just in case if it wont work
do the same in VGA mode start ur pc press F8 and from booting menu
select Start windows in VGA mode
then do the same as safe mode
and restart your pc
Nov 25, 2008 | Computers & Internet
Out of range
NO PC stated nor OS is it windows what or linux what or O/S2?
10meter . is way too long. sorry. never do that ....
10m means that. why say 10m?
lead = cable. VGA cable. it is.
VGA will not run 10meters ever, and look ok, (i do know how)
out of range means the PC is using ******* resolutions settings
on this old monitor. see list of legal resolutions below.
the answer is simple.. (NOT REALLY WITH NO PC OR OS STATED)
in your unstated PC and OS (windows)
we do what, (im blind cant see what you own)
if HP PC is get the correct driver from my PC, (GPU/VGA)
then it works.
if this pc is over 10 years old (last year made not first)
then there is no HP support.
if running XP or Vista, then Plug in play is not going to work on the dead. (MS shut this down)
so i run my scan program (pci dev maker scanner)
omg i see the video chip now, and its a XXXX
(geforce 123)
i got to nVidia and get it and it loads and works (ask how)
then in the nvidia driver i set the default resolution to
any of the BOLD max resolution's.
NO OTHERS ARE ALLOWED BUT THE BELOW OR IS OUT OF RANGE!
learn to that using a new PC using and old model
the New PC with NEW OS does not recognize this old model
its too old. now. so we must force it, in WINDOWs.
you must force your unstated video chop to the below resolutions
ranges. pick one and set it. there.
if running XP or Vista ,both are dead do PNP plug and play is dead, now. in most cases F8 safe boot , set it to say
1024x768 works then you reboot and it stays there.
but not if the driver for you VGA chip is missing or wrong.
means get it and load it now. in safe mode F8
is this pc connected to the internet as it must?
832 x 624 / 75 Hz
640 x 480 / 75 Hz
640 x 480 / 73 Hz
640 x 480 / 60 Hz
800 x 600 / 75 Hz
800 x 600 / 72 Hz
800 x 600 / 60 Hz
800 x 600 / 56 Hz
1024 x 768 / 75 Hz
1024 x 768 / 70 Hz
1024 x 768 / 60 Hz
1024 x 768 / 85 Hz
640 x 350 / 70 Hz
720 x 400 / 70 Hz
Aug 02, 2017 | Compaq TFT5015 15" LCD Monitor
SAFE MODE
Provide more description regarding your issue. Is there any error message when you try to boot without safe mode? Does the computer just boot to safe mode without asking you anything? Andy
Aug 27, 2007 | Compaq Presario 5000 PC Desktop
GNR F153A (Black/Silver) 15" LCD Monitor Logo
95 people viewed this question
Top GNR Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a GNR Computer and Internet Expert? Answer questions, earn points and help others
