Question about MSI Starcam 370i Webcam
Resolution & picture problem
1) I can't set the pic res. higher than 176x144 !!
The settings app. in the taskbar (for SnapShot) doesn't have any other resolution option. How to set higher resolution?
Do I have to download some other application or...
2)
The colours in the picture look like the night mode is always on. (Black hair showed grey...)
(WinXp + SP2)
Thanks!
Mike
Solved it... :D
Well, the resolution option depends up on application that uses the camera at that moment... Dumb or not, this could have happened to anyone who used it with no additional software ( just with "My Computer -> MSI Star Cam 370i " icon )..
Posted on Feb 21, 2008
Some games need 1440x900 resolution to play but when i go to the display settings to change it, its not there just 1360x768, 1600x1200 and lower ones. I need help????
Hi there. If you're able to get 1600x1200 on the monitor, that should suffice--anything equaling or larger than the game's required res is ok...the picture will have a little bit of border on the edges because of the higher resolution but shouldn't be a hinderance at all. Remember this...the higher the resolution, the harder the graphics card has to work to maintain proper movement of the images in the game. Use the exact res if possible. However a close, higher res is fine, too.---Rick
Oct 03, 2009 | HP Compaq WF1907 Monitor
Says card full
Hi Mickcommodor,
It depends on what resolution the snaps are taken at.. generally cameras have setting that can be set to take pictures at lower resolution (requires loss space) or medium or higher resolution (takes more space on the card).
Also, I would suggest you to transfer all the pics on the card to the computer and then try formatting the memory card and then try again .. Let me know if that helps.
If both the above suggestions do not work for you then please let me know what is the capacity of the memory card and were you using this memory with the same camera earlier?
Regards,
Srinivas
Jun 29, 2009 | Fuji FinePix A345 Digital Camera
Dynex 19 LCD
I went over the specs of the TV.
The max input for the VGA is 1360x768 at 60Hz. Anything higher will make the TV go bonkers.
I would try to get the resolution at 1360x768, then change the frequency to 60Hz.
May 29, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
On screen resolution issues
Bought a new XGA projector.../
It appears from researching that the native res for the Benq is too low 800x600 so I will never get a good picture even though most of the images I install are at least 10meg originals. Also the new projector will work in a bright room the Benq will not.
May 07, 2009 | BenQ PB6110 Multimedia Projector
Screen resolution on powerpoint cannot be locked at high res. Changes when connected to my projector. Monitor screen res. also changes everytime the projector is plugged in, In power point display (2nd...
I just checked the specs on your Benq PB 6110, which has a native resolution of 800X600 and will simulate 1280X1024. When you connect it to your computer, the computer goes to 800X600, right? That is the resolution of the BenQ. How high a resolution do you want? THe highest I have seen in projectors is 1024X760, which is not that much higher. Projectors seem to lag behind monitors and Plasma/LCD/LED TVs for resolution. They must have a very small market share therefore low developement.
May 07, 2009 | Microsoft Office PowerPoint Home and...
Have a new 23 inch samsung monitor that requires res 1920x1080
The problem is the cable connection to the video card.
When using the DVI output of the FX 5500, the maximum screen resolution that you can select is 1280 x 1024.
But, if you use the Analog (VGA) output, the card will support resolutions up to 2048 x 1536, which should be ok.
Apr 23, 2009 | XFX GeForce FX 5500 Graphic Card
Stops taking pictures after approx. 128-130
Hi, Sue,
Not really sure on this, but if where he bought cam will take it back,try it...
However, it may not be the cam, but different resolution settings on the two different cams. Digital cams by different manufacturers format SD cards using different means; some allow more memory space on card for formatting than others..and if the game cam is set at a higher resolution than the other cam, then the 2nd cam might use space 1st cam left avail.i.e., say cam "sets aside 4mb of memory to format card, but only uses 2mb of this space. Now, the game cam is set for high resolution and take 130 pics @ 15mb each..15x130=1950mb,+ 2mb left by game cam=1952mb(1.952gb), or about 50mb of space left on card...put it into cam set for lower res. and might get several more pics before card was really full...be sure all is equal...both cams, and card,ect. 128-130 pics @ high resolution ain't bad....on a 4gb SDHC card with my I-40's set for High Res., I can get 1000 pics;@ enhanced and I get only about 300. Set at low res., and # goes way up.Hope you understand all this.
ron
Mar 11, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
My hp photosmart M547 will not give me the 2000 pictures it can hold. It says that the memory is full after 10 pictures.
hi there
if it only holds 10 pics it is probably working off the 16meg internal memory and not your card which if it is a 6 gig will hold about 2000 medium res pics
hope this helps
beergut707
Oct 20, 2008 | Cameras
Setting resolution on s5000 digital camera
It did likely re-set to lower resolution when the batteries were changed. To set it where you want, press the "F" button when in shooting mode. You'll see the options, one of which is for image size/quality.
Oct 06, 2008 | Fuji FinePix S5000 Digital Camera
Picture storage appears reduced
Hey there wenpet, there are two possible causes for your problem. On is that the card is not being totally emptied and the other is that your camera settings are at a higher resolution than before, therefore each picture has more detail, and is taking up more memory space. I would suggest that you use your computer to delete any thing remaining on the memory. Install the memory back in your camera and then reformat. This step should ensure your memory is totally empty. For the other potential problem, check the settings on your camera. The higher the resolution, the more memory space each picture uses up and vice versa. Your camera manual should indicate the picture memory usage for each setting. If you have any further questions, please let me know. Good Luck!
Mar 13, 2008 | Cameras
MSI Starcam 370i Webcam Logo
87 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
