Question about Panasonic PanaFax UF-8000 Laser Fax
Fax Error When you fax a document, we don't received any fax confirmation and fax doesn't go through.
  • senwestlady Mar 06, 2008
    How do you get a fax confirmation so you know your fax went through??
  • Devaander1 Dec 03, 2008
    panasonic uf-8000 will not print confirmation page after a fax is sent.
    Sergeant:
  • 284 Answers
If this is a uf8000 please follow these instructions.
fuction-7-4-start-1-2-start-2"always"-start stop.
the journal will print every time you fax out now
have a good day and good luck
Posted on Sep 17, 2008
    Champion:
  • 220 Answers
If you want a confirmation report all the time you have to go to system setup and in reports select option "always print".If you want confirmation only this time you can print journal and see status of last item.
Samir
Posted on Mar 14, 2008
The fax is received by the other party but we receive an error code J72. There is no jam
Dear
If you are sending the fax using ADF, there may be the document jam, Open the ADF cover check the path for any foreign objects.
Also you can send from platen glass without document jam.
Also this may happen to the other end fax machine, better you do a test copy from ADF and Platen glass. and confirm your fax machine is ok.
Thanks.
Mar 05, 2015 | Panasonic PanaFax UF-8000 Laser Fax
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
How to receive fax documents
You cannot receive fax using this printer, because this printer doesn't support fax sending/receiving. Only fax supported printers can receive fax documents. You will know if a printer is fax support if you see a Fax button there or if you can see a numpad buttons where you can dial numbers.
These are the photo examples of fax printers
Hope my solution helps. Thanks for using Fixya!
Jul 11, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
Sharp FO-4700 Fax Not Received Even Though OK Fax Confirm Given
It's gone forever, once your machine received a EOT (end of transmission signal), your fax machine thinks it was received OK and clears it from memory.
Oct 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
How do i set up the fax to print a confirmation sheet when it sends something?
Try this:
Press the Setup button (it might be the sign of a monkey range)
  1. Press the Down arrow (c00844971.gif ) to highlight Print Report , then press OK .
  2. Press the Down arrow (c00844971.gif ) to highlight Fax Confirmation , then press OK .
  3. Press the Down arrow (c00844971.gif ) to select one of the following options in the table below, then press OK
On Fax Send Prints a fax confirmation report for every fax you send. On Fax Receive Prints a fax confirmation report for every fax you receive. Send and Receive Prints a fax confirmation report for every fax you send and receive. Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
Select the one you would like to choose ;
For further help click on the following Link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01083680&cc=us&lc=en&dlc=en&product=3204785
Regards Soumajit
Sep 21, 2009 | HP Photosmart C7280 Laser Printer
Need a fax number to confirm fax is b eing sent
  1. Test your HP Fax to make sure it is set up properly for faxing.
  2. Place a document in the document feeder and dial 1-888 HP FAX ME (1-888-473-2963).
  3. Press Start/Enter .
    1. Wait approximately 1 minute and you will receive a “Fax Back System Test” page, confirming your product is working correctly.
    NOTE: The Fax Header must be set up to test the fax machine.
  • Jul 27, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
    ''Document Jammed'' error message
    Open the document feeder and look for a switch actuator stuck in the down position.
    Nov 19, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
    Confirmation page
    You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
    Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    Not been able to receive fax some time
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00547&cc=us&lc=en&dlc=en&product=425911&dlc=en&lang=en
    Oct 31, 2007 | HP 1040 Plain Paper Inkjet Fax
    Sending Faxes
    When the last page of your document has been sent successfully, the machine beeps and returns to Standby mode. When something goes wrong while sending your fax, an error message appears on the display. If you receive an error message, press Stop/Clear to clear the message and try to send the document again. You can set your machine to print a confirmation report automatically each time sending a fax is completed. If you get the error message write it down it should always supply an error message if the fax did not go through.
    Jul 25, 2007 | Samsung SCX 4521F All-In-One Laser Printer
    Panasonic PanaFax UF-8000 Laser Fax Logo
    269 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Mitch S
    Mitch S
    Level 1 Expert
    HEMANT GROVER
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
