Question about Hotpoint WMA64 Front Load Washer
Heater element how do you fit a new heater element to a hotpoint wma64, i cannot see any screws or bolts that hold it in place ?
  • steve marren Feb 17, 2008
    there is a nut but it only appears to be the earth connection and i cannot see any other fixings even on the new heater element?
    Sergeant:
  • 236 Answers
There should be 1 nut that holds it in. undo this fully and the element has to be carefully prised out. replacement is in reverse, ensuring that the rubber seal is pushed fully home.
Posted on Feb 16, 2008
I have bought a new drum for a hotpoint aqxxd169pm. But it has come without the heating element integral with the drum. I do not know how to get the heater element out of the old drum and the refit it into...
heater element should only be held in by 1 bolt which runs from inside to outside element faxe......remove the nut..........carfully prise the element out...its only kept in place by rubber ..washing up liquid may help.......
cheers
Mar 09, 2015 | Hotpoint Washing Machines
This water heater has two elements, correct?? Well how do you get them out?
The first thing to do is shut off power supply to the heater. Then while water is still on hook up garden hose to drain valve on bottom of heater. Place hose to floor drain or some other location for safe drainage. Open drain valve and if it starts draining at a good rate then shut water supply valve off to heater. You will want to open hot side of closest faucet to prevent vacumn which will slow or stop draining. After heater is done draining shut off drain valve and faucet . Remove the cover plates on top and bottpm of heater. Usually four small screws. Locate heating elements and disconnect wiring,label if you need to for reinstallation. There are two kinds of heating elements,one is held in place with 4 hex head bolts,and the other is screwed in. If yours has the bolts carefully remove to avoid breaking bolts.Then just pull out to remove To reinstall there will be a new rubber gasket with element, fit it in place and insert element back in heater. Reconnect wires. If there are no bolts apparent then the element screws into heater. You will need a pipe wrench or large wrench to remove the element. The same thing with this element is that it should have a new rubber gasket. Put gasket in place and wrap threads with 5 to 6 wraps of teflon tape. Install element and tighten snugly. Connect wires,refill with water and check for leaks. If no leaks then turn power back on. Put cover plates back on and you're done. I hope this helps you. Thanks
Nov 19, 2010 | Audiovox Richmond 6EM30-2 30-Gallon 6-Year...
Do you have to take the motor out to fit new brushes on a hotpoint wma64
Remove lower rear panel of washer.
Remove drum drive belt.
Unplug lead to motor, remove earth wire.to motor.
Locate and undo 2 screws securing motor to drum chassis.
Lever motor backwards to remove from mountings, keeping hold of the motor so it does not drop.
Remove old carbons at opp end to motor pulley.
Mar 13, 2010 | Hotpoint WMA64 Front Load Washer
My hotpoint dryer isn`t putting out any heat and when turned on the drum does turn.I had the dryer apart and tried to take out the heating element but couldn`t get it out.It seems that the element has...
The backside of the terminals are bent to hold them in place. You need to use a pair of needle nose pliers to bend the tabs out from the outside of the terminal. Its very awkward to get to them so if you have to you could remove the 4 screws that hold the heater housing in place and then you can kind of swing it up to give you a better look at the bottom of the terminals. When you restring the new element be very careful not to over stretch the coils. If they touch ANY metal at all it will short out and fry the element. Hope this helps _MJ_
Feb 19, 2010 | Hotpoint Dryers
Hotpoint Door Seal WMA64
I have reproduced the details of my article: http://www.fixya.com/support/t1543617-door_seal
here. I hope this will give you the information you need.
Rule 1: BEFORE YOU START Turn off the mains, unplug at the wall, turn off the water supply.
The gasket is held in place on the drum by a large sprung wire ring with a screw tighten/release. To access this (Depending on the model), you will either have to go in from the top or the bottom of the machine. Usually the top.
Pull the machine out, go to the back and unscrew, usually 2 screws that hold the "Work top surface" top on the machine at the back. There are usually clips at the front of the top, so by lifting the rear clear and either pulling the top back, or giving it a tap forward, depending on the design, the top should now lift off.
You should now be able to look down at the drum and you should clearly see the rubber gasket fitted over the edge of the drum with the clip in place. Locate the screw in tensioner and undo it until it is possible to slip it forward and clear of the drum. You should now be able to simply pull the gasket away from the drum. Most machines rely on the door being closed to hold the gasket in place where it meets the chassis, it should just pull off if the door is open, but while you are lookiing inside, just check anyway. The assembly is simply a reverse of what is described above.
Stuff to consider: You may not be able to see the screw clip from the top, if so, tip the machine back and look from underneath. If you have to do this: Never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, so the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend putting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
Feb 13, 2009 | Hotpoint WMA64 Front Load Washer
Need to remove case of hotpoint wma 63
The drum comes out through the front on this one.Take off kick plate and remove screws holding front panel to frame. Take out soap drawer & remove screws behind it. Take off band holding door seal & peel seal back.Remove 2 screws holding door lock &push lock through. Pull control panel forward at left side &slide to right to remove being carefull with board & wiring.Remove screws holding top end of front then lift slightly &remove front.Remove back panel &take wiring off heating element & pump. Disconnect the pump hose at the drum end, disconnect the hose from the soap dispenser, note that wiring is fastened to the drum at several points and will need to be disconnected. Remove panel from behind control board then carefully move everything away from the front of the machine, the drum can now be lifted clear.
Forgot to mention unplugging motor but common sense will prevail.
If you need any further assistance please post back
Good luck & thanks for using Fixya
Nov 27, 2008 | Hotpoint WMA64 Front Load Washer
SOAP DISPENSER HOSE
take both star screws from under lugs on either side of the lid remove that then take soap drawer out if screws are not visable remove front facia panel the same screws which hold the facia will also hold the soap drawer in place as you lift the drawer you will be able to undo the hose to the drum.
Mar 08, 2008 | Hotpoint WMA64 Front Load Washer
Hotpoint ultima wma62s
d67081b.jpg Remove Two pin socket carefully with pliers. Refit of new one is reverse of remove.
Feb 23, 2008 | Hotpoint WMA64 Front Load Washer
Hotpoint FDW60 heater replacement
The heater is the black element at the bottom of the tub. you can see it when you open the door, there are 2 wires attached to it under the dishwasher along with 2 nuts and some rubber washers to keep it from leaking, It is a simple job to replace. Remove the wires undo the the nuts that hold it to the tub, and there may be some brackets inside the dishwasher that secure it in place. remove the element and replace it. Install in the reverse order you took it apart.
Feb 22, 2008 | Dishwashers
How to change the Heater Element in Hotpoint WF210G
hi there, this heater can be a bit fiddly but can be fitted from the back first remove the 10 or possible 8mm nut from the heater and all wires then with a pair of pliars grip one of the terminals and pull the heater 2-3" out then with a small flat head screwdriver start to prise the rubber seal out all the way round until the heater drops out don't be scared to use a bit of force on the seal as your new heater comes compleate with new seal
hope this is of some help murdozzz
Dec 09, 2007 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint WMA64 Front Load Washer Logo
60 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
