Question about kawasaki PVS1080
DVD Player won't turn on.
I can't get any power to the unit. The batteries are on, the unit is plugged into a wall socket but it will not come on. Nothing. What is the problem? It has only ever been used 4-5 times since I bought it. Where do I find a manual for it?
  • 2 more comments
  • Anonymous Mar 16, 2008
    My unit did the same thing on the same day, I have a manual, no answer there.
  • Anonymous Jul 21, 2008
    same problem
  • railroad1 Sep 10, 2008
    Thanks for all your help! I haven/t tried to change the fuse yet, but I will do that today and see if it works.
  • MayorCB Feb 19, 2009
    I have a Venturer PVS1080 DVD player, it has not been used since last summer. I can get no power with the adapter or the batteries. Can the batteries be no good and can I get replacements.
Did u try changing the fuse? i also have this problem but it isn't the fuse on mine, i already tried changing it
Posted on Sep 10, 2008
I had the same problem on the same day. No answer in the manaul. Bill
Posted on Mar 16, 2008
No power when plugged in in any socket.
Solving HDMI Problems - HOW TO GUIDES
www.hdtvsupply.com > HOW TO GUIDES
Rating: 4.7 - ‎2,086 votes
The hdmi cables carries a low DC voltage while connected. ... If so, reset it to match the native resolution of your TV or video projector (such as 720p or .... Source Device:Any Blu-ray Player, DVD Player, Gaming Console (PS3, Xbox 360), ... Power cycle:Power off / Power on equipment (At the wall socket since some LCD's ...
HDCP / HDMI Handshake Troubleshooting and Guidelines
site.hdtvsupply.com/hdcp1.html
The hdmi cables carries a low DC voltage while connected. ... Source Device = Any Blu-ray Player, DVD Player, Gaming Console (PS3, Xbox 360), Apple ... Power cycle = Power off / Power on equipment (At the wall socket since some LCD's ...
Amazon.com: Customer Reviews: Belkin Conserve Socket ...
www.amazon.com/Belkin...Socket.../B003P2UMQ2
Amazon.com, Inc.I wanted to completely turn off my subwoofer amp, blu-ray player, PS3 and .... but my Mac uses next to no power and my PC normally gets shut down after use). ... I hereby give up any and all hopes regarding Belkin support. ... I plugged her television in to the main outlet and her Wii and dvd player into two of the other ones.
[PDF]Blu-ray Disc™ / DVD Player - Manuals, Specs & Warranty
https://docs.sony.com/release/bdps3100_bx310.pdf
Sony Corporationin this Blu-ray Disc/DVD player is harmful to eyes, do not ... be unplugged from the wall socket immediately in the event ... operating in conjunction with any other antenna or ... However, there is no ... as power-supply cord or plug is damaged,.
Jan 26, 2016 | Televison & Video
Won't turn on
see this causes and fix it. God bless you
  1. Power outlet, wall adapter, or batteries are dead (as appropriate).
  2. Damage to line or wall adapter cord or plug.
  3. Bad connections or faulty component in power supply (including blown fuse).
  4. Defective microcontroller.
Sep 23, 2012 | Samsung DVD-H1080R DVD Player
It wont turn on when i plug it in
Did u check your wall socket to see if it has power , plug some other unit intointo the socket that u know worts like a light if it does not work check the fuse box for a trped breaker
Sep 19, 2012 | Mintek DVD-1600 DVD Player
Sony portable dvd player won't power on? /model #dvp-fx950?
Have you tried to plugged in directly to the wall without the battery?
Feb 23, 2012 | Sony Televison & Video
I unplugged my dvd recorder. When I plugged it back in it won't power on.
Hello
Just look at the power chord, whether it has been pluged into the slot well. Check the wall power socket also for presence of power. Replug it to an other power plug point. Till the problem perists, surely there must be some fault with its power regulator board inside. Normally, if power regulator board gets power, the power indicator must light up. If not power regulator board [SMPS] board is faulty, and should be replaced with same type and number. OK.
Jun 27, 2011 | Philips Magnavox DVD/VCR Dual Player
Id like to know how to unlock my samsung ht-z120 home theatre dvd player to watch other counrty dvds
Hiya,
Try this procedure:
1) Unplug player from power socket (for 1min)
2) Connect plug to power socket
3) Using the remote, press POWER button to turn unit on.
4) Press DVD button to enter dvd-mode
5) Press the following remote buttons, in this sequence:
ENTER, 8, 4, 2, 6, 9, ENTER
If done correctly, your dvd should go into Standby mode.
6) Press POWER button to turn unit on.
Cheers,
"If this works, please rate this solution with thumbs up"
Jun 16, 2011 | Samsung Audio Players & Recorders
Craig, portabale, dvd player has been lying around for months. When I plug it in I have no power. Do I need to let the, internal, battery charge even if the unit is plugged into the wall?
Yes,u must let the litium battery fully charge,if u want to use the DVD player as a potable player.Without plug in the power outlet from the wall.
Feb 27, 2010 | Televison & Video
Won't turn on.
"Player is getting power. (It's) making a faint sound and the output jack is flashing but shows nothing on the display"
So, it is obviously NOT 1, 2, or 3 above. It IS getting power.
The first thing I'd try is a re-boot, try unplugging the unit and waiting about
Feb 08, 2010 | LG BD390 Blu-Ray Player
My little colby dvd player wont open or close and it wont turn off. if it would open, i would try to reset the remote..yes, i have plugged and unplugged and have it plugged directly into tv???
I assume you've tried plugging into a wall socket instead of TV?
Probably won't work, but push and hold power button on unit 10 seconds then release, for that matter try all buttons. Not uncommon problem, usually you have to UNPLUG unit, disassemble to remove DVD and discard unit if cheap enough.
Sep 26, 2009 | Televison & Video
Dvd Recorder+VCR Combo Model#DRC8320N
CALLED 1-866-775-0976..WAS ADVISED IF PURCHASED LESS THAN 1-YEAR AND HAVE RECEIPT..SEND MODEL DRC8320N..TO: VENTURER ELECTRONICS..203 EGGERT ROAD..BUFFALO, NEW YORK 14215.....FOR REPLACEMENT PRODUCT....ANDREW REP..STAED THAT RCA WAS BOUGHT OUT BY AUDIO BOX COMPANY....SENDING MINE..GOOD LUCK....FROM : AFM1PGE.COM...GOOD LUCK!
Sep 12, 2007 | RCA DRC8300N DVD Recorder/VCR
kawasaki PVS1080 Logo
1,299 people viewed this question
Top kawasaki Televison & Video Experts
wayne chamberlain
Jaime Hernandez
Davor Krstevski
Davor Krstevski
Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
