Question about Panasonic Panafax UF-790 Plain Paper Laser Fax
Changing cartridge i just changed the fax cartridge, recd error message no cartridge info, code 045
  • 159 Answers
The cartridge is probably not seating correctly in the machine. These cartridges are made with a plastic flashing on the drum shield that mates with a sensor actuator in the machine. Problem is, Panasonic made the same machine with sensor actuators in slightly different places for machines made in different parts of the world. This is so you couldn't use cartridges made in different places or for similar print engines such as HP or Lexmark, which are cheaper. You will have to fiddle with this so that the actuator is tripped, I usually remove the drum guard complete with springs and defeat the actuator with a rolled up ball of paper.
Posted on Feb 16, 2008
Most Copier Cartridge have chips on them that tell the copier I am new, Replacing the toner/refill, does not change the chip info as long as the chip says I am empty its empty to the copier, replace the cartridge with a new OEM cartridge.
Mar 17, 2015 | Sharp FO-2081 Copier
There is a fix for this. But only a Panasonic tech has access to the parts for the fix. The toner sensor underneath must be moved closer to the cartridge, you are not low on toner.
Jun 15, 2010 | Panasonic Panafax UF-790 Plain Paper Laser...
Memory received but i am not able to received fax
Please change the toner and feed the papers. It will print all the faxes recd in memory.
Nov 05, 2009 | Samsung SCX 4521F All-In-One Laser Printer
We have a Panasonic Panafax UF-790
It could be a refilled Kyocera KM-F650 cartridge in a Panasonic UG-5510 box.
They look identical, but are configured differently.
You need to try another cartridge as it appears it is not a machine problem.
Dec 30, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
UF-788 Error Codes...
You have a bad laser unit, no parts are available anymore.
Nov 20, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
PanaFax UF-780 toner error.
If you mean a 788, there are moveable tabs on the front top of the cartridge that trip switches. Move them around.
Several companies have their own brand names on Panafax's. Their toner won't work. Kyocera must be kyocera Toner, Canon must be Canon toner, etc.
Aug 05, 2008 | Office Equipment & Supplies
Panafax uf 780
Make sure you have not installed a Toner Cartridge made for the Panafax 585/595 or one for a Kyocera-Mita KM-F650.or Pitney Bowes
It should be UG-5510
The all look identical.
Jul 24, 2008 | Panasonic Panafax UF-780 Plain Paper Laser...
Panafax uf-790 - info code = 011
Check cassette refers to the paper cassette. If there is no paper or the cassette is not seated correctly, then you will get that error. If you tried those, then check the left rear of the cassette for a tab. If that tab is broken off you will get this error and you need a new paper cassette. Good luck.
Jun 14, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
Error message Sharp FO-4450 Fax machine
Press life "2" start for toner.
And life "3" start for drum.
These will reset the counters.
If you are having a "check drum error" then you have broken the sensor arm that is attached to your lid.
Call a technician in your area.
Sep 19, 2007 | Office Equipment & Supplies
Machine will not reset after toner replacement
Info code 45 really means Toner cartridge is not installed.Info code 41 is out of toner & code 43 is toner getting low. There are three connection points inside of the fax machine that tell the machine that a cartridge is installed. Open the cartridge door & remove the cartridge. Verify that the metal tabs on the right hand side above the drive gear stick out far enough to make contact with the cartridge. There should also be two wires that are located on the left hand side that also make contact with the cartridge. Try putting your used/empty cartridge in & see if your info code changes to a 41 or 43.If not, you may have a broken connection. I have found that some compatible cartridges for the panafaxes are missing metal tabs that make contact with the connectors. Compare a cartridge that worked to the one that doesn't to see if it's missing metal tabs. This is not an issue if you are using OEM. Good luck! I can be reached by email if you have any questions.
May 23, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-790 Plain Paper Laser Fax Logo
155 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
