Question about Copystar CS-2030 Copier
Error appearing on screen C710
We have an error C710 appearing after one copy.
  • Chris Coughlin
    Chris Coughlin May 11, 2010
    What kind of copier is it. Is it a Minoltia?
    Genius:
  • 1,665 Answers
Did you disconnect telephone line?
C710: Interrupted Communication at the Destination.
If you're the sender, it's happening outside your machine.
Most likely, phone line
Posted on Feb 20, 2008
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Feb 20, 2008
    Also check:
    Try removing and refitting drum and toner.
    If this does not help you may have damaged your toner cartridge or the sensor
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
My acer chromebook will only show a blue screen when turned on, will not come on?
Hi
Are there any error messages on the screen or is it just blue if any errors can you tell us what thay are
Cliff Cook
MCP
Jul 30, 2014 | Acer C710-2055 Chromebook
Error c710
it means that toner cannot enter the developing section of the copier, all you have to do is remove the developing unit, then pour it with enough toner, the problem will be solve.
May 17, 2009 | Kyocera Mita KM-1815 All-In-One Laser...
Can not clear Error Code AP
You are out of toner...It means ADD POWDER
Feb 05, 2009 | Kyocera Mita KMR-1810P Laser Printer
Mita Kyocera KM1535 with an error code. C710
C170-Toner sensor/Developer Error
check usual suspects Sensor, Wiring, Developer material, connectors.......
Feb 05, 2009 | ASUS P5GZ-MX Motherboard
Kyocera mita km-1530
press 1087 1087, then 131, press copy and then set toner level to 155. turn off machine and on again.
Mar 17, 2008 | Baby Gear
Need to be fixed
either the toner output voltage is inaccurate,poor contact,no contact at ll or the toner sensor is faulty replaced it.
Feb 15, 2008 | Kyocera RI-3530 Black and White Copier
Copystar CS-2030 Copier Logo
1,710 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
