Question about Sony Playstation 3 (PS3) Console
Disc Drive When we insert game, or movies, nothing happens. It won't give icon to play a game. Its as if the disc drive isn't running. We have tryed resetting the sysem config. also downloaded 2.10 update. This did absolutely nothing. This machine is only 2 months old???
  • keith2121 Feb 16, 2008
    i brought my ps3 in dec about a month later it wouldn't read my disc. the icon in the corner would keep turning. so i send it back. i just received my ps3 back of sony and now the icon in the corner is working but the icon for the disc will not show. i can't play a thing. i did upgrades, clean the disc, put the disc in right still nothing. I JUST GOT IT BACK AND IT STILL DOESN'T WORK. that's CRAZY.. I have to send this junk machine back again. $400.00 for nothing. SOMEBODY TELL SONY MONEY DOESN'T GROW ON TREES..
  • Anonymous Nov 27, 2008
    i have exactley the same problem ps3 are ****!! sony sucks
  • 4,102 Answers
Hi alot of sony customers are having this same problem as you it is covered by the warranty so dont do anything with it just contact the place you brought it form they should replace it for you if the say they wont contact customer support in your manual and then they will tell you the best way to get it sorted out its not worth trying to repair yourself because it should still be under warranty even if no warranty sony will replace it because its such a common fault.
The problem relates to the laser failing usuall the laser motor fails not spinning the disk but alot of the ps3 have been either having your problem or over heating this is the other most common fault.
Just remember when they replace your ps3 that dont use it on carpet it needs to be on solid flat surface and also dont have it on top of dvd player or any other device as this will cause the unit to over heat and fail.
Im sorry i couldnt give you good news but it really isnt worth messing with unless you have no other options left as if you was to repair it yourself you will need to buy new laser unit and these for the ps3 are not cheap and you will also need osciloscope that is if you are going to do the repair yourself they cost about £1000 so the cheapest way is to pay a repair shop to calibrate the laser as they will have the scope to calibrate the laser with as you cant do it without let me know if you need further assistance ok
Posted on Feb 15, 2008
Tip
Xbox help for "Can read CD but NOT DVD."
Step 1: Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc 1. Hold the disc by the edges without touching the top or bottom surfaces. 2. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward. Note Do not use solvents to clean the disc. 3. Once the disc is clean, load the disc into your console and see if the disc plays. If the disc still does not play, try step 2. Step 2: Try other discs Try other discs to determine whether the problem happens with any disc or only with this particular disc. If multiple game discs, DVDs, or CDs will not play: 1. Make sure the media type and the disc region code are compatible with the console. 2. If the problem happens with several discs of different types (games, DVDs, and CDs), skip to “Step 7: Request a repair” below. If a specific game disc will not play: 1. Search the Microsoft Knowledge Base to determine if the game title has any known problems. 2. Make sure the media type and the disc region code are compatible with the console. If the disc you are using has a region code that is compatible with your console but you still cannot play the disc, try step 3. Step 3: Clear your system cache If your Xbox 360 console can’t play multiple game discs, try clearing your system cache. Here’s how: 1. On the console, go to My Xbox, and then select System Settings. 2. Select Memory. 3. Highlight any storage device, and then press Y on your controller. 4. Select Clear System Cache.
Note If Clear System Cache is not available, use the button sequence described in the following article: 971755 How to clear the Xbox 360 console cache 5. Try to play a game disc. If you still can’t play a game disc, try step 4. Step 4: Remove the hard drive If the problem only happens with game discs, let’s try temporarily removing your hard drive. If your Xbox 360 console does not have a hard drive, skip to step 5. 1. Turn off your console. 2. Locate the hard drive on your console. 3. Press the release button on the hard drive and lift the hard drive from the console. 4. Turn on your console. 5. Try to play a game disc.If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If you still can’t play game discs, try step 5. Step 5: Disconnect memory units 1. Turn off your console. 2. Unplug any memory units attached to your console. 3. Turn on your console. 4. Try playing a game. If this step resolves the problem, reattach the memory units and contact Xbox support to order a replacement memory unit.
on Feb 15, 2010 | Video Game Consoles & Games
Guys after i finished installing the game, it refuses to launch and a message is displayed that i insert the disc but after doing so nothing happens,please help??? coz i eagerly want to play it.
There might be no autostart. Click on the start menu, then my computer and double click on your disc drive. from there there should be an icon probably by the same name as the game that should allow you to start if nothing pops up after clicking on the drive.
Apr 01, 2011 | Rockstar Games Grand Theft Auto: San...
I purchased chessmaster 10th edition and installed to computer when i hit the play button for startup it asks to insert disc 1 i would like to know why this is required when the program is installed ...
i am sorry to give u bad news, game CM is game that need disc to run the game because a lot of stuff that still need to run the program left behind in the disc. it was factory setting.
But u can use alternative way by make the disc to image then run it with daemon tool.
first u need program that can make image file like .iso, .nrg, etc. ( i use nero)
make an image file from CD 1 and CD 2 and save it in computer.
second install program that can make image drive to run image disc (i use daemon tool).
make one image drive then mount the image disc to the drive.
now u can play without real disc. (after finished play the game unmount the image disc)
hope this helpful
Feb 15, 2011 | Ubi Soft Computers & Internet
My 360 only plays cds or dvd s wont play games please advise
Feb 15, 2010 | Microsoft Xbox 360 Console
PS3 will not read games or movies.
replace the drive or optical unit you will be glad you did. Another tip never play blue ray movies unless you want to keep replacing the drive as it puts wear on the laser and servo motor get a blue ray for you movies leave this to the gamming only my advice! please give me a good review you will be glad you did!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 15, 2009 | Sony Playstation 3 (PS3) Console
Can't play games or movies
you have a disc read error on your ps3. you can either send it to sony and pay 150 if not under warrenty, or you can get a whole new disc drive for about 50-60 bucks on ebay. you can find a video on youtube on how to install it yourself. its pretty simple.
Jul 06, 2009 | Sony Playstation 3 (PS3) Console
Games,movies wont play
i tried to insert to game cd but the response was negative the game icon never appears on the screen so post me a solution for this in my mail
Nov 08, 2008 | Sony Playstation 3 (PS3) Console
LAPTOP DVD DRIVE WONT PLAY DVDS ANYMORE
Drive is on its way. Typical behaviour. Try air dusting lens but unlikely to fix it. Very easy diy repair and cheap. EBay the new disc drive or refurbished. Then go to youtube. Nearly all laptop drives are the same to replace no matTerry brand. You could even get a faster drive.
Mar 05, 2017 | Televison & Video
Sony Playstation 3 (PS3) Console Logo
586 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
