I am tring to figure why my printer isn't working, It isn't printing and I was told that I need to bring it in for services. Is there anyway that I can be able to clean the head on the printer?? It is for All in One lexmark X1150. Thanks Robert
  • 37 Answers
If it requires servicing then unless you know the ins and outs of how a printer works then i suggest you take it to a qualified repair centre.
Posted on Feb 15, 2008
When removing the document that prints, how do I remove it from the continous paper without wasting a sheet every time?
Press the view button tear off the paper then press view button again and the printer will bring the paper back down, I think anyway
Mar 23, 2012 | IBM 6400 Matrix Printer
It is saying my printer is out of paper, but it is not and will not print. It just makes some weird noise and shows error.
Hi
These printer are not of any good. Anyways try to open the printer and access the service station see if it moves right to left without trouble.
Look inside the printer towards the right side you will see the service station and before that check if a small plastic lever has broken its a small lever connected near the service statation if you can figure it out then you need to replace it.
DO RATE MY SOLUTION
Jun 30, 2011 | HP PSC 1315 All-In-One InkJet Printer
Have a linksys router tring to get adlink print
Did the dlink print server come with an installation disk? If so, you probably need to run that. It will help you set up a virtual printer port that you can then choose when adding a printer. For seting up two printers, you'll have 2 different virtual printer ports. For example SCB77031_P1 and SCB77031_P2.
If you need more help, please let me know what model linksys router and dlink print server
Aug 23, 2009 | Linksys Computers & Internet
Error message ''Unable to Print 4F''
How to repair error "print unable 4F" in the Brother dcp-135c .
thank alot.
Jan 06, 2009 | Brother MultiFunction Center MFC-440CN...
No link between computer& epson 580
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | Epson Stylus Color 580 InkJet Printer
Lexmark C1150 printer doesn't print
First I try to uninstall the printer, it didn't work, so I reinstall the the printer anyway, it worked for one print only.
As second attempt I disconnected the printer completely, turned the PC off, and after few minutes on again. Uninstalled printer.
Reconnected the cables again, install the printer - it works well!
Dec 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
Toner not refreshing
I replaced the toner, but it still says toner life ended open front cover and repalce with new one. How do I resolve this
Oct 24, 2008 | Brother MFC-7820N Laser Printer
Canon i860 error codes
Try this: With your i860 printer turned ON, press and hold the I/O switch then pull off the power cord. This will turn off your printer. But without lifting your finger on the I/O switch put back your power cord. the I/O switch will blink for a second and will go off, then turn-on your printer again and see if it works.
Sep 15, 2008 | Canon i860 InkJet Photo Printer
Our new printer won't print.
Ussually, if you go to CONTROL PANEL - PRINTERS AND FAXES, you must be able to see the printer there, if the printer is there do right click on it and select properties, then on the top select the port tab and make sure the port to where the printer in connected is checked, if you have one usb cable then you has to have usb1 or usb2 checked, some times we have the usn cable connected to the usb1 and the printer port is redirected to usb2, so try changing the usb cable to different usb plugs on the computer, if you are using LPT1 and it is checked, do right click on the printer and do print test page, if this work is not the printer, could be the software from witch one you try to use this printer, hope this help a little, see you
May 16, 2008 | Zebra LP 2844 Thermal Printer
Error 361
I've the same problem. Error 361 in the scan mode with MP 780. The offical Canon support told me it's a mechanical problem and I've to bring it to the service. But scaning works and printing isn't a problem too. So I don't believe its a mechanical Problems. Looks more like a Firmeware-bug.
May 21, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Open Questions:
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
