Question about KitchenAid Pro Line Coffeemaker Coffee Maker
Beeping sound, won't brew
I've had my coffee maker for a couple of years and it's work perfectly, up until now. When I try to turn the coffer make on to brew, it will beep once, flash the blue light and not do anything. The same thing will happen on repeated attempt(s). When I walk away and try again a few minutes later, it usually comes right on and starts to brew. I know there's enough water but I'm wondering if there's some type of internal sensor problem. Unfortunately, I can't find my manual to come up with any ideas. only blue light comes on, will not brew coffee. My pot is 3 yrs old.Is it worth getting fixed and who repairs this machine. Thanks   jrthornburg@yahoo.com
    Genius:
  • 3,587 Answers
Our Hassle-Free Replacement Warranty guarantees that if your PRO LINE™ countertop appliance fails in
the first two years, KitchenAid will replace it free of charge. We will:
  • Deliver a replacement to your door
  • Arrange the return of the failed appliance
  • Guarantee the new appliance for two years
    For more information or complete warranty details on KitchenAid® PRO LINE™ countertop
    appliances, please call Customer Service at 1-800-541-6390 or click here.
    spacer.gif up_carat.gif Return to top
    Beeping sound, won't brew - spacer.gif spacer.gifBeeping sound, won't brew - spacer.gifsrc="http://i.fixya.net/uploads/images/spacer.gif" alt=Beeping sound, won't brew - spacer.giff" class="h_mi" /> spacer.gif spacer.gif spacer.gif Product Literature spacer.gif Additional Resources
    Posted on Feb 15, 2008
    • Patrick Michaels
      Patrick Michaels Feb 15, 2008
      since new ones run 250 bucks, and you're just a tad out of warranty, you might wish to consider a fix. Sounds like you're maker is having temperature sensor issues. Call that phone number, and I'll bet they can wire you up in a hurry
    My mr coffee optimal brew just beeps constant when you press the brew now button
    My hubbub and I "downgraded" to an "upgraded" Cuisinart to Mr. Coffee Optimal Brew 12 cup carafe, mainly d/t the carafe keeping the coffee hot with no burn taste and the stylish st. steel carafe. We've had 2 cuisinart's and both gave us leaking issues after 3 years of hard use (2 pots daily). The cuisinart leaked and also had the burned coffee taste, We unpacked the Mr. Coffee, cleaned all parts, after several attempts, finally stopped beeping and ran the first clean cycle. We are past ready for a great cup of joe...NO.pot ready, grounds in, attempt to turn it on and...that beeping almost got and may still get this apparatus taken back, traded, gone....but after reading my book that never says a word about beeping, I googled and saw MDLS1 replied and while I thought it was crazy I was not giving up without pulling out crazy, and it worked. After a solid hour, I found an answer... You can't just tap it here and there, I took resevoir off, banged it good, forceful but not to hurt my hand, took the basket out and banged the top and clapped around all sides, filled her up, turned it on and walla.made a perfect 10 cup = about 5 "normal" cups of joe, and it was good...pot made in 8-9 minutes, stayed hot over an hour when it was finished. Tonight, I have a hot cup, hubbub got his,and we are happy campers...however, one more beep and it's gone.
    Dec 06, 2013 | Mr. Coffee 10-Cup OptimalBrew Thermal...
    Keurig Mini B 30 won't work.
    Time for a new unit....it is past its prime now.
    Jan 05, 2013 | Keurig B30 Mini Coffee Maker
    It won't brew when it says its brewing. Why won't it brew my coffee? Just seems to be really slow and I have only had this coffee maker about a year.
    Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
    Keurig CoffeeBrewer not making a full cup of Coffee
    heatman101
    Aug 18, 2011 | Keurig Platinum B70 Coffee Maker
    Coffee maker brews MUCH slower and makes less coffee
    It may not help but won't hurt; put a couple of cups of plain vinegar into the water chamber, turn on briefly until it starts to pump, then turn off and leave overnight - at least, if not longer. The mild acid content may clear some lime buildup.
    Apr 14, 2010 | Cuisinart DCC-1200 Coffee Maker
    Jura Impressa E fails to dispense, then gives "open tap" message
    I had the same problem, when I called their very helpful customer service, I was given these directions.
    Take out the tray.
    Inside the machine you can now see a flap hanging from the top.
    Reach behind the flap, and you should feel a round object/filter. It has a little dimple sticking out in the middle.
    Wipe the filter with a paper towel.
    Put the machine back together, and voila you got your coffee brewing again.
    Jul 03, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
    Turn off beeping alarm when the coffee maker is done brewing
    you can't ,its up in the top behind the controls.
    you have to take the pot totally apart.
    only a trained tech should attempt this.
    Mar 23, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
    My DCC-1200 won't turn on
    I called Cuisinart. There is no way to fix it. If your coffee maker is still under warranty (3 years) they will replace it. Otherwise, its next stop is the landfill.
    Dec 14, 2007 | Cuisinart DCC-1200 Coffee Maker
    go to this link armed with your model number for the manual(they help you to find this on the site if you have trouble). http://www.kitchenaid.com/custserv/service.jsp If you get no luck from that then please ask again. Hope this helps :)
    Feb 07, 2007 | KitchenAid Pro Line Coffeemaker Coffee...
    KitchenAid Pro Line Coffeemaker Coffee Maker Logo
    459 people viewed this question
    Top KitchenAid Coffee Makers & Espresso Machines Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Sal De
    Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
