Question about Belkin (F5D9230-4) Wireless Router (F5D92304)
Belkin wireless g router
I bought a belkin wireless g router so i can play online opn my ps3. However it keeps disconnecting for a second so i have to re connect again.
I would like to know what type of connection i need and why it is doing this???
  • Pooki3 Feb 24, 2008
    have the same problem but with my PC which is connected by cable to the wireless router
  • 340 Answers
you might need to reset your router:
On the back of your router there is a reset button, press and hold that when power on, until all the lights are blinking simultaneously (about 30 sec).
Connect a computer to any one of the four LAN ports of the Belkin wireless router. DO NOT use a wireless connection, use a cable.
Open your web browser and type the IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
Click Login on the top of the page to login to the router. By default the Password is left blank, clickSubmit.
Click Security under Wireless menu.
Under Security, Select 64 bit WEP (or 128 bit WEP).
Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you. Example (0102030405060708090a0b0c)
Apply the settings. Please write down the key – You will need it later to configure your wireless computers with the same key.
Remember to set an admin password before you close down, other vice anyone can access you router and change the setup and admin password.
/regards
Teis
Posted on Jan 04, 2009
How to change the nat settings on my belkin play router from strict to open so i can play the ps3 online gameplay more easily.
what about to set the ps3 ip address on the DMZ for the router that will give all the ports open to that address and will play freely
try go to advance settings and firewall or game and applications there is where you will set dmz application .
Good luck
Jul 28, 2010 | Belkin (F5D8231-4) Wireless Router...
Just bought second hand router belkin 54g trying to set up with ps3 it is asking 4 a wpa key and i dont know what to do can you help
the old owner of your router know the wpa code he/she inputed you must ask him wat is the wpa code since you are now the new owner you shold chnage also the old wpa code to new one....
Oct 28, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I have a Belkin Wireless router and I have a PS3
Actually you don't need to forward ports when playing online games. The router should automatically locate the ports for the game because it has UPnP function. Here's what you can do. Disable the port forwarding and DMZ that you set on the router. Look for the UPnP function of the router and disable, Save it. Enable it again, then save. Now power cycle your router. If you have Static IP on the PS3 network settings, try to set it first to automatic IP and automatic DNS.
Hope that helps.
Sep 23, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
My Belkin n1 router disconnects from telstra every 2 hours - exac
This is a known problem with the Belkin N1 Vision Modem Router. The router keeps time by connecting to a Simple Network Time Protocol (SNTP) server every 2 hours. The solution is to go to www.belkin.com and download and install the pre-release firmware which is supposed to fix "A problem where the router could drop some connections on 2-hour intervals" among other things.
Sep 14, 2009 | Belkin N1 Vision Wireless Router
Cannot play my ps3 online on my wireless conected, supported by my belkin router. I'll be able to connect, but it will disconnect after a short time.
Connect Router - Computer ( Wired )
Open RSP by typing 192.168.2.1 on the address bar of the Internet Explorer
On the Left Side Click Firewall
Disable it and click Apply Changes
Restart the Router
Try connecting to Wireless
Let Me know If it Works
Mar 21, 2009 | Belkin (F5D7230-4) Router (587009)
Ps3 problem
- Physically connect the PS 3 to the Belkin router on one of the LAN connection
- Check the connection of the PS3 (if not connecting through)
- Contact your PS 3 manufacturer to gather the ports of the PS 3 and open it on the port forwarding of your router configuration page.
Note: you'll needing to allow the ports of your PS3 and IP address to the Belkin router.
Mar 07, 2009 | Belkin F5D7330 802.11g/b Wireless Adapter
Can't even connect to "setup assistant"
it sounds like you need to keep using your usb modem to connect to the internet. then setup internet sharing on the computer and connect the wireless router to the network plug on the computer.....
then basically you are sharing the internet to the plug on the back of the pc into the router and then wirelessly out to the network and PS3
Aug 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Connecting PS3 via Belkin router to internet, wirelessly
I HV COMCAST AND THE BELKIN ROUTER AND I WANTED TO NO HOW CAN I CONNECT MY PS3 TO THE ROUTER.
Oct 28, 2007 | Computers & Internet
Belkin (F5D9230-4) Wireless Router (F5D92304) Logo
127 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
