Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Water to my ice maker freezes in metal tube
My ice maker is not kicking out the ice fast enough before it fills back up.so it is freezing up the water thats coming out and cloging up.
  • 1 more comment
  • startpines Jul 23, 2008
    a plastic tube protrudes through the frig to a metal tube which directs water into the ice tray to be frozen. The water freezes in both the metal and plastic tubes. Prior to inserting Styrofoam around the tubes water ran down the back of the frig and froze to the back. I have also raised the temp in the freezer a small amount and varied the size of the cubes. however the problem still exists
  • Gary Davd
    Gary Davd May 11, 2010
    check the water pressure coming into the water valve also see if the inline filter is clogged
  • robert samples May 11, 2010
    i dont quite understand what your trying to say whats freezing up the fill tube or the icemaker
    Novelist:
  • 184 Answers
ON MOST ICE MAKERS, THERE IS A LARGE WHITE GEAR ON THE FRONT OF THE ICE MAKER BEHIND THE COVER.
THIS GEAR HAS CIRCUIT TRACES ON IT THAT WILL BURN THE PLASTIC FROM ARCING FUSING THE WATER FILL CIRCUIT TO ANOTHER ONE CLOSE TO IT. THIS WILL CAUSE THE FILL TIME TO TRIPLE FROM THE 7 SECONDS TO ABOUT 20 SECONDS. THIS WILL OVER FILL THE ICE MAKER AND POUR DOWN INTO THE ICE BIN. THE ONLY SOLUTION IS TO REPLACE THE CONTROL MODULE OR THE ENTIRE ICE MAKER.
Posted on Apr 04, 2008
Ice maker freezing up
The water line to your unit may need to be replaced. Check how fast water comes out of the dispenser. If it's trickling out or takes 30 seconds to fill the glass, you have poor water pressure to the unit and it's causing the fill tube to freeze.
Nov 27, 2013 | Refrigerators
Ice maker spout starts to freeze up (6years old Viking side by side), is there a solution?
low water pressure or faulty valve
low water pressure the valves do not seal proper and slow drips freeze up in tube
are you on well/?
last time fridge filter was changed?
if all good faulty water valve
Mar 28, 2017 | Viking 48 in Built In Professional...
Ice maker fill tube freezing
There is a possibility that the water valve isn't closing completely leaving just enough space for a drop or two of water to make its way and freeze in the tube, but more than likely the fill tube is a plastic one and little divots have formed retaining water and freezing up. These divots may not even be visible to the ***** eye. A good solution is to switch to a rubber fill tube which is less likely to have this problem.
Jun 16, 2012 | GE Refrigerators
The water filling the ice maker freezes in the filling tube.
You can thaw the frozen water with a hair dryer but to stop this from happening the water control valve may be the reason for this to happen. When the ice maker calls for water to refill it is timed. If the water control valve located on the rear of your refrigerator is not closing all the way for the ice maker side it causes the water to freeze in the tube because it slowly flow to the ice make just enough to seal the fill tube.
Thanks and let me know what you find, Sea Breeze
Oct 12, 2009 | GE Refrigerators
Ice maker filling with water but not freezing into cubes.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 25, 2009 | Amana ABB1927DE Bottom Freezer...
Our ice maker plus WHIRLPOOL is not working
If the fill tube gets choked up with ice, it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut.
Apr 28, 2009 | Refrigerators
My ice maker overflows
If the fill tube gets choked up with ice, it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut. or it could be that the ice maker is not level.
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Ice maker isn't filling with water. Water is on and ice maker is on. It's been humid.
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Jul 16, 2008 | Kenmore 53642 / 53644 Side by Side...
ICE FORMS IN THE WHITE PLASTIC WATER TUB LEADING THRU THE BACK OF THE WALL TO THE ICE MAKER. SHUTTING OFF THE WATER TO THE ICE MAKER.
The units not getting enough water pressure to keep the water flowing fast enough not to flash freeze in the fill tube. You will have to check the water supply valve on the plumbing and the back of the unit to see witch on needs cleaned out or replaced.
Apr 18, 2008 | Refrigerators
Water freezes before getting to ice tray
sounds as if your water inlet valve is not closing fast enough allowing a small amoutn of water to accummulate in fill tube freezing and eventually freezing solid, would try replacing water inlet valve, or even the water filter if this model is so equipped
Feb 18, 2008 | Refrigerators
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
146 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
