The television keeps cutting out and the green light at the front flashes, tried to put it on timer but it doesn't work cuts out every five minutes.
    Genius:
  • 1,665 Answers
Many problems have simple solutions. Don't immediately assume that your problem is some combination of esoteric complex convoluted failures.
Your problem may be caused by power input line or power supply output.
Unplug the appliance for a couple of hours and plug it again.
Please say the manufacturer and model number in order to search if there is any schematic or user manual in the web.
If you have user or service manual see if there are troublshooting instructions describing the situation of green light flashing.
A TV which appears to be dead except for a once a second or so tweet or flub usually indicates an overload fault in the power supply or a short in one of its load circuits. In some cases, the low voltage (including B+) will just be reduced to a fraction of their normal value as a result of an overload on one of the outputs - usually the main B+. This may be caused by a shorted rectifier in the power supply, flyback, or even the yoke, but check the the loads first. Wait a few minutes for the filter caps to discharge (but stay away from the CRT HV connector as it may retain a dangerous and painful charge for a long time), use an ohmmeter across the various diodes in the power supply.
Using an ohmmeter on the rectifier diodes, the resistance in at least one direction should be greater than 100 ohms. If it is much less (like 0 or 5 ohms), then the diode is probably bad. Unsolder and check again - it should test infinite (greater than 1M ohms) in one direction.
If you are not familiar with electronics it is better to append to tech service to check and figure out the problem.
Posted on Feb 15, 2008
  • 19,396 Answers
This is not my field of expertise, however you can find solutions to similar case in fixya follwing the link below:
http://www.fixya.com/tags/tv_turns_off_itself
hope it helps
cheers
    Genius:
  • 3,422 Answers
Since the size of the picture fragment is correct but is missing, my first thought would be to check waveforms going into the vertical output stage. The supply voltage is probably correct since that often determines the size. It almost sounds like the waveform rather than being mostly on (active video) and off for the short blanking period is somehow only on during the last part of the active video thus giving you just the bottom of the picture. If there is a vertical output IC, it may be defective or the blanking input to it may be corrupted. The problem may be as far back as the sync separator.
Check for bad solder connections between the main board and the deflection yoke. Could also be a bad horizontal coil in the yoke, linearity coil, etc.
If you cannot do this by yourself i stronglly reccommend you to get it repaired by a technician.This is the best solution since there is no home remedy to fix your problem.
Goodluck..
    Genius:
  • 3,587 Answers
Cutting out, as in the screen goes on and then blank?
Hi Had power cut this morning and now the heat pump will not go. Green power light just keeps flashing and orange timer light on.
try turning the power off at the mains ( Isolator switch next to the unit or at the meter box.. Leave off for about 30 minutes as most AC units have a backup memory for when power goes off. Try restarting. If it still goes into a fault code mode ( flashing lights etc) there may have been damage done to the main board due to a power surge.
Jul 14, 2011 | Heating & Cooling
The view timer keeps cutting in some time i can watch tv for hours or five minutes does anybody know the answer
Go into Your Menu Settings and check your settings for the timer. Turn it to OFF. That should stop it from popping up. That's a friendly task some people do to limit how much TV They watch. Very normal believe it or not.
Mar 09, 2011 | Sharp 61RWP5H 61 in. Rear Projection...
I have a Sony 60 Wega, it keeps cutting on and off by itself. It will play for about 5 minutes and then cut off. The timer light flashes approximately 12 times and then it will turn back on. Any insight...
Please replace lamp in tv as existing lamp has reached at end of working life and causing problem.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Dec 27, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
The green light on front keeps flashing an tv does not turn on. I have done a system reset and removed power but it just keeps flashing.
capacitors have failed. You can get the repair kit called the V26 Chassis DM/Power repair kit from www.tvrepairworld.com which contains the caps and the instructions.
Jun 19, 2010 | Mitsubishi WD-62525 62" Rear Projection...
The timer on button flashes
The timer light blinking indicates a failure in the TV set. Either the vertical circuit or horizontal circuit has failed and needs repair. It actually has nothing to do with the timer circuit.
In my experience its probably a vertical output chip, smalla capacitor and zener diode. There may also be an open resistor.
Cost to repair in the 50-75 dollar range usually
Feb 24, 2009 | JVC AV-27020 TV
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Sep 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
