Question about Compaq TFT5015 15" LCD Monitor
Out of range
I have put on a 10m svga lead to my monitor. when i start the pc up i can not get past the xp blue screen (log on). it get this far and then i get the out of range message.
when i am already logged on i can connect the 10m lead and everything works fine. i can also use the lead in safe mode.
anybody got any answers ?
i have tried changing the resolution and also the refresh rate 1
  • Compaq Master
  • 2,304 Answers
NO PC stated nor OS is it windows what or linux what or O/S2?
10meter . is way too long. sorry. never do that ....
10m means that. why say 10m?
lead = cable. VGA cable. it is.
VGA will not run 10meters ever, and look ok, (i do know how)
out of range means the PC is using ******* resolutions settings
on this old monitor. see list of legal resolutions below.
the answer is simple.. (NOT REALLY WITH NO PC OR OS STATED)
in your unstated PC and OS (windows)
we do what, (im blind cant see what you own)
if HP PC is get the correct driver from my PC, (GPU/VGA)
then it works.
if this pc is over 10 years old (last year made not first)
then there is no HP support.
if running XP or Vista, then Plug in play is not going to work on the dead. (MS shut this down)
so i run my scan program (pci dev maker scanner)
omg i see the video chip now, and its a XXXX
(geforce 123)
i got to nVidia and get it and it loads and works (ask how)
then in the nvidia driver i set the default resolution to
any of the BOLD max resolution's.
NO OTHERS ARE ALLOWED BUT THE BELOW OR IS OUT OF RANGE!
learn to that using a new PC using and old model
the New PC with NEW OS does not recognize this old model
its too old. now. so we must force it, in WINDOWs.
you must force your unstated video chop to the below resolutions
ranges. pick one and set it. there.
if running XP or Vista ,both are dead do PNP plug and play is dead, now. in most cases F8 safe boot , set it to say
1024x768 works then you reboot and it stays there.
but not if the driver for you VGA chip is missing or wrong.
means get it and load it now. in safe mode F8
is this pc connected to the internet as it must?
832 x 624 / 75 Hz
640 x 480 / 75 Hz
640 x 480 / 73 Hz
640 x 480 / 60 Hz
800 x 600 / 75 Hz
800 x 600 / 72 Hz
800 x 600 / 60 Hz
800 x 600 / 56 Hz
1024 x 768 / 75 Hz
1024 x 768 / 70 Hz
1024 x 768 / 60 Hz
1024 x 768 / 85 Hz
640 x 350 / 70 Hz
720 x 400 / 70 Hz
Posted on Aug 02, 2017
5 Suggested Answers
Rosley
  • 11 Answers
SOURCE: out of range
maybe you have to boot your pc to enable vga mode and adjust the resolution to a smaller screen resolution...........
Posted on Feb 16, 2008
ginko
  • 19396 Answers
SOURCE: flickering screen
Check cable first
Posted on May 21, 2008
SOURCE: EVO N600c starts up fine but when when its time to sign in nothing on screen just blank
Both of you, what did you do before the restart? If you changed anything while in Winblows it seems likely it is a software related issue. If you didn't, then a hardware issue is possible, in which case I'd start by unplugging the non-essential peripherals and restart. If that doesn't work, also try a different power supply and disconnect the battery. Sometimes a bad peripheral can cause the boot up sequence to hang. And correct me if I'm wrong, but I believe a weak psu can undersupply power to the harddrive causing the operating system to fail to boot. But, you probably have tried these ideas so they may not be of much help. Oh well, good luck!
Posted on Jul 22, 2008
kingpin27
  • 13 Answers
SOURCE: out of frequency range set low resolution or refer monitor manual
TO RESET IT START YOUR COMPUTER IN SAFE MODE AND GO TO DISPLY SEETTINGS SET YOUR MONITOR AT VERY LOW 32BIT 800 BY 600 PIXELS IT WILL SOLVE THE PROBLEM THAN RESTART THE COMPUTER
Posted on Feb 06, 2009
Screen has a yellow tint that I have not been able to get rid of.
Try this instead
change out the connector in the back of the computer, or the monitor cable (Replacement cable *see below) While the connector/ cable is going out it can give a solid hue across the entire screen.
You can also try updating the video drive through device manager to see if an updated is need.
Hope that helps.
Fullink Premium Blue Connectors HD15 Male to Male SVGA VGA Long Video...
I’m happy to help further over the phone at https://www.6ya.com/expert/james_d4449ffdf318a2c3
Sep 27, 2015 | HP 2009M Monitor
I have a Toshiba Satellite A505 S6930 and the screen went totally black and I can't do anything. I can log in with my password, but I can't see anything. Is there a screen lock or something? I've shut down...
Try Plugging an External Monitor to your SVGA Port on the system.
Then use your function button (Fn) and hit the external monitor button (Looks like a Monitor or TV screen) ...reason for this.
Is you might have your system set to external mode to use a monitor instead of being set to the main screen of your laptop.
Hope this helps.
Dec 06, 2009 | Toshiba Satellite A105 Notebook
How can i connect my two monitor in one pc..thanks
If you want to work with two monitors you can buy a monitor switch box or a second video card to connect two SVGA monitors to one computer. You'll need Windows XP or Mac OS X or newer one. For details please watch the Video by clicking on below link.
Cut and Paste in your browser the below link:
http://www.ehow.com/video_13829_connect-two-monitors.html
Please rate my answer and give your feedback, this would lead me towards better serving of your problems.
Regards,
KK
Oct 25, 2009 | Computers & Internet
With all cords hooked up there is no pic and a blue lite blinking
This means you are not getting a signal to the monitor.
If you have 2 SVGA outlets on the back of your computer, are you using the correct one?
Next, I would suspect that the display on your video is out of range for the monitor. On the computer start-up, start hitting the F8 key until you get the black and white menu. Choose the VGA option to get Windows started and then you can set the correct resolution.
Sep 30, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Out of the blue one day, monitor started displaying "anaolog power saving mode." This is a stand-alone computer which has never been hooked up to internet.Took tower unit to PC World to see if it was a...
you go to control panel starting your pc ,, then display settings,, from there,, screen saver tab, then make screen saver to none, and click on button power,, there you make everything to never,, and then see. it should work good
Sep 27, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Blue screen then shuts off
Sounds like WIN 95 blue screen of death 9x is no longer supported or missing or corrupted drivers, reinstall O/S and perform updates, if not you may have internal parts problem have a extra computer ? swap monitors or plug into computer so loang as if its SVGA to SVGA do not swap into a card and drivers for VGA, or lower .
otherwise contact a Certified Electronics Tech or try Best Buy their techs are certified,
Apr 16, 2009 | NEC MultiSync LCD2335WXM (Silver, Gray)...
FORGOT HOW TO HOOK-UP MONITOR (PF790) TO MAC G4.
Have a look on the back of the monitor for the output socket.
If the socket is blue with 15 round holes then this is a SVGA socket, if it is white then it's a DVI socket. Though I believe that this monitor only had SVGA outputs.
Look for these same sockets on the G4, and connect the cable to the matching socket.
If you have one which is blue and one white you will need an adapter for the cable.
Mar 25, 2009 | ViewSonic PF790 PERFECT FLAT 19" Monitor
Out of range external monitor
The max resolution supported by that LCD HDTV is 1366 x 768. If your screen resolution in XP is set higher than that, you'll run into issues. Reduce your screen resolution first, then run the nVidia multiple display setup.
Jan 28, 2009 | IBM NetVista PC Desktop
Sync out Of range
You need to get the monitor back into a range it can use and the best way is to go into SAFE mode on the pc put it back into 640X 480 and at 60 hz refresh rate. 37.9khz is way too high for the monitor!
It is best in the 60hz to 80 hz (if it can go that high!) start at 60 to begin with and it will work.
Good Luck!
Rich Lilja
Nov 24, 2008 | Samtron MONO TTL 13 Monitor
Out of range
Feb 15, 2008 | GNR F153A (Black/Silver) 15" LCD Monitor
Compaq TFT5015 15" LCD Monitor Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
