Question about Hotpoint RGB745 Gas Kitchen Range
Replaced ignitor burned up after 10 seconds
I have a 9 year old hotpoint oven in great shape the ignitor in the stove went out I bought a replacement installed it and at first it lit fine then I screwed it in and a few seconds later the glow was really bright and it sparked and blew out. Help!!!
  • 1 more comment
  • mccplace Feb 15, 2008
    screwed the two mounting screws sorry
    this ignitor has 2 wires does it need to be wired up a certain way?
  • robert samples May 11, 2010
    what do you mean by you screwed it in
    President:
  • 1,314 Answers
Ok you might have just got a defective part take it back and get another one it should have a warrenty on it not enough power to blow it like that try another one and let me know
Posted on Feb 15, 2008
Gas oder when using oven, not when using burners. stove well over 14 years old.
What brand is it? Does the oven use a glow-bar ignitor, or a spark ignitor. I'm assuming it uses a glow-bar ignitor, and that ignitor is weak and needs to be replaced.
Sep 05, 2014 | Kitchen Ranges
Magic chef self ignitor top,, how do u get the oven to work.. is it self ignite too. i turn on oven ger a glow in the oven,, dont know the model ,,older stove. good shape. bought house with gas stove...
If the glow bar is glowing and the oven doesn't come on in about 30 - 45 seconds.... it probably is the glow bar that needs to be replaced. BUT it could be the oven valve. Usually it is the glow bar.
The glow bar is wired in series with the oven valve and even if it is glowing it may not be sending the correct voltage through to the oven valve. To change the glowbar... unplug the appliance, unscrew 2 screws holding the metal bracket to the burner and remove the ignitor. You can cut the 2 white wires going to the ignitor and use ceramic wire nuts with the new ignitor.
Tom
Aug 10, 2010 | Magic Chef 31000 Gas Kitchen Range
O'Keefe & Merritt Contempo Gas Stove Oven won't light
Probably needs the ignitor replaced. http://www.handymanwire.com/ubbthreads/showflat.php/Cat/0/Number/408747/an/0/page/332
May 24, 2010 | Kitchen Ranges
Hotpoint self cleaning oven won't heat
maybe a bad connection with the heating element. Check to make sure bottom element is pluged in all the way. May need to be replaced if anything looks strange (ie. burnt spot, hole, srrange color, or maybe no external sign)
Aug 15, 2009 | General Electric Stove/Oven/Range Chrome...
My stove works and so does my broiler. I replaced
If you use a multimeter, you can test the gas valve where the white and yellow wires connect is where your terminals for bake on that valve are. If you have continuity there, then check to make sure that igniter is wired ok.
http://tclaundryrepair.com/home
Feb 19, 2009 | Whirlpool SB160PEE Gas Single Oven
HOtpoint Electric stove/oven
You have not responded to my clarification request, so I'm guessing that you have resolved this issue. If not, let me know if I can still be of assistance.
Aug 26, 2008 | Hotpoint RGB745 Gas Kitchen Range
Tappen gas 4 burner about 10 years old with about 10 hrs total use time(basement stove)
Hi Carlsr,
The F1 error code description is an electronic oven control failure. To fix this error, you need to replace electronic oven control (also called EOC or clock).
Hope it helps.
Thank you for using FixYa.
Apr 13, 2008 | Tappan TGF320 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
115 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
