Question about Sharp 56DR650 56" Rear Projection HDTV
Sharp 56dr650 Dlp colorwheel for Mike miaer
Thanks for your help on the colorwheel problem, that was helpful.But mike do you know which model number of the rca dlp will work for the sharp, or are they useing the same colorwheel from model to model on the rca. i have a 600.00 tv not up yet. thanks for all your help mike.
  • 3 more comments
  • Tanya LeVasseur Mar 12, 2008
    I need to know if the rca dlp colorwheel will work also...I have found 7 of them for 143 and some change great solution for a 1700 dollar part if you can even find it....
  • Anonymous May 17, 2008
    Can someone tell me the Vizio Color Wheel part number that has an interchangeable bearing with the Sharp 56DR650 DLP Tv?
  • Anonymous May 19, 2008
    Need To know part number of Vizio color wheel with same bearing as Sharp, and source to get it.
  • Anonymous May 25, 2008
    I have taken the color wheel out and put some graphite on it, but there was no difference in humming noise
  • Anonymous Feb 09, 2009
    I contacted sharp and explained that my lamp had just been replaced and 3days after I installed it, the color wheel goes bad.
    So Sharp offered me a discount on 4 different new and refurbt 52" aqua models.
    Prices for a brand new one ranges between $1380-$1555 and refurbished $$970-$1075...new 1yr warranty and refurb 30days.
    I went online, of course, and checked out the models and prices and found out that their so-called discount is very lame.. I found 2 of 4 models at B&H for $100 less than their direct Sharp price.. I wouldn't consider refurb since they only give me 30 day warranty.
    Sharp has disappointed me and I will probably never buy a sharp tv again.
    Bad color wheel and nowhere to find the part.
  • 80 Answers
I have the original color wheel avaible if you need one let me know -
nipper00@gmail.com
Posted on Jun 06, 2008
I have a Sharp 56dr650. The color wheel bearing failed. Sharp cares not for its customers and won't even respond to my pleads for help in obtaining the replacement. So, with that said, I went to ebay and bought a vizio color wheel (Omega TV in Hollywood, FL). Color wheel is incorrect and colors are all blue as is, so I pulled the color wheel off and did the same from the old one-BIG note, the wheels are glass and fragile, DO NOT BREAK the old color wheel! I viced the old bearing and carefully worked the shaft out of the bearing (it is snapped into the bearing). The vice distorted the old bearing but it was trash anyway. The new bearing, I broke the new color wheel off and viced the shaft. I then pulled the old bearing from the wheel. I then carefully push the old shaft and color wheel into the new bearing (you will know when it snaps in place) asserting preasure ONLY on the metal center hub with my thumb. I had to file a new slot on the cast housing as the ribbon connector is about 1/2 inch shorter on the new bearing. I installed and it all works great!!! Saved from tossing a $2,000 plus tv out! SHAME ON SHARP! Never buy another Sharp product!
Posted on Apr 11, 2008
Sharp 56DR650- Does anyone know how to remove the shaft on which the color wheel is mounted, from the color wheel assembly, without damaging the wheel or motor?
Why are you changing the color wheel? Color wheels are factory built and cannot be taking apart. You have to replace as an assy.
Jan 23, 2010 | Sharp 56DR650 56" Rear Projection HDTV
Projector turns on but does not illuminate bulb is good
may be either the colorwheel or the ballast. if you hear the colorwheel spin up (high-pitched whir), replace the ballast. if you don't hear it, replace the colorwheel.
Dec 11, 2009 | Sharp XR-10S DLP Projector
I have a Sharp 56DR650, red power light turns off.
Engine block(color wheel) needs replacing approx $650 total
Aug 09, 2009 | Sharp 56DR650 56" Rear Projection HDTV
Sharp 56DR650 service menu
Hold menu & vol+ (for 3sec) opens the lamp counter reset menu on Sharp DLP
press OK to reset
Dan
XPortHomeNetworks.com
Feb 16, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Sharp 56DR650 56 in
I searched for over a month for this custmer and had no luck at all finaly the ony option was to get the light engine from Sharps board exchange for $600.00 that is beter than the 1300.00 that Andrews wanted for it. Then found that RCA used the same wheel in one of there DLP's and sure enough this part number had been discontinued and the entire set has crush and exchange order on it as well.
Feb 15, 2008 | Sharp 56DR650 56" Rear Projection HDTV
I have the color wheels in stock let me know if you need them
Sharp 56DR650 56" Rear Projection HDTV Logo
1,060 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
