Question about Trekstor Datastation maxi t.u SATA 500 GB SATA Hard Drive
Disk not readable, Mac OSX 10.5.2
I can use the compact flash card reader fine, but it gives me an error when I plug it in to utilize the hard drive. It says that the disk is "not readable"
I can't find a driver anywhere for it, no software with the product got it from J&R.
  • 3 Answers
Hey guys. I have an answer on how to fix the Trekstor Datastation "Removable Disk" problem.
I also own a Trekstor Datastation 500GB and had the same problem even though it worked for several months then all of a sudden when I tried to hook it up to another computer, it stopped working. It would recognize the USB connection but you could not read the drive as it would say "Removable Disk".
In "Device Manager" it recognizes the drive as Sundata USB2SATA. But what it really should be is "WDC WD50 00AAVS-32ZTB0 USB Device" or something similar to that. For those that are wondering, yes, the hard drive is a Western Digital Hard Drive. Western Digital Caviar to be exact.
Solution: You need to open the cover to the hard drive and reconnect the hard drive to the connector on the board. It's that simple!
It is very loose and this model is not well designed so it can easily come off if you accidentally knock over your hard drive or move it to another location. The hard drive is held in place by screws on a holder where there is room for the screws to slide if the screws are not tight enough.
You'll need a T10 screwdriver bit to remove the cover and a Phillips screwdriver to adjust the hard drive.
NOTE: Doing this will probably voids your warranty but trust me, it works and it's really easy and quick to do. Took me 15 minutes.
Posted on Jul 01, 2008
For me too, after multiple uses it suddenly stopped showing working up.
please help so, i do not lose my my important data
Posted on Jun 16, 2008
Hp back files on card can my computer restore these
The Hx 4700 series and the & The Hx2190 have a removable card Compact Flash or SD Card, if the information you want was stored on these you can buy a USB Card reader from woolies plug the SD or Compact flash into the card reader and plug it into the USB port of your PC or mac and it will be readable (no drivers needed). You may also be interested to know that there are updated ROMS available for this model to update the OS & the Office Apps + increase the max capacity of the storage cards that are recognized.
Mar 29, 2014 | HP iPAQ HX4700 Pocket PC
Tip
Formatting an external hard drive with Mac OS X's Disk Utility
Formatting your new external hard drive is not as difficult as you may think. In fact, you don't even have to be a computer techie or uber-Mac geek to perform this procedure successfully.
The tool you would use, to format your drive within your Mac OS X system, is the built-in utility application called Disk Utility.
Disk Utility is Apple Inc.'s defacto utility application, for performing disk related tasks within the Mac OS X volume.
From creating new images, to burning CDs and DVDs to formatting hard drives, Disk Utility performs well enough to keep not only your Mac OS X volume on your hard drive error free, but keep your hard drive healthy and error-free as well.
I could go on in detail, admirably describing more features of this versatile Mac OS X tool, but the purpose of this FixYa tip, is to show you how to easily format your external hard drive. So that is where I will take you now.
There are generally two formats in Disk Utility that you can use to effectively format your hard drive.
Mac OS Extended (Journaled) - if you want a Mac readable hard drive only
MS-DOS (FAT 32) - If you want your external hard drive to be read by both Mac and PC.
--STEPS FOR FORMATTING YOUR HARD DRIVE WITH DISK UTILITY--
• First, make sure your external hard drive is connected securely to your Mac and is turned on.
•Next, from your desktop, click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities* folder.
(*You can also get to the Disk Utility application via Applications > Utilities folder)
• Now, locate and launch the Disk Utility application.
When Disk Utility opens you will see a left side window, which will show
all connected hard drives and optical drives. It is here that you
should see your external hard drive listed in that window.
• When you locate it, simply select it and then select Partition
from the tabs on the right hand side.
• Change the Volume Scheme from Current to 1 Partition
• Make sure to provide a name for your new external hard drive.
• Select Mac OS Extended (Journaled) from the Format
drop down menu, for a bootable Mac only external hard drive.
• Or select MS-DOS from the Format drop down menu, for a bootable Mac & PC external hard drive.
From there, click the Options button, located toward the bottom of
your window.
This will open a partition scheme selection window as seen in this screen shot:
• Select GUID Partition Table for bootability on a Intel processor based
Mac.
• Or select the Apple Partition Map for bootability on a PowerPC based Mac.
• Click the OK button.
Finally, click the Partition button and allow Disk Utility to format your new external hard drive.
When this process is complete, you now have a newly formatted, ready to use hard drive.
Believe it or not, this process can be completed faster than you think.
Using this method with Disk Utility, I was able to format my new 1TB Iomega USB external in less than 20 minutes.
Final Note:
I used the external hard drive as the focus for showing you how to format and prepare your hard drive for use on your Mac, but this feature can also work with internal hard drives as well.
For more information about some of the disk repairing features of Disk Utility, here is a great support link for this nifty and quite effective Apple utility for the Mac OS X platforms:
Using Disk Utility to repair a disk
Thanks for reviewing my Mac OS X Tip!
Regards,
-Mactechtrainer
on Feb 11, 2010 | Computers & Internet
How to install a .dmg from pc to mac
use a thumb drive to move the disk image from your pc to your mac. Partition the thumb drive within Disk Utility as Ex-Fat and it will be readable in Windows and OSX and will not have the file limit of 4GB that Fat32 has.
Feb 26, 2014 | Apple MacBook Pro Notebook
I want to format my transcend from mac how can i do it
Transcend produces different kinds of memory modules, including Random Access Memory, or RAM, chips for computer systems, USB flash drives and a variety of flash memory card formats, such as SD.
Transcend's flash memory devices are usually preformatted with either FAT32 or NTFS. Macintosh systems primarily use the HFS+ file system format.
You can format a Transcend flash memory card to the FAT format using the Disk Utility program on a Macintosh.
Insert the Transcend flash card into a card reader connected to the Mac.
Some Macintosh computers have SD card readers built in.
Open the Disk Utility program in the Utilities folder.
Click the flash card in the left column of the window.
Click the "Erase" tab.
Click "MS-DOS (FAT)" in the "Format" drop-down list.
Enter a name for the flash card in the "Name" box.
Click "Erase" to format the flash memory card to FAT.
Hope this helps
Oct 28, 2012 | Transcend ts250gsj25m storejet 25 mobile...
Mac
Hard drive failure.
May 12, 2012 | Apple Macbook Computers & Internet
How to disable write protection in flash drive..? other solution please..
use partitioning software i.e. disk utility if mac if PC partition editor and rewrite the disk as FAT 32 (Mac OSX Journaled if on Mac) if unsure or whatever format you want it in
Mar 01, 2011 | Electronics - Others
1T external will not mount on Mac OSX. It worked fine but just stopped. Have tried other computers and cables but nothing. It is getting power. Model #MDHD10T-U2 Serial #JPA7470874
This needs to be formatted before it can be used on a Mac.
  1. Launch Disk Utility by selecting ApplicationsUtilitiesDisk Utilities
  2. Click on the active partition to select it.
  3. Click on the Erase tab.
  4. Select MS-DOS (FAT) from the Volume Format drop-down menu.
  5. Click on the Erase button.
  6. When Disk Utility is finished erasing the disk, click on the active partition and ensure that the Format field at the bottom of the Disk Utility window says that the volume is MS-DOS (FAT32).
  7. You can now quit Disk Utility.
Oct 13, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
When i put the memory card in my digital camera, it says filesys error: e00100, and then it tells me that the memory is full, i just bought the memory card new.
Okay this means that there is a problem with the card. Can you Plug your card directly into your computer? If you can I need you to reformat the card. If you need instructions on how to do this Just ask. If that does not work I will continue to assist you to help you resolve your problem in the most efficient manner possible.
Thanks You,
Ryan Frame
Creative Energy Associates Technical Center
Jul 28, 2009 | SanDisk 2GB microSD Memory Card
I have a Canon EOS 350D, Compact Flash card freezes my computer
Instead of connecting via the camera, just use a USB card reader and put the CF card in that.
Mar 17, 2017 | Canon Rebel XT / EOS 350D Digital Camera
Installing Maxtor onto mac osx
I found the solution here: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=SATA_Troubleshooter_-_Mac_OS_X_Installation_Basics&vgnextoid=a0a44a3cdde5c010VgnVCM100000dd04090aRCRD#storage
but short version of it all:
Basically you just need to format the drive to get it working. Open up disk utility. Selecting the maxtor drive on the left in disk utility. Then select the erase tab. Then change MS-DOS (FAT) to Mac OS Extended. Finish by clicking erase.
Mine didn't work at first even though I plugged it in but after I did that it worked. Hope you can get yours working too!
Jun 08, 2008 | Maxtor BASICS Personal Storage 3200...
Trekstor Datastation maxi t.u SATA 500 GB SATA Hard Drive Logo
799 people viewed this question
Top Trekstor Computers & Internet Experts
Mohamed Ismail
Mohamed Ismail
Alun Cox
giarcnameloc
Level 1 Expert
Are you a Trekstor Computer and Internet Expert? Answer questions, earn points and help others
